Old Jan 05, 2008, 06:28 PM
oldfish is offline
Find More Posts by oldfish
FLYING Better Than Drugs
oldfish's Avatar
Thonotosassa, FL
Joined May 2007
I've been looking at this one too
http://www.3dhobbyshop.com/detail.aspx?ID=2097
oldfish is offline Find More Posts by oldfish
Old Jan 05, 2008, 06:30 PM
silent_guru is offline
Find More Posts by silent_guru
Hold my Beer and watch this!
silent_guru's Avatar
USA, MA, Brockton
Joined Sep 2007
EBT = Electric Basic Trainer. The "Top Gun" elctric flyer at my field has one. It flys gentle and slow, but can still do aerobatics. He hover his
http://www.quietrcflying.com/Product...id=3DH-EBT-ARF
silent_guru is offline Find More Posts by silent_guru
Old Jan 05, 2008, 08:26 PM
jed1d is offline
Find More Posts by jed1d
Sherman, TX
Joined Aug 2003
Ebt
I have been flying for sometime. I am putting together an EBT right now. The plane seems to be well built. All videos indicate that EBT flys well. A friend has one , he has been flying for years, and loves it. thanks...Joe from Texas
jed1d is offline Find More Posts by jed1d
Old Jan 06, 2008, 09:58 AM
staggerwing is offline
Find More Posts by staggerwing
In NY's beautifull hills
staggerwing's Avatar
Binghamton Broome Cty, New York, United States
Joined Jun 2004
Floats
Just came upon this thread--w/o reading the whole thing, has anyone put floats on one of these ?
Thks
Bob
staggerwing is offline Find More Posts by staggerwing
Old Jan 06, 2008, 02:01 PM
Charley38 is online now
Find More Posts by Charley38
United States, TX, Kerrville
Joined Oct 2003
Thks
Bob
Not to my knowledge but I have a set of GWS floats that I used on my Mini Ultra Stik. Too cold right now.
CR
Charley38 is online now Find More Posts by Charley38
Old Jan 06, 2008, 03:27 PM
Joined Jun 2004
Thks CR. I have this kit & am going to give it a try for both snow & water
I noticed Tower has some plastic floats that would appear to work for a reasonable price ($33) but are currently out of stock
Bob
Old Jan 06, 2008, 03:37 PM
Tom Smith is online now
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
The GWS floats work great for $11.
Tom Smith is online now Find More Posts by Tom Smith
Old Jan 06, 2008, 03:40 PM
Joined Oct 2003
Bob
AIR, the GWS floats are less than 20 bucks. They worked fine on my MUS. Look here:
http://www.rcgroups.com/forums/showt...=MUS+on+Floats
These are foam with plastic Vee bottoms.
CR
OOPS! The link to my pics is in Post #11.
Old Jan 06, 2008, 03:55 PM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
GWS floats on this plane? Have any pic's of your mounting?
rvincent is online now Find More Posts by rvincent
Old Jan 06, 2008, 04:23 PM
Joined Oct 2003
Not on the T'craft yet. Shouldn't be too tough tho. Mount the floats to the main LG with the step at the CG. One would have to install a rear LG block in the fuse, fabricate or adapt a rear LG setup. If I was living in snow country I'd already have those floats mounted in lieu of skis.
CR
Old Jan 06, 2008, 05:42 PM
Joined Jun 2004
GWS floats
Hi Tom,
Think we corresponded awhile back on something.
The GWS are 21" & have no specs that I can find on recommended model weight--does anyone here have any weights on models mentioned that have used these floats successfully ?
Tom, are you saying you've used them on the T Craft ?
Bob
Old Jan 06, 2008, 05:52 PM
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
No Bob, I had them on a Husky. See photo. They worked great. Floats should be 75% of the length of the model from the back of the prop to the rudder hinge. That is a good rule of thumb to use. At 21" the GWS floats should be OK on models up to 28" long from back of prop to rudder hinge. The T Craft is 31" in that length so the GWS floats are a tad short but should work fine because the model is very light. With the step on the CG the floats should extend out past the prop by an inch or two to keep the model from trying to submarine when power is appied. It would be worth trying for an $11 investment. They work great on snow too because the bottom half of the float is hard plastic that slides like crazy on snow or wet grass. The tops are molded foam. Tom
Old Jan 06, 2008, 09:13 PM
Jaybird is offline
Find More Posts by Jaybird
Hallowell, Maine
Joined Jan 2002
Taylorcraft on foam floats
I've put mine on some 25" long foam floats and it it works great off powdery snow. All the water in Maine is frozen right now for the most part so I'll have to wait for the water test. I have a taxi video loaded and I'm trying to get a flight one put up. Using the 450 outrunner and 11 x 4 wide blade slow prop works great and still does most aerobatics, but why would you! Fly bys and touch and goes are the thing. The water rudder is from the previous et up and the linkage is not hooked up. I think I'll make a bigger one if the air rudder won't handle it. Here are a couple pictures and a link to the taxi video.
http://www.rcgroups.com/forums/showthread.php?t=797097
Jay
Jaybird is offline Find More Posts by Jaybird
Old Jan 07, 2008, 05:17 AM
Joined Jun 2004
Thks Jay--sure looks great & what an inspiration to put floats on this bird !
Do you know the AUW ?
Bob
Old Jan 07, 2008, 05:59 AM
Dennis Sumner is online now
Find More Posts by Dennis Sumner
Wanted for breaking Ohm's Law
Dennis Sumner's Avatar
United States, MI, Canton
Joined Sep 2002
RE: Floats, has anyone looked at the float kit by Top Notch Kits? It is 26" long and sounds like a prefiect fit for the Taylorcraft or their Cessna 195 kit, I have attached the PDF construction manual. I think they get $25.00 for their kit.
Enjoy!
Dennis Sumner is online now Find More Posts by Dennis Sumner
New Product E flite Taylorcraft for 450 or 480 P-51C Scale ARF/RTF 23 May 23, 2009 05:11 AM
Discussion E-Flite park 450 outrunner, 980kV - suggested plane(s) or kits? dougaustin Power Systems 4 Jul 01, 2006 02:49 AM
Wanted E-Flite Park 450 Outrunner Twmaster Aircraft - Electric - Power Systems (FS/W) 3 Jun 17, 2006 11:41 AM
For Sale E-Flite Park 450 outrunner motor(3 days old) wilsonbueno Aircraft - Electric - Power Systems (FS/W) 3 Mar 01, 2006 10:10 PM
Question E-flite Park 450 vs Hacker A20-20L Jimmy Hoffa Power Systems 2 Dec 19, 2005 02:29 PM
