Old Mar 26, 2008, 06:51 AM
moogly is offline
Find More Posts by moogly
moogly's Avatar
Joined Jun 2006
Originally Posted by goldeneye007
get a wattmeter as soon as you can. i have been flying EP for over a year and i have only just got one. but it is the best investment i have made. i had a plane with a 20A ESC but i thought i needed a bigger ESC so i paid out for a 40A only to find out when i got a wattmeter my setup was only pulling 16A. so i could of saved some cash.
better yet get a logger I use an eagle tree and found out that most of my planes draw alot less in the air than sitting on the ground my T craft only pulls 7 amps avg. with a 10X6 prop and maybe 18-22 on take off theres some data eariler in this thread
moogly is offline Find More Posts by moogly
Old Mar 26, 2008, 12:52 PM
kthomas is offline
Find More Posts by kthomas
kthomas
USA, GA, Buford
Joined Aug 2004
Motor Mount Help
I banged up my Taylorcraft motor mount and am doing some repair. The sidewalls are in good shape. The front wall (to which the motor bolts) got crushed. I've made a new, simpler piece from ply that fits snuggly into the puzzle lock tabs on all sides. The hard part is finding the exact center for the motor so the prop shaft exits the cowl without touching. It is not in the exact center of the mount (up a little). Could someone post a close-up photo facing directly head on to the stock motor mount so I can make a good esimate of the center. If you have a flatbed scanner, set it on the glass (dark room) and scan it for the ultimate closeup.
Any help is appreciated.
kthomas is offline Find More Posts by kthomas
Old Mar 26, 2008, 01:14 PM
rcwings is offline
Find More Posts by rcwings
North Simcoe Flyers
rcwings's Avatar
Midland, Ontario, Canada
Joined May 2007
moogly,
What logger at you using or recommend?
rcwings is offline Find More Posts by rcwings
Old Mar 26, 2008, 01:44 PM
tdearth is offline
Find More Posts by tdearth
USA, IN, Nineveh
Joined Apr 2002
It would almost be easier to just start from scratch.
Hold the fuse in a vertical position and set your motor on the mount approximately centered.
Put the cowl on and scoot the motor around until you have it centered and then carefully remove the cowl without moving the motor and then mark it's position for mounting screws.
It helps to have someone else hold the plane while you do this unless you have some way to clamp it while you work on the front.
Tim
tdearth is offline Find More Posts by tdearth
Old Mar 26, 2008, 02:04 PM
Vyceroy is offline
Find More Posts by Vyceroy
G G Ghost Pirates !!!
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
Is anyone else with a Taylorcraft coming to SEFF ??
Vyceroy is offline Find More Posts by Vyceroy
Old Mar 26, 2008, 09:30 PM
Flying-Monkey is offline
Find More Posts by Flying-Monkey
Did you get it on video?
Flying-Monkey's Avatar
United States, FL, Ponce De Leon
Joined Nov 2005
I might put mine together by then
Flying-Monkey is offline Find More Posts by Flying-Monkey
Old Mar 27, 2008, 11:37 AM
Palmettoflyer is offline
Find More Posts by Palmettoflyer
Palmettoflyer's Avatar
United States, SC, Mt Pleasant
Joined Jun 2002
Better question is how many of them will be there? How about having the mass launch of Taylorcrafts at the same time!
Seriously, this is a really cool plane I do hope to see a bunch of them.
Palmettoflyer is offline Find More Posts by Palmettoflyer
Old Mar 27, 2008, 12:05 PM
Vyceroy is offline
Vyceroy's Avatar
USA, NC, Gastonia
Joined Dec 2001
i was thinking same thing .. would make a nice ad for Eflite to have several up flying all at once ..
Old Mar 27, 2008, 12:10 PM
wingbeat is offline
Find More Posts by wingbeat
Gravity gets me down.
wingbeat's Avatar
United States, WI, Milwaukee
But you better put some numbers or other colors on them.
Might be hard to keep track of whose is whose!!
wingbeat is offline Find More Posts by wingbeat
Old Mar 27, 2008, 12:25 PM
moogly is offline
moogly's Avatar
Joined Jun 2006
Originally Posted by rcwings
moogly,
Eagletree has been really good to me lots of upgrades and the have the V3 out now with more memory. It works great theres a big difference between static and flight data.
I can show 20 + amps static and in the air its more like 7 - 8 Avg. with 20 on takeoff.
Old Mar 27, 2008, 04:02 PM
goldeneye007 is offline
Find More Posts by goldeneye007
Joined Jan 2007
can someone tell me the size of the servo holes so i know what sort of servo to look for. thanks Dave
goldeneye007 is offline Find More Posts by goldeneye007
Old Mar 27, 2008, 04:45 PM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Hitec HS65 servos are a drop in fit.
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old Mar 27, 2008, 04:50 PM
A Rdnek is offline
Find More Posts by A Rdnek
Bruno, GOOD DOG
A Rdnek's Avatar
United States, IA, Grinnell
Joined Aug 2007
So are these.
http://www.unitedhobbies.com/UNITEDH...idProduct=5456
Ron
A Rdnek is offline Find More Posts by A Rdnek
Old Mar 27, 2008, 07:12 PM
Holtenbacker is offline
Find More Posts by Holtenbacker
Holtenbacker's Avatar
Modesto, California USA
Joined Jan 2004
Originally Posted by A Rdnek
Did you see the customer reviews?
Holtenbacker is offline Find More Posts by Holtenbacker
Old Mar 27, 2008, 08:21 PM
rcwings is offline
North Simcoe Flyers
rcwings's Avatar
Joined May 2007
I was looking at those last night and looks pretty slick!! Are you using the optional "power panel"? Or straight to PC? approximately how much flight time can you get data for? (I guess that would also depend on what you are monitoring as well...AMPS, Heat, RPM, Speed.....) From what I have read, you can run it in the plane to collect data, then yank out and pull data later....or do you actually have to always have it connected to power in order to retrieve the data? (i.e. in the plane)
Looks much more versatile than the standard meters on the market, and not much more $$. Just gotta find someone who sells it up here, as the shipping and brokerage fees can sometimes hurt the pocket book
Sorry to get off track here guys....but if I ever get that TCraft up here at my LHS, suspect this would make a good fixture.
New Product E flite Taylorcraft for 450 or 480 P-51C Scale ARF/RTF 23 May 23, 2009 05:11 AM
Discussion E-Flite park 450 outrunner, 980kV - suggested plane(s) or kits? dougaustin Power Systems 4 Jul 01, 2006 02:49 AM
Wanted E-Flite Park 450 Outrunner Twmaster Aircraft - Electric - Power Systems (FS/W) 3 Jun 17, 2006 11:41 AM
For Sale E-Flite Park 450 outrunner motor(3 days old) wilsonbueno Aircraft - Electric - Power Systems (FS/W) 3 Mar 01, 2006 10:10 PM
Question E-flite Park 450 vs Hacker A20-20L Jimmy Hoffa Power Systems 2 Dec 19, 2005 02:29 PM
