Yardbird RC YB-22 Park Jet Review
In this review, PJ Horne takes you up close, and personal with the electric, profile foam jet, the YardBird RC YB-22!
Wingspan:24"
Weight:12.5 oz.
Length:34.5"
Servos:2x Hitec HS-55
Transmitter:Futaba 7C
Receiver:Hitec Electron 6
Battery:Dualsky 25c 3s(11.1v) 1300mah
Motor:Motrolfly USA DM2210 1700kv
ESC:Motrolfly USA FM20A
Prop:APC 7x5
Manufacturer:YardBird RC
Available From:YardBird RC
Retail Price:$49.99
Released in January 2003, the F-22 Raptor is an American fighter aircraft that utilizes stealth technology. It is an air superiority fighter, but is equipped for ground attack, electronic warfare and signals intelligence roles as well. The United States Air Force considers the F-22 a critical component of the US strike force.
The F-22 is claimed by several sources to be the world’s most effective air superiority fighter. The US Air Force claims that the F-22 cannot be matched by any known or projected fighter aircraft.
The F-22 Raptor is a favorite for many, but with its $137,000,000 price tag, it is not something everyone can own. Now you can thanks to YardBird RC! Whether you have the need for speed, or just want a nice, stable plane that is great for everyday flying at the park, the YB-22 is the plane for you!
The plane arrived double boxed, and very well packaged. When I first opened the box I was very impressed. I expected metal rods, but was I wrong! I think was the first foam plane I have received that had NO warped parts!
Kit Includes:
  • Depron airframe
  • Carbon spars, and pushrods
  • Control horns
  • Instruction manual
  • Motor Mount
  • Decal sheet
Kit Requires
  • Brushless motor
  • Brushless 20A ESC
  • Two HS-55 servos
  • Elevon capable transmitter with a minimum of 4 ch
  • 4ch Receiver
  • 3s(11.1v) 1300mah Li-Po battery
  • X-Acto knife
  • Foam safe glue
  • Propeller
  • CA hinges
This is the simplest and fastest kit I have ever built. The included manual is very clear and has plenty of pictures!
The manual first says to cut off all the little tabs from the foam.
Fuselage/Wing
The vertical foam pieces of the fuse ARE supposed to stick out further than the horizontal fuse piece.
Tail
The manual says to use 6 of the included CA hinges on each elevon, but it does not need near that many and could stress out the servos as well, so I used 4 instead.
Electronics
 Motrolfly USA DM2210 Specs
Type: Brushless Outrunner
RPM/Volt (Kv): 1700
Resistance (Ri): 0.062 Ohms
Non-Load Current (Io): 1.6m Amps
Prop Range: 6x6 to 9x4.7
Nominal Power: 160w
Battery: 2s-3s Li-Po
Efficiency: 79.8%
Weight: 43 grams
Maximum Burst Current: 20A
Motor, and ESC supplied by MotrolFly USA, a Motrolfly exclusive USA distributor.
The electronics installation could not have been easier. There are only two servos to hook up, cutting way down on the build time. Make sure to secure all the wires inside the hatch so they will not dangle into the prop when you take off. I used a Hitec Electron 6, but you only need a 4 channel receiver.
 Hitec HS-55 Specs
Hitec HS-55 Specs
Type Sub-Micro Servo
Operating Speed 0.17 sec/60°
Stall Torque 15.27 oz-in.
Weight 0.28oz (8g)
Dimensions 0.89" x 0.45"x 0.94"
Connector Wire Length6.29"
Gear TypeAll Nylon
Operating Voltage4.8-6.0 Volts
My total flying weight came out to right about 12.5 oz. RTF, and flight times are around 9-10 minutes depending on throttle usage.
Control throw setup
High Rates UpHigh Rates Down
Left Elevon 35 degrees 33 degrees
Right Elevon 35 degrees 33 degrees
This plane flies VERY well, and is probably the most stable plane I have ever flown. There is ZERO wing rock, either upright and inverted. It is capable of very fast speeds, but can slow down to a crawl when you want it to. It sounds good too!
The YB-22 must be hand launched. Unlike most jets, you do not have to throw it: just give it about 50% throttle, and let 'er go! Since it does not have landing gear, you have to belly land it, but it is a very easy plane to land. It is best to land in grass if possible.
Loops, rolls, inverted flight, harriers, and inverted harriers are what this plane does best. High speed passes are awesome! Make sure you have plenty of speed when you pull out loops. If you don’t have enough speed, it will go into a spin.
No! While the YB-22 is very easy to fly, I would not recommend it as a first plane. It would be a good third of fourth aileron plane, though.
I HIGHLY recommend this plane! It is flies great and is sturdy too.
Pluses
Very clear, and easy to follow instruction manual
  • Fast build
  • Top notch hardware
  • Easy to fly
  • Very stable flyer
Minuses
None noted
Old Jan 23, 2008, 07:45 PM
TDisaster is offline
Find More Posts by TDisaster
"See and Sea" Pro
TDisaster's Avatar
United States, MO, Knob Noster
Joined Jun 2006
Great review Edge! Nice flying too!
TDisaster is offline Find More Posts by TDisaster
Old Jan 23, 2008, 07:47 PM
edge5foamy is offline
Find More Posts by edge5foamy
There is no place like Hodges!
edge5foamy's Avatar
United States, GA, Byron
Joined Mar 2007
Thanks!
edge5foamy is offline Find More Posts by edge5foamy
Old Jan 23, 2008, 07:48 PM
ihor14448 is offline
Find More Posts by ihor14448
ihor14448's Avatar
Strongsville, OH
Joined May 2007
wow, i was thinking if getting a foam jet someday, this will be perfect, where did you get it?
ihor14448 is offline Find More Posts by ihor14448
Old Jan 23, 2008, 07:54 PM
edge5foamy's Avatar
Joined Mar 2007
www.YardBirdrc.com
Old Jan 23, 2008, 08:57 PM
kissfan is offline
Find More Posts by kissfan
kissfan's Avatar
Muscle Shoals, Al.
I've been flying mine for about 4-5 months with the same setup as listed above, and I love it !!! Looks awesome in the air and sounds really cool too.
Very good review.
kissfan is offline Find More Posts by kissfan
Old Jan 23, 2008, 11:17 PM
kuczy is online now
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
If you set it up with 4 controll surfaces like the shockflyer su27 it handles much better and the barrel rolls are blistering. My neighbor has one and it flys awsome with the 4 controlls. He can hover and just start to barrel roll in place!!! Pretty sweet for a jet. It looks faster in the Yardbird RC video than it really is but I'd say it goes about 50mph 60 tops with the Dual Sky 12t and 7x5 apc.
kuczy is online now Find More Posts by kuczy
Old Jan 23, 2008, 11:34 PM
kuczy is online now
kuczy's Avatar
Joined Feb 2007
I forgot to mention this plane can slow way down. You can slow down enough to touch and go and accelerate straight up as high as you want.
Old Jan 23, 2008, 11:38 PM
Jim Mack is offline
Find More Posts by Jim Mack
Atlanta, GA
Joined Sep 2003
Thanks for doing a fine review for all us wanta-be jet jockeys.
Jim Mack is offline Find More Posts by Jim Mack
Old Jan 24, 2008, 06:42 AM
The Reaper is offline
Find More Posts by The Reaper
www.ReaperBrushless.com
The Reaper's Avatar
Joined Jul 2007
Motrolfly USA
dear edge
looks great how did you like that motor combo i put together for rick at www.yardbirdrc.com we love the Motrolfly USA DM2210-1700kv with the FM20 esc . they work well together.
scott
www.motrolflyusa.com
The Reaper is offline Find More Posts by The Reaper
Old Jan 24, 2008, 07:24 AM
dawnron1 is offline
Find More Posts by dawnron1
"Have Glue - Will Travel"
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Nice review PJ!
dawnron1 is offline Find More Posts by dawnron1
Old Jan 24, 2008, 08:38 AM
edge5foamy's Avatar
Joined Mar 2007
Originally Posted by MotrolflyUSA
dear edge
scott
Scott, this combo is awsome! It is a perfect match for this plane.
Thanks!
Old Jan 24, 2008, 08:40 AM
edge5foamy's Avatar
Joined Mar 2007
Originally Posted by dawnron1
Nice review PJ!
Thanks Ronnie!
Old Jan 24, 2008, 11:45 AM
Blaze.45 is offline
Find More Posts by Blaze.45
Seeing the Farside.
Blaze.45's Avatar
Seattle WA, USA
Joined Aug 2005
Nice review,
I've been flying mine for a month or so now... nothing but good things for this one. Reliable and EASSSSY is the two words that come to mind. I can't believe how easy the launches are... in all honesty, I actually land multiple times throughout a flight JUST to hold it in my hand and take off again.
Thanks YB RC.
-Chris
Blaze.45 is offline Find More Posts by Blaze.45
Old Jan 24, 2008, 01:58 PM
2dogrc is offline
Find More Posts by 2dogrc
2dogrc's Avatar
United States, NC, Vass
Joined Apr 2005
Originally Posted by Blaze.45
Nice review,
Thanks YB RC.
-Chris
Blaze!
WOW surprised you bought one of this! I guess your $50 foamy rule has a loophole for kick butt planes!
2dogrc
2dogrc is offline Find More Posts by 2dogrc
Site Sponsor
Article Great Planes L-39 Albatros Jet EDF ARF Review Bajora Foamy EDFs 584 Dec 03, 2014 07:39 AM
Article 3D Hobby Shop 47'' Yak 54 ARF Review Get Real 3D Flying 21 May 29, 2011 11:00 PM
Discussion Electric Foam Models EPP Edge 540 chris8105 3D Foamies 11 Apr 09, 2009 07:39 PM
