Hallowell, Maine
Joined Jan 2002
Hi bj,
I'm thinking the stabilizer saddle might not be aligned properly front to back. The extra weight, assuming it balances the same, would make the plane want to fly faster to generate more lift to carry the additional weight. The up elevator is an attempt to increase the angle of attack which would also generate more lift but at a slower speed. Unfortunately this also generates more drag as a result of the increased lift and form drag from the elevator deflected into the slip stream. My guess is that the leading edge of the stabilizer is angled up which would induce an upward force on the tail and point the nose down. We then have to add up elevator trim at the trailing edge to bring it back down. With such a short tail moment it would take a fair amount of deflection to get the counter force required...maybe. Without plans to varify alignment and incedence we are just guessing here. I wish ARF's would include just one sheet with a side view and angles to check. Jay |
Surrey, BC, Canada
Joined Feb 2007
If the tail is already glued to the fuselage it is a bit more difficult to glue the elevator connecting rod in. What I would recommend is cutting the CA hinges, clean up the hinge line, glue the connecting rod into the elevator halves while it is in place in front of the rudder post then just use hinge tape to hinge the elevator. Just leave enough room between the elevator and horizontal stabilizer so that there is no hinge binding.
bgfireman,
I would not trust an S75 servo on the elevator of the Taylorcraft. If you require more up elevator after going to a larger battery try moving it more to the rear to adjust the CG. I am using TP Extreme 2200's in mine and have to move the battery back quite a bit to even get the rearward CG. I also modified the hatch hold down slightly with my Dremel to make battery installation easier. Gary |
United States, TX, Kerrville
Joined Oct 2003
Cheers, CR |
I attached the elevator without considering that the hinge was off. It'll be a lot trickier to cut and re-hinge while mounted. A case of "new plane" excitement and not using my head. Doh! And I agree on the notion that ARFs ought to ALWAYS include decalage/incidence readings. This is as basic as CG. If these flight requirements aren't tuned in, there's going to be some frustrating compensation. Most, if not all of my slopers are 0º/0º, both wing and tail set level. Not all the powered planes I've built and flown- either electric or fuel- are the same. Definitely not an expert here- would love to know what the seasoned flyers think on this. |
Mooresville, Indiana
Joined Sep 2003
Good Build
All,
While I haven't been able fly my Taylorcraft yet do to the weather, I am pleased to say that all assembly went very well without any issues and my struts fit perfectly to the holes provided in fuse and wing. Although it is a minor flaw, I do have the small gap where the bottom of the wing meets the fuse, which also was mentioned by several others. If the Taylorcraft flies as well as it builds and looks, I will be extremely pleased Joe |
Maiden flight
Just got back from the field and I must say, this model is everything everyone said it was. She flew just fine with just a few clicks of trim. I was using an old 2500 mah 3s lipo that would not take full throttle without cutting off. So, my takeoff was at a tad over 1/2. Still flew super with my AXI 2808-24 outrunner. Flew for about 8 minutes and did some loops, rolls and inverted flight. Handled everything just fine, and greased the landing. Looks sweet in the air, and handles great. Guys at the field were impressed, to say the least. Tom
Hallowell, Maine
Joined Jan 2002
Great news Tom. Glad it went well for you. I was out at noontime today as well. Can't see quite see as much grass though...covered with more than a foot of snow. It was nice because the last storm ended with some rain and freezing rain (if you call that nice) so the soccer field had a hard crust over the whole surface. The snowmobilers hadn't been all over so I had unbroken surface to land and take off from. Oh, it was 27 degrees and calm...yeah baby!
Another storm arrives this evening with 6 to 8 more inches coming Thursday..global warming?..what global warming? Jay |
Got mine done except for the installation of the struts. Mine look like they line up. Of course what eflite should have done was not even put holes on the wing. They should've left that up to the flyer to use a 1/16 inch drill. The struts are for looks anyways as they don't really do anything since there are 3 hinge points in each strut. I also had to drill a slightly larger hole for the wing hold down screws. They didn't quite line up with the holes for the mount. This way, I have a bit more room to juggle the screw to find the blind nut to hold the wing down.
As far as I can see, my wing wasn't warped. I also busted off the balsa tab for the vert stab to go into the slot. I hate the tab/slot into the fuse deal. This is the 2nd model I had this problem with. Its fixed and the tail looks straight to me. Gary, good mod on hatch door. I am also gonna use 2100's and its a batch to get a pack in there. And, how are you guys keeping on your wheel pants? A puny little wood screw is a poor way to keep it on. Especially those of us that fly off of grass runways. Sure you can put a drop of CA on there but I don't think its gonna hold up that long. I'm keeping mine off until I find a more sturdier way of doing it. Dave... |
Jay, my kid sister use to live in Maine, Hampden to be exact, just outside of Bangor. Summer was nice up there, all 6 days of it. She spent two winters there freezing her arse off in a 1780s farmhouse. She now lives in PA in a geo-thermal heated house.
It was 72 out at the field today. Once I retired in NY in 2000 we started looking for a warmer place to live. The west coast of Florida is where we settled and don't regret it one bit. I fly three days a week, every week. Plus I race sailboats on Tuesday afternoons. Man, ya gotta love retirement. Would like to see the T Craft on floats. I did lots of float flying in NY. Full scale and models. My buddy owned a seaplane base on the Hudson River and has a Champ, Cub, and Piper something on floats, plus his Ultralite. They were the good old days. Tom |
Hallowell, Maine
Joined Jan 2002
Hi Tom,
We have friends who live in Wildwood, Fl that we visit during the winter. We have visited a large club up in Ocala several times...great folks to visit. I have just started float flying this past year and have the Mini-Ultra Stick on floats (water and snow) and a Hanger 9 J-3 Cub that's about 8 years old. My father built some floats and never used them so I installed them on my Cub. Great fun after I got the the incedence between the wing and floats right. I've taken it to several ponds and float flys this past summer. My brother flies with the Skymasters club in michigan that hosts a huge regional float fly each September. |
| Thread Tools | |
| New Product E flite Taylorcraft for 450 or 480 | P-51C | Scale Electric Planes | 23 | May 23, 2009 05:11 AM |
| Discussion E-Flite park 450 outrunner, 980kV - suggested plane(s) or kits? | dougaustin | Power Systems | 4 | Jul 01, 2006 02:49 AM |
| Wanted E-Flite Park 450 Outrunner | Twmaster | Aircraft - Electric - Power Systems (FS/W) | 3 | Jun 17, 2006 11:41 AM |
| For Sale E-Flite Park 450 outrunner motor(3 days old) | wilsonbueno | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 01, 2006 10:10 PM |
| Question E-flite Park 450 vs Hacker A20-20L | Jimmy Hoffa | Power Systems | 2 | Dec 19, 2005 02:29 PM |
