Old Dec 16, 2007, 04:11 PM
service_dude is offline
Find More Posts by service_dude
service_dude's Avatar
Joined Feb 2006
Tom, I have 5 eflite planes in my fleet right now. I've probably owned 8. Out of the 8 planes, 2 had straight wings and the Taylorcraft is not one of them.
If your struts don't align you may want to look for a wing being warped.
service_dude is offline Find More Posts by service_dude
Old Dec 16, 2007, 04:23 PM
Tom Smith is offline
Find More Posts by Tom Smith
Rhinebeck CD-99,00,01,02
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
Wings are straight. I just put a trusty old 2500 mah lipo in her and she balances just fine. I added a few 1/4" strips of plywood down the length of the battery tray on either side. Stiffened it up nicely. What was there was rather flimsy. Wish they didn't cut those big holes in the battery floor. There is barely any surface to put the velcro on. If the winds are light tomorrow morning I will maiden her. Sure is a pretty little thing. Gonna look nice under the tree. Tom
Tom Smith is offline Find More Posts by Tom Smith
Old Dec 16, 2007, 04:28 PM
Ed Couch is offline
Find More Posts by Ed Couch
Ed Couch's Avatar
North Richland Hills, Texas USA
Joined Aug 2000
Tom
Check and see if the plastic sheet connectors on the struts have not come unglued. The balsa in the strut are simply sliced and the plastic (similar to a plastic hinge sheet) had slipped. Realigned and reglued to resolve problem. I thought at first that mine would require an extra hole be drilled but it only took a minute to resolve and things worked out perfectly from there. Everthing worked as advertised on mine.
ed
Ed Couch is offline Find More Posts by Ed Couch
Old Dec 16, 2007, 04:42 PM
Joined Feb 2006
I did the same, one thing I noticed is the grain of the ply of the battery tray is from side to side. Grain running in that direction just makes it weaker with the lighting holes.
The Funtana X is one of the best planes eflite has ever put out. It has a weak spot in the landing gear area from the lighting holes in the ply. Why they do this I have no clue.
Old Dec 16, 2007, 09:14 PM
Charley38 is offline
Find More Posts by Charley38
United States, TX, Kerrville
Joined Oct 2003
My two struts assemblies were exactly the same size, but did not line up with the pre drilled holes in the wing and fuse. Damm. This thing went together so well and the last step turns out to be a mess. Tom
OK, I snipped a lot. BUT, they should do better! Advert an ARF, deliver an ARF.
That said, it has come together beautifully. Now, if the weather will cooperate....
Cr
Charley38 is offline Find More Posts by Charley38
Old Dec 16, 2007, 09:42 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
I was under the impression that there should be some dihedral ? I believe there *might* be some straightening when the wing is in place and the bolts are tightened and this is what is causing the probs w/struts. Decided to check this now (mounted the wind) instead of after getting the RX and servo wiring completed. Sure enough...warped struts and mis-aligned holes. That's when I noticed the wing was now straight ! Might need to make some shims/tubes to go over the mounting nuts....will advise.
-Dave
Lonelasso is offline Find More Posts by Lonelasso
Old Dec 16, 2007, 10:13 PM
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
lasso, When I said my wings were straight, I did not mean straight across, I meant there were no warps or twists. There is a slight amound of dihedral in this model. Not very much, but a little bit. Sorry you may have miss understood me. Tom
Old Dec 17, 2007, 12:17 AM
Gerry B is offline
Find More Posts by Gerry B
Gerry B's Avatar
Surrey, BC, Canada
Joined Feb 2007
I just took the twist out of my wing tonight. The right was fine. Left was pretty twisted. It didn't take long to fix it.
I have an idea for the battery tray. I will post pictures in a couple of days when it's done.
Gerry B is offline Find More Posts by Gerry B
Old Dec 17, 2007, 07:40 AM
Lonelasso's Avatar
Joined Dec 2006
No biggy Tom Thx for the info !
-Dave
Old Dec 17, 2007, 08:52 AM
Joined Feb 2006
Same here, left wing was twisted. My struts fit fine after taking out the twist. Incidence meter does not lie.
Old Dec 17, 2007, 11:08 AM
Jaybird is offline
Find More Posts by Jaybird
Hallowell, Maine
Joined Jan 2002
A good thing to check with a meter. Mine had looked straight but my first flight showed a strong left bank tendancy and it took full right trim to get level flight. After straightening the left panel it flew great. I added a few more details including instrument panel, forward cabin bracing and profile pilot figure. I drew the door lines with a fine tip sharpie marker and the tail braces are nylon coated fishing line. Just about done I think.
Jay
Jaybird is offline Find More Posts by Jaybird
Old Dec 17, 2007, 01:22 PM
Dora Nine is online now
Find More Posts by Dora Nine
The sky is my playground.
Dora Nine's Avatar
United States, NH
Joined May 2005
You aren't the only one. I'm disapointed with both this plane and the T-6.
Dora Nine is online now Find More Posts by Dora Nine
Old Dec 17, 2007, 03:10 PM
Tom Smith's Avatar
New Bern, NC
Joined Mar 2001
Don't be disappointed. The people who assemble and cover these things have no idea what a wing warp is, or what it can do to a models ability to fly correctly. They are simply factory workers banging out one after the other, day after day, week after week. Always check an ARF's wings for warps. It's quite common to find them twisted. It just comes with the territory. They are built in a jig and straight as a poker, but then they are covered and shrunk by hand and warps will and do occur.
Mine didn't fly today. Too windy. Wednesay she will fly. Tom
Old Dec 17, 2007, 03:22 PM
Jaybird is offline
Hallowell, Maine
Joined Jan 2002
When you consider how lightly built these airframes are, it's amazing there aren't more twists. I remember the good old days when everyone complained about the sagging heavy weight covering coming off. The Taylorcraft is beautifully covered and know I couldn't do it any better. Luckily the light weight structure allows you to correct the problems. At least you guys are finding them on the work bench instead your maiden flight. It doesn't take much twist to make this little cutie a real bear in the air.
Jay
Old Dec 17, 2007, 06:36 PM
Gerry B is offline
Gerry B's Avatar
Surrey, BC, Canada
Joined Feb 2007
I am going to have to get one of the meters. I just eyed mine, should be close though.
Jaybird, all the detail you did is great. I am going to do mine like that, hope you dont mind . I had been thinking of adding the tail braces. Yours looks great. Did you just drill holes and run it all the way around? How is it fastened? I have added fine leather string around my windows for trim, it hides the ragged edges of the covering that are visable.
New Product E flite Taylorcraft for 450 or 480 P-51C Scale ARF/RTF 23 May 23, 2009 05:11 AM
Discussion E-Flite park 450 outrunner, 980kV - suggested plane(s) or kits? dougaustin Power Systems 4 Jul 01, 2006 02:49 AM
Wanted E-Flite Park 450 Outrunner Twmaster Aircraft - Electric - Power Systems (FS/W) 3 Jun 17, 2006 11:41 AM
For Sale E-Flite Park 450 outrunner motor(3 days old) wilsonbueno Aircraft - Electric - Power Systems (FS/W) 3 Mar 01, 2006 10:10 PM
Question E-flite Park 450 vs Hacker A20-20L Jimmy Hoffa Power Systems 2 Dec 19, 2005 02:29 PM
