Old Sep 29, 2007, 08:36 AM
bladebogger is offline
Find More Posts by bladebogger
Joined Aug 2007
best 500-515 blade for 3d
im trying to make some changes to my L10 and im wondering what blades you guys use on your L10's for better cyclic...
any input would be appreciated
thanks
bladebogger is offline Find More Posts by bladebogger
Old Sep 29, 2007, 09:21 AM
epc2 is offline
Find More Posts by epc2
Miami Fl/Santo.Dgo.
Joined Jun 2004
thanks
1-Rotortechs 515
2-Mikado 500's
epc2.
epc2 is offline Find More Posts by epc2
Old Sep 29, 2007, 03:41 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
The new RotoTech blades are very good.
RC Man is offline Find More Posts by RC Man
Old Sep 29, 2007, 04:25 PM
Eco8gator is offline
Find More Posts by Eco8gator
United States, FL, West Palm Beach
Joined Jun 2001
Hello
You may want to consider paddles instead of blades. Bigger light paddles will probably help out a lot. BTW the mikado carbons work just fine on my Logo for 3D but mine is also flybarless...
Eco8gator is offline Find More Posts by Eco8gator
Old Sep 29, 2007, 04:33 PM
Wheelhaus is offline
Find More Posts by Wheelhaus
volts x amps = watts.
Wheelhaus's Avatar
Denver
Joined Sep 2006
Shorter blades will increase blade loading, *may* roll quicker since they have less mass and inertia, but they will definitely respond to collective with less authority than larger blades and will need more pitch to grab the same amount of air.. Since the blade loading is higher, the heli will feel "heavier" and not as floaty as larger blades... I'm not saying larger blades are the holy grail, but if you want 3D power then you want to grab as much air as possible.
What blades are you currently using and what is the setup?
Wheelhaus is offline Find More Posts by Wheelhaus
Old Sep 29, 2007, 07:37 PM
syclic is offline
Find More Posts by syclic
Joined Jan 2006
My favorite 3D blades on all my heli's are the RT's. Here my vote goes to the RT515's.
syclic is offline Find More Posts by syclic
Old Sep 29, 2007, 08:38 PM
Wheelhaus's Avatar
Denver
Joined Sep 2006
agreed, the best 500-515mm blades seem to be the 515mm Rotortechs.
Old Sep 29, 2007, 10:10 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
Have to agree, the RT 515s are very nice.
FB
Fred Bronk is offline Find More Posts by Fred Bronk
Old Sep 29, 2007, 10:52 PM
Joined Aug 2007
my current setup is 7s a123 on a19T pinion with a century 600+ motor...my flight times suffer at about 4.5 mins and the hel;i still isnt really that balistic...it bogs when ticktocking. Im thinking about getting the align 600l or xl motor and running a 4s 6000-8000mah prolite pack for better duration and reasonable power.
Old Sep 30, 2007, 04:12 PM
syclic is offline
Joined Jan 2006
bladeblogger
Your bogging is not a result of motor, but more of battery energy available on demand and disc loading (battery weight)
Your A123 under load only deliver about 2.6 Volts under our type of heavy loading and are only of about 2100mah. So even at a 20C demand burst rate, the total power on demand is relatively low compared to a good 4 cell or 5 cell lipo pack. Wattage peak of your A123 is about 2.6 x 7 x 2.1 x 20 = 764 watts. That of a good 5000mah 4 cell pack is 3.7 x 4 x 5 x 20 = 1480 watts. BIG DIFFERENCE!!
Personally I have found the combo of the 600+ motor on an 11T pinion with the light (not heavy) 5S1P/3700mah/20C TP or FP packs a great 3D combo. Head speeds of 1980 with flight times of 6 minute. The battery is warm (not hot) and the ESC and motor are cool!! So I expect a pretty long life from it all also.
Old Sep 30, 2007, 05:59 PM
Joined Aug 2007
3.7 is 50% discharged on lipo while 2.6v is totally out on the a123's...i think your numbers are wrong sir!
Old Sep 30, 2007, 08:52 PM
syclic is offline
Joined Jan 2006
Bladebogger
I am just going by the numbers from my eagletree monitoring system....that are also corraborated by tests in various magazines.
Note that I always said "good Lipo" packs. As I have tested some that rate themselves on their labels and in their ads as 4000mah and 15C and I would not class them as more then 2200mah at 8C.
Old Sep 30, 2007, 10:38 PM
Joined Aug 2007
syclic...you have provided some valuable info...I was just trying to stirr things up a little!
Discussion Best Cd-rom wind for 3d? Nooflyer Electric Motor Design and Construction 25 May 21, 2006 08:44 PM
Best Direct drive setup For 3d on 12# ultimate bip chickengeorge Sport Planes 4 May 15, 2005 04:20 PM
Question Best brushless and main blade for EP-CONCEPT? eko1212 Electric Heli Talk 0 Mar 23, 2004 08:59 PM
best gws power system for 3d planes easy2fly Power Systems 2 Nov 05, 2003 02:24 PM
Best Micro heli for 3D??? Jason M Electric Heli Talk 31 Jul 18, 2002 11:31 AM
