Old Jun 03, 2008, 09:55 AM
Sisyphus is offline
Find More Posts by Sisyphus
Sisyphus's Avatar
Upper U.S.
Silent, I have one in the box so forgive my asking (I have not looked), but is the elevator control rod sticking in the sleeve or guide? (fine steel wool sanding often helps, followed by white or similar grease)
Sisyphus is offline Find More Posts by Sisyphus
Old Jun 03, 2008, 10:02 AM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
http://www.nesail.com/detail.php?productID=5572
Guys it looks like this site has some at the old price. I didn't go all the way through so not sure. Also, I have never purchase from them so buy at your own risk.
blakevan is offline Find More Posts by blakevan
Old Jun 03, 2008, 10:09 AM
Sisyphus is offline
Sisyphus's Avatar
Upper U.S.
Very reliable seller, but shipping can be high: I have a Viking from NE, which is a real beauty in the air!
Old Jun 03, 2008, 10:15 AM
silent_guru is offline
Find More Posts by silent_guru
Hold my Beer and watch this!
silent_guru's Avatar
USA, MA, Brockton
Joined Sep 2007
It might be. It seemed that the angle of the dangle changes and puts pressure on the control rod when it is pulled in (down elevator) and there is less pressure on the rod when it moves out (up elevator). The end of the tube is a bit messed up in the back where it exits. Looks like they made the hole in the covering with a soldering iron and melted a bit of the tube end.
silent_guru is offline Find More Posts by silent_guru
Old Jun 03, 2008, 10:20 AM
Sisyphus is offline
Sisyphus's Avatar
Upper U.S.
"The angle of the dangle...." I have not heard that one in years-there is an entire formula as I recall.
Old Jun 03, 2008, 10:27 AM
USA, MA, Brockton
Joined Sep 2007
"The angle of the dangle is inversely proportionate to the heat of the beat"
Old Jun 03, 2008, 11:07 AM
Sisyphus is offline
Sisyphus's Avatar
Upper U.S.
Yes, that's very, very close!
Old Jun 03, 2008, 09:18 PM
Holtenbacker is offline
Find More Posts by Holtenbacker
Holtenbacker's Avatar
Modesto, California USA
Joined Jan 2004
My experience with NE Sail is that shipping runs about twice that of others (Tower, Horizon,etc.) and half of what I received had some damages. His customer service is legendary (on the bad side) lots of threads have been dedicated to him.
Holtenbacker is offline Find More Posts by Holtenbacker
Old Jun 03, 2008, 09:34 PM
Sisyphus is offline
Sisyphus's Avatar
Upper U.S.
Yes, he does have quite a group of "followers." Maybe I was lucky.
Old Jun 05, 2008, 06:30 PM
goldeneye007 is offline
Find More Posts by goldeneye007
Joined Jan 2007
ok who has a good way of quick fitting the wing struts to the fuselage. as i have to remove the wing for transport.
goldeneye007 is offline Find More Posts by goldeneye007
Old Jun 05, 2008, 07:00 PM
Joined Jan 2004
Never found that to be a problem.
I back out the screw enough to clear the fuse but remain in the strut.
It clears through the gap in the gear
takes only about 15 - 20 seconds to mount the strut on.
Old Jun 07, 2008, 07:03 AM
e_airman is offline
Find More Posts by e_airman
Oh - yeah, I meant to do that
e_airman's Avatar
Central NY
Joined Feb 2008
Hey Guys,
I have had my T-craft for about a month or so and its still in the box. . . time for me to start building (actually it will be another week or so), but I want to start collecting the necessary hardware. I believe I will be going with the recommended EF 450 power system. My question is: What about the servos - has anyone had any issues with the recommended e-flite (EFLRS75) servos? Are they to Big/Small, quality good/poor?
I would normally use Futaba S3114 for a plane in this class, but I am thinking I would like to try the e-flite servos, but only if others have had a good experience with them. Thanks for any input you may have - e_airman
e_airman is offline Find More Posts by e_airman
Old Jun 07, 2008, 07:14 AM
DeaninMilwaukee is offline
Find More Posts by DeaninMilwaukee
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
Originally Posted by e_airman
Hey Guys,
I would normally use Futaba S3114 for a plane in this class, e_airman
Don't use the eflite servos. These are the same ones that come stock in the blade cp helicopters, of which I had one. Besides having a geartrain that becomes excessively sloppy after only a couple of hours of operation, I had no less than 3 of them fail on me electrically while in flight. They just locked up solid and created a glitching situation till they were unplugged. I was very lucky not to crash from these failures.
The 3114's on the other hand are excellent, perhaps the best in this cost/size class.
Dean in Milwaukee
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old Jun 07, 2008, 09:03 AM
moogly is offline
Find More Posts by moogly
moogly's Avatar
Joined Jun 2006
Hey Guys,
H run Hitec HS 65s. the HS55s striped and so did the e-flite the e-flights were the worsred but the Hitec HS65
are karbonite ?and they drop right in and are soild as a rock
just my 2 cents
moogly is offline Find More Posts by moogly
Old Jun 07, 2008, 09:10 AM
USA, MA, Brockton
Joined Sep 2007
Hey Guys,
I used the S75's in my mini pulse. They were very crappy and gave out one by one. I am using HS55's in my T-Craft but I am going to at least change out the elevator servo to an HS65 today becasue there is still some binding and it does not like to center from down elevator input. I sanded and lubed the rod and cleaned up where the rod exits the fuse, things are better. I got a few more flights on her early this morning and I am loving this plane now that I am getting more used to how little throttle it needs to put around.
New Product E flite Taylorcraft for 450 or 480 P-51C Scale ARF/RTF 23 May 23, 2009 05:11 AM
Discussion E-Flite park 450 outrunner, 980kV - suggested plane(s) or kits? dougaustin Power Systems 4 Jul 01, 2006 02:49 AM
Wanted E-Flite Park 450 Outrunner Twmaster Aircraft - Electric - Power Systems (FS/W) 3 Jun 17, 2006 11:41 AM
For Sale E-Flite Park 450 outrunner motor(3 days old) wilsonbueno Aircraft - Electric - Power Systems (FS/W) 3 Mar 01, 2006 10:10 PM
Question E-flite Park 450 vs Hacker A20-20L Jimmy Hoffa Power Systems 2 Dec 19, 2005 02:29 PM
