This thread is privately moderated by SebastianJ, who may elect to delete unwanted replies.
Old Sep 29, 2007, 02:31 PM
SebastianJ is offline
Find More Posts by SebastianJ
Trader Rating: 0
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
Trader Rating: 0
New Product
1.15 m rotor gas coax.
Walkeras upcoming model LM8.
Main rotor dia. 1150mm.
All up weight 3300g.
Drive system 50A engine.
This thing is BIG!
Looks cool, can't wait to see a video.
SebastianJ is offline Find More Posts by SebastianJ
Old Sep 29, 2007, 03:17 PM
tkn0spdr is offline
Find More Posts by tkn0spdr
Trader Rating: 4
I see dumb people
Indian Harbour Beach, FL
Joined Sep 2007
Trader Rating: 4
I'm not sure about that. Why does a coax need a tail rotor? Smells fishy to me.
David
tkn0spdr is offline Find More Posts by tkn0spdr
Old Sep 29, 2007, 03:20 PM
tkn0spdr is offline
Trader Rating: 4
I see dumb people
Joined Sep 2007
Trader Rating: 4
Unless the rotors don't provide yaw and just always spin at constant RPMs.
Old Sep 29, 2007, 04:24 PM
crashduck is offline
Find More Posts by crashduck
Trader Rating: 0
expert crasher
Joined Aug 2007
Trader Rating: 0
That's probably it. Single motor to drive both sets of fixed pitch blades with a fixed gear and the belt-driven tail to control the yaw.
Not something I would want to buy, but interesting stuff...
crashduck is offline Find More Posts by crashduck
Old Sep 29, 2007, 05:23 PM
Velktron is offline
Find More Posts by Velktron
Trader Rating: 0
I fly ghetto stuff.
Velktron's Avatar
Greece
Joined Aug 2007
Trader Rating: 0
Doesn't this kinda defeat the purpose of a coaxial design? I mean, eliminating the tail rotor is what all alternative designs are all about (even though the tail rotor is the most popular to this day).
I mean, what, they cancel "most" of the torque with the coaxial design, and leave the tail rotor for yaw corrections? Then this would be a hybrid design, not a pure coaxial.
Velktron is offline Find More Posts by Velktron
Old Sep 29, 2007, 05:53 PM
i8urls6 is offline
Find More Posts by i8urls6
Trader Rating: 0
Joined Sep 2004
Trader Rating: 0
It would be extremely inefficient to run a tail rotor with a coaxial design.
i8urls6 is offline Find More Posts by i8urls6
Old Sep 29, 2007, 06:24 PM
salvagerat is offline
Find More Posts by salvagerat
Trader Rating: 0
My jail picture
salvagerat's Avatar
Tucson,Az
Joined Aug 2007
Trader Rating: 0
This thing is BIG!
do both of the main rotors spin the same way because that would be the only reason i think there would be a need to have a tail rotor
salvagerat is offline Find More Posts by salvagerat
Old Sep 29, 2007, 06:55 PM
Lou is offline
Lou
Find More Posts by Lou
Trader Rating: 1
Lou
Joined Dec 2005
Trader Rating: 1
In this design a tail motor would be a good idea, actually in the lama it would be a good idea.
With a single motor contra, the blades would fly ( spin ) at the same or near same rate. That means that you would have no way to correct any slight unwanted tail movement. This movement can be caused by wind, mechanics or what ever.
Add to this a tail rotor that has a constant speed, variable pitch prop and you can adjust the tail. For the most part the tail rotor prop pitch would be adjusted by the servo which would be receiving its instructions based on information generated by a servo. This servo would be a part of a 4n1, 3n1 or it could be a separate servo.
Why is this advantageous? One reason would be that with the main rotors spinning at a near constant rate that when a turn is induced there would be less loss of altitude.
Why you ask? Using the Lama as an example, when you induce a left or right turn, the gyro kicks in and detects a change in tail position. The gyro then induces the necessary voltage change to increase/decrease the power to the two motors for the main rotors. This change in voltage is what reduces the speed of the motor, the loss of rpm/speed is what causes the heli to lose altitude. Of course, the act of turning will also cause some loss of altitude, but when you drop the voltage to a motor, the altitude loss is increased quite a bit.
With both motors spinning constantly because only one motor is being used, then when a turn is induced and the tail position change is detected by the gryo, the correction is made by changing the pitch on the tail rotor. Because the mains are spinning constantly, less altitude is loss during the turn. The corrections are made by the tail rotor, not the main rotors.
This type of heli is what I have posted serveral times about. Single motor main rotors and a tail motor. Put an electic motor in this babe and they will have a winner; add linkage and an upper swash and this heli would be an Olympic champ.
Lou is offline Find More Posts by Lou
Old Sep 29, 2007, 07:28 PM
Velktron is offline
Trader Rating: 0
I fly ghetto stuff.
Velktron's Avatar
Greece
Joined Aug 2007
Trader Rating: 0
Even with two fixed-speed rotors, there would still be altitude loss upon rolling, also because one of the rotors would change cyclic pitch, while the other can't. You can also yaw without losing height just by increasing the speed of a motor while decreasing the other's, thus cancelling excessive altitude losses.
The "correct" way of eliminating the height loss upon yawing would be to have a proper double CP system and a differential collective pitch contol on both upper and lower rotors like e.g. on the Kamov helicopter, too bad that it's very complex to implement economically on a scale model.
A hybrix coax-tail rotor design is surely simpler to design and build, but it seems to me that it just brings the WORST of two worlds together: all inherent weaknesses of a tail rotor, plus the inherent limitations in speed and maneuverability of a FP coaxial rotor system with only one swashplate.
They probably chose this solution because a coax gas heli with different rotor speeds would be very hard to implement -again, the "correct" solution being a double differential CP control -.
Old Sep 29, 2007, 08:04 PM
slickster is offline
Find More Posts by slickster
Trader Rating: 0
Joined Jul 2007
Trader Rating: 0
Imagine the Toilet Bowl
OUCH!
slickster is offline Find More Posts by slickster
Old Sep 29, 2007, 09:27 PM
Lou is offline
Lou
Trader Rating: 1
Lou
Joined Dec 2005
Trader Rating: 1
Velktron, I agree with what you are saying. I am just pointing out that 'one' of the reasons for altitude loss is the power reduction induced onto the mains as a result of the gyro altering voltage to compensate for tail movement.
I took my Lama and did a program mix on my Optic 6 so that every time in commanded a left/right turn power was increased. This did reduce the altitude loss to near zero but the heli became a bit more effort to have to fly.
My take is that if you did the same thing with this new Walkera, that with it being a single motor driven contra that you could reduce the loss from a turn quite a bit. Of course that is just theory .... I don't have one yet to try this with.
By the way .... any idea why this thread was moved? I would think that regardless of power system, it is still a multi-blade heli. Seems to me that the multi-blade forum was appropriate.
Old Sep 29, 2007, 11:26 PM
HELIRLC is offline
Find More Posts by HELIRLC
Trader Rating: 57
HELIRLC
HELIRLC's Avatar
SOUTH CHARLOTTE, NC
Joined Feb 2005
Trader Rating: 57
The equally contra rotating blades will produce an extremely stable flying platform with virtually no yaw. This now needs the tail rotor to induce yaw, no gains but you lose the gyro, Now there is no need for a gyro,
It is in fact simpicity in in motion.
HELIRLC is offline Find More Posts by HELIRLC
Old Sep 30, 2007, 05:34 AM
Trader Rating: 0
Droner
SebastianJ's Avatar
Joined Mar 2006
Trader Rating: 0
Why has this thread been moved here to F/S wanted?
Old Sep 30, 2007, 08:31 AM
Lou is offline
Lou
Trader Rating: 1
Lou
Joined Dec 2005
Trader Rating: 1
Don't know why it was moved, ask a mod to move it back to the multi-rotor forum.
Old Sep 30, 2007, 12:38 PM
Velktron is offline
Trader Rating: 0
I fly ghetto stuff.
Velktron's Avatar
Greece
Joined Aug 2007
Trader Rating: 0
Even with mechanically linked contra-rotating motors with fixed relative speed, that still isn't a 100% guarantee of having 0% torque, so a gyro or at least an elementary trim control would be required.
Don't forget, mechanical systems are always imperfect, blades do not produde exactly 100% opposite torque, the (fixed) pitch on both blades isn't exactly the same etc. plus the lower rotors can change cylic pitch while the upper ones can't, thus any cyclic input would automatically disrupt the torque balancing.
Don't forget, real coaxial helicopters yaw by changing torque at constant rotor speed, by altering collective pitch, and messing around with one of the rotors is guaranteed to disrupt torque. So, all in all, you'd still need a gyro.
I also would like to know how they plan to implement the tail rotor drive system: since it has only trim/yaw corrections to perform, while the bulk of the torque would be canceled out by the coax system, it can be relatively less powerful that the tail rotor of a single-rotor heli.
From the included pics, it appears to be a continuously engaged CP tail rotor system (perhaps with lower speed). This means that it's as complex and delicate as a traditional single-rotor helicopter, although it requires less power for yaw control and anti-torque balancing.
Contest 1.5 m Summer Fling in Madison, Wisconsin July 15, 2007 (Hand Launch Contest) wingbeat Sailplane Events 0 Jul 11, 2007 03:54 PM
Help with motor upgrade 1.8 m glider Carl K Electric Sailplanes 3 Feb 06, 2003 06:52 PM
It's 11:15pm, it's 15, and I'm FLYING eBird Parkflyers 6 Jan 04, 2003 02:39 AM
FS 1.905-M Silent Dream (6 ft. 3 in.) Mose Aircraft - Electric - Airplanes (FS/W) 1 Jul 10, 2002 06:02 PM
