Old Jan 03, 2008, 10:23 AM
InspectorGadget is offline
Find More Posts by InspectorGadget
It Wasn't Me!!!!
InspectorGadget's Avatar
Joined Feb 2005
Originally Posted by E-Challenged
If you are using four servos and 3S lipo you should install a Park BEC or other switching type add-on BEC especially with Spektrum receivers. I learned the hard way and don't fly 3S and four servos without them anymore.
I have heard this before and I have 3 planes setup now with what is NOT reccommended, which is 4 servos on 1 ECS using a 3S with a spectrum reciever.
So far I have had NO problems---but I may just be tempting faite, but I rearley push the envelope.
My Talorcraft is one of them and so far she flies GREAT.
C-YA RL
InspectorGadget is offline Find More Posts by InspectorGadget
Old Jan 03, 2008, 10:27 AM
rvincent is online now
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
You guys using Spektrum could just add the capacitor that the sell for $6 and then you would be safe too
rvincent is online now Find More Posts by rvincent
Old Jan 03, 2008, 10:36 AM
Charley38 is online now
Find More Posts by Charley38
United States, TX, Kerrville
Joined Oct 2003
Originally Posted by Gary Hoorn
phyxer,
I have the 480 in my Taylorcraft. It may be overkill according to some but as I fly off a grass field the power is handy.
Gary
I fly off of a grass field too and I have the small wheels and spats installed. I'm using the Park 450 and 22 amp ESC that came in my MUS PnP. My T'craft has no problem getting off at less than full throttle and it climbs out steeply. I agree with the "some" who think that the 480 is overkill unless you want to hang it on the prop, as in 3D.
BTW, your 480 must be loafing on that 10x6 prop. I'm using a 10x7 Slo-Fly APC on my 450 and it barely gets warm.
CR
Charley38 is online now Find More Posts by Charley38
silent_guru is offline
Find More Posts by silent_guru
Hold my Beer and watch this!
silent_guru's Avatar
USA, MA, Brockton
Joined Sep 2007
Can you tell us more about the capacitor? I fly a Mini-Pulse with a 450 and four servos, 25a e-flite ESC and Spektrum AR6000 and think I may have had the shutdown problem once. After some full throtle passes over the runway it stopped responding to input and nosed in.
silent_guru is offline Find More Posts by silent_guru
Old Jan 03, 2008, 10:57 AM
rvincent's Avatar
Joined Jul 2004
You can find it anywhere Spektrum stuff is sold. All it does is to be sure your voltage never drops below 3.7v's to cause a system re-boot and loss of control during that L-O-N-G 4 second lock out. It just plugs into an open reciever chanel and maintains even system voltage. Quite simple and brilliant actually
Old Jan 03, 2008, 11:26 AM
Gary Hoorn is offline
Find More Posts by Gary Hoorn
Chesapeake Bay RC Club
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
Charley38,
I experimented with some different props and settled on the 10x6. WOT the speed gets quite high and the vertical is almost unlimited using a TP Extreme 2200mah V2. I am careful to close the throttle on down lines to control the speed build up. My T-Craft will do huge loops at about 3/4 throttle both inside and outside. Just a fun plane to fly
Gary
Gary Hoorn is offline Find More Posts by Gary Hoorn
Old Jan 03, 2008, 11:30 AM
phyxer is offline
Find More Posts by phyxer
USAF Retired
Altus, OK
Joined May 2007
For me personally, and I stress the "personally" part, the motor issue is DEAD! I purchased the Park 480 with FULL knowledge that the Park 450 was enough motor to adequately fly the Taylorcraft 450. I have learned (the hard way) that sometimes it is best to leave a little room for error when specking rc airplanes. I chose to go this route with this airplane. I have also learned that my transmitter has two levers on it that are used to control the speed and attitude of my rc airplanes. In my case (mode 1); the stick on the right when moved forward and aft controls the speed. I can consitantly identify that particular stick 9 out of 10 times without confusing it with any other control. I am also improving my ability to properly actuate it on a daily basis. I really didn't want to start a war over the proper engine for this airplane; I am more concerned with all of the rest of the specking of the airplane and I truly do appreciate and look forward to all of your inputs on the specking of the rest of my electronics. And yes, I realize that this post may be taken by some the wrong way, but just so you now, it was meant to make you chuckle more than make you mad! Thank you.
Troy
phyxer is offline Find More Posts by phyxer
Old Jan 03, 2008, 03:07 PM
Joe Minton is offline
Find More Posts by Joe Minton
Newbury Park, California
Joined Apr 2002
As Cook Neilson, then the editor of Cycle magazine, told me: "Minton, too much power is --- perfect." He was probably right as he won his class at the Daytona speedway that same year (1977).
More thrust than weight sure is nice when your'e four feet off the ground and in the middle of a stall!
Joe
Joe Minton is offline Find More Posts by Joe Minton
Old Jan 03, 2008, 03:12 PM
trashbug is offline
Find More Posts by trashbug
trashbug's Avatar
United States, OH, New Franklin
Joined May 2004
You can find your cap. here.
Jim
trashbug is offline Find More Posts by trashbug
Old Jan 03, 2008, 03:35 PM
Tom Smith is offline
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
Dang, that's interesting. I have my Spektrum DX 6 in 9 model planes and one sailboat with narry an issue, but this might be good insurance on a model that draws a lot of power for the servos. Thanks, I honestly never ever heard of doing this, but in makes sense, and is as simple as can be. Tom
Tom Smith is offline Find More Posts by Tom Smith
Old Jan 03, 2008, 03:46 PM
phyxer is offline
USAF Retired
Altus, OK
Joined May 2007
I bet that would work great as an insurance policy on my ASSAN 2.4 GHz system receivers too! Thanks!
Old Jan 03, 2008, 05:16 PM
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
I can assure you a capacitor is no replacement for an ESC that is not capable of delivering the required amount of current. At best it will handle only short spikes. That part is really designed for RC Cars.
Gary
Old Jan 03, 2008, 05:24 PM
rvincent's Avatar
Joined Jul 2004
Gary you are 1000% correct, but that one time lock out for 4 seconds while it reboots after an instant at or under 3.7v's will be complete disaster for most planes. A cheap, yet effective insurance policy is all most will require.
Old Jan 03, 2008, 05:26 PM
phyxer is offline
USAF Retired
Altus, OK
Joined May 2007
Gary
Oh I completely agree! I wasn't planning on substituting the capacitor for a seperate BEC, the capacitor would just be another layer of insurance for trying to extend my airplane's expiration date!
Old Jan 03, 2008, 06:07 PM
Gary Hoorn's Avatar
USA, MD, Annapolis
Joined Feb 2005
The best insurance is a good ESC and decent Lipos that will deliver the power under load. I use Thunder Power V2 Extreme 2200mah Lipos in mine and a Castle Thunderbird 36amp speed control. This combo works just fine in my T-Craft with 4 Hitec HS65 servos. A 6 minute flight with throttle management on the 480 requires about 850mah from the Lipos. I am breaking in the new Lipos so flight times are short. I intend to stretch them out after 6 cycles.
Gary
New Product E flite Taylorcraft for 450 or 480 P-51C Scale ARF/RTF 23 May 23, 2009 05:11 AM
Discussion E-Flite park 450 outrunner, 980kV - suggested plane(s) or kits? dougaustin Power Systems 4 Jul 01, 2006 02:49 AM
Wanted E-Flite Park 450 Outrunner Twmaster Aircraft - Electric - Power Systems (FS/W) 3 Jun 17, 2006 11:41 AM
For Sale E-Flite Park 450 outrunner motor(3 days old) wilsonbueno Aircraft - Electric - Power Systems (FS/W) 3 Mar 01, 2006 10:10 PM
Question E-flite Park 450 vs Hacker A20-20L Jimmy Hoffa Power Systems 2 Dec 19, 2005 02:29 PM
