Old Nov 30, 2012, 07:46 PM
SkyPirate67 is offline
Find More Posts by SkyPirate67
Break, fix, fly, break again
SkyPirate67's Avatar
United States, PA, Royersford
Joined Apr 2012
Originally Posted by KTL13 View Post
SkyPirate, from one TC owner to another I just wanted to give a few tips I learned along the way, it wasnt long ago that I recieved this plane as a gift and I was looking for the same sort of answers. This was also my 2nd plane after the HZ SuperCub.
-For whatever reason MY plane needed a of trim, all the surfaces were pefectly lined up when I built it and wow was it ever untrimmed when I maidened it. I think it might be due to the wing or horizontal stab being warped or perhaps it was epoxied on with a slight twist. So do a once over on the plane and check that out. You cant really correct it before the flight but if you get a wonky maiden youll know why. On my maiden I quickly learned how untrimmed it was on takeoff, it was almost unflyable plus it was a bit tail heavy too. So get good at trimming on the fly! You may never need that skill but its a great skill to have. All my flying buddies get me to trim their planes now. Back to the plane - once I got it trimmed out all was well.
-Be 100% sure about your CG point. Unfortunatley putting the battery in and out of this plane is complete pain but do your homework and youll be rewarded.
-Watch out for the tip stall tendenices on this plane too, it has been rumoured to tip stall quite easily. I keep my speed up to avoid this, ive experienced this a few misakes high so I know how to avoid it now.
-You likely already know this but when you turn you gotta come out of a turn "unturning" so to speak. It is nothing like the SuperCub, it will not correct itself at all. If you leave it banked it will stay banked. I didnt think it would be that different....but it is. But once you get used to it its very simple. Also dont be shy about using lower rates and some expo. On my dx6i for low rates I have 70% rate and 15% expo. Dont be shy to even use 30% expo. Youll find its twitchy in comparison to the supercub but youll adjust in seconds....just insure yourself for the first few seconds! LOL. I have a 480 in mine and this plane is by far my most aerobatic of all my planes, except my 3D plane. Not only does it zip along really nicely but it can loop and roll like crazy. I love doing outside loops and 1/2 cuban 8s, this plane is just so unasumming and is really overpowered in the air..... I just love it. I have my TC on skiis at the moment and taking off and landing on skiis is just so much fun. And on a side note to your corsair, my 3rd plane was a PZ P47. I maidened it about 4-5 flights after my TC maiden and I gotta say once you can fly the TC youll find the warbird slower, less aerobatic and dare I say easier to fly. Congrats and good luck with your TC!!!!
I just finished tightening a rather "loose and lumpy" 80" Canadair. It came absolutely wrinkled beyond belief. I bought both an iron and a heat gun and I found that its best to take an iron and do the edges first then take the heat gun and slowly apply heat to the area....works like MAGIC. I found the iron took too long compared to the gun for the other open larger parts of the plane, the gun works within seconds. Make big swooping circles and it will tighten in all directions equally. I also have my TC with some wrinkles that I am planning on fixing.
Wow! That is alot to take in but I am! I appreciate the tips and help. I will use yourr technique on tighting the sheeting. Makes alot of sense. Also, I am learning how important cg and proper alignment and trimming is. I have done the alignments and found I had to still trim once I fly. I usually land and check/make adjustments then fly again. I have been forcing myself to trim in the air lately though. I think it will make me a better flyer for it and I think I am making more accurate adjustments this way. I am getting into checking wattage, amps etc. to make sure I have good setups and parts arent failing...even on my super cub since she has been flown so much I did a xomplete workup. Good practice for me. Again thanks!
SkyPirate67 is offline Find More Posts by SkyPirate67
Old Dec 02, 2012, 10:50 AM
Fredriksson is offline
Find More Posts by Fredriksson
Just having fun
Fredriksson's Avatar
United States, KY, Hopkinsville
Joined Feb 2008
Also, when using the heat gun, be careful of anything plastic. When I first built my TC I melted/deformed the window in the top of the wing by getting a little bit too much heat on it. Luckily, E-Flite has the windows available as spare parts so I replaced that top window.
Freddy
Fredriksson is offline Find More Posts by Fredriksson
Old Dec 02, 2012, 11:17 AM
fogflyer is offline
Find More Posts by fogflyer
Northern California
Joined Sep 2002
Originally Posted by Charley38 View Post
Usually wheels develop flat spots because of sitting in one place for extended periods of time. I hang my models up. How do you store your TC?
CR
My flat spots were definitely from landing as the plane was brand new and hadn't been sitting on its gear. However, I just went and looked at the plane which has been sitting on its wheels for the last week. Holy crap! Now that is a flat spot! I guess I will have to hang it. My other planes are so light I never had this problem before, but my poor TC has huge flat spots from sitting now. Hopefully the will go away.
What is the best way to hang a model?
fogflyer is offline Find More Posts by fogflyer
Old Dec 02, 2012, 09:37 PM
Joined Apr 2012
Freddy
Thanks Freddy. I like the fact that I can get parts pretty easily. Makes me less fearful.
Old Dec 09, 2012, 03:22 PM
Mendo is offline
Find More Posts by Mendo
Mendo's Avatar
United States, CA, Ukiah
Joined Dec 2011
Broke the motor box and firewall today doing a rather vigerous lomcevak...Shortened my flying day a fair bit. Tonight I will dig into it and see what the extent of damage is and fix it up for flying in the morning. One of my absolute favorites that almost always makes it in the truck...Might be time to buy a spare, I have been pretty hard on the airframe doing aerobatics and its starting to remind me that it just wants to shoot touch and goes......
Mendo
Mendo is offline Find More Posts by Mendo
Old Dec 09, 2012, 10:14 PM
GCplane is offline
Find More Posts by GCplane
GCplane's Avatar
Manassas, Virginia
Joined May 2008
I did an aileron roll with my floats on. I was a little scared to try it, but the plane flew fine.
GCplane is offline Find More Posts by GCplane
Old Dec 10, 2012, 06:37 AM
CyberJay is offline
Find More Posts by CyberJay
Rsetiegerd Uesr
CyberJay's Avatar
USA, AR, Cave Springs
Joined Apr 2005
Mendo
Further back in this thread that's been discussed. Pretty common. One of the few "mods" I would do before flying this plane is to flow CA over the joints between the motor box and firewall. But even after doing that I've still had it pop off. Once it's off and you can get glue down in the joint it is easier to re-glue it. Hopefully you don't have too much cowl damage.
-Jay
CyberJay is offline Find More Posts by CyberJay
Old Dec 10, 2012, 09:45 AM
Mendo is offline
Mendo's Avatar
Joined Dec 2011
-Jay
Oh yea, when I assembled it many many flights ago I went over every single glue joint I could weasel thin ca into, braced the cabin all around with carbon fiber, as well as the battery tray. Then soaked the motor box, firewall, and battery tray with thin ca. I have had to re glue a few random places here and there as the flights and abuse added up. Mine is just a case of high energy aerobatics that alot of airframes dont tolerate for long ( and in the t crafts case its not anywhere near up to all the g's stock ) The cowl wasnt damaged at all as I noticed it within a few seconds of it letting go, and it was given a thorough inspection and repair last night. Plan on flying this morning, Ill try to remember to turn on my hatcam instead of just bringing it and hopefully have a vid or two for folks to laugh and/or cringe watching and waiting for the catastrophic structural failure that seems imminent! There may be some knife edge madness between lomecevacs if its back to normal....Maybe a very non scale hover to mortify or delight...
Now that I spoke up Ill probably re kit it lol.
Mendo
Old Dec 10, 2012, 12:34 PM
deckert is offline
Find More Posts by deckert
Plowin Dirt
deckert's Avatar
USA, WA, Benton City
Joined Oct 2007
Usually you have to get a jury together of 12 peers before anything can happen. After the conviction, any good tree limb should work.
Dan
deckert is offline Find More Posts by deckert
Old Dec 10, 2012, 06:12 PM
Mendo is offline
Mendo's Avatar
Joined Dec 2011
Well, no videos...Was windy and soggy at the field all morning. Tcraft is all fixed and I put a couple very bumpy flights up to see if anything would come loose, nothing did thankfully and it went back in the truck. Oh well..
Mendo
Old Dec 10, 2012, 10:05 PM
GCplane is offline
GCplane's Avatar
Manassas, Virginia
Joined May 2008
Here is how I hang my models
Old Dec 13, 2012, 01:39 AM
sleepyfish is offline
Find More Posts by sleepyfish
sleepyfish's Avatar
Canada, BC, Madeira Park
Joined Mar 2012
wall hangers 1x4 down, 1x2 across bottom, 3/4" pvc covered with foam water pipe insulation or round (pool noodles)
sleepyfish is offline Find More Posts by sleepyfish
Old Dec 13, 2012, 01:46 PM
Just having fun
Joined Feb 2008
Where's the TC? Must be at the place of honor in the lining room or master bedroom.
Freddy
Old Dec 26, 2012, 06:21 AM
Wobisch is offline
Find More Posts by Wobisch
fortuna favet fortibus
Wobisch's Avatar
Schweiz, AG, Merenschwand
Joined Oct 2011
Maiden Flight Taylorcraft 450
Had some good first flights with my brand new Taylorcraft 450. This Aircraft seems to be a very good trainer for my son. Very easy to start, fly and land. I did not reach the battery end so far. Incredible flight time with the 480 Brushless and 2200 Battery.
E-flite Taylorcraft (1 min 23 sec)
Wobisch is offline Find More Posts by Wobisch
Old Dec 26, 2012, 11:47 PM
overthebars is offline
Find More Posts by overthebars
overthebars's Avatar
meridian, idaho
Joined Mar 2010
Great video!
I am stoked........ just ordered this plane today. I've got a hanger full of war birds and really miss the ability of having a nice, mellow, scale flyer to enjoy now and again. I learned to fly with the HobbyZone SuperCub, and there is just something about this TaylorCraft that makes me want it NOW.
I'm going to buy the Park 480, E-Flite 40 amp pro switch-mode BEC, and Hitec 65HB servos over the next couple of months and have her ready to maiden by the time the snow melts.
overthebars is offline Find More Posts by overthebars
New Product E flite Taylorcraft for 450 or 480 P-51C Scale ARF/RTF 23 May 23, 2009 05:11 AM
Discussion E-Flite park 450 outrunner, 980kV - suggested plane(s) or kits? dougaustin Power Systems 4 Jul 01, 2006 02:49 AM
Wanted E-Flite Park 450 Outrunner Twmaster Aircraft - Electric - Power Systems (FS/W) 3 Jun 17, 2006 11:41 AM
For Sale E-Flite Park 450 outrunner motor(3 days old) wilsonbueno Aircraft - Electric - Power Systems (FS/W) 3 Mar 01, 2006 10:10 PM
Question E-flite Park 450 vs Hacker A20-20L Jimmy Hoffa Power Systems 2 Dec 19, 2005 02:29 PM
