Old Sep 24, 2012, 05:29 PM
Hit N Run is offline
Find More Posts by Hit N Run
Fly it low.. and fly it fast!
Hit N Run's Avatar
United States, MA, Westport
Joined Nov 2011
Originally Posted by RC Man View Post
I am getting ready to buy one who has some good deals?
I'm right behind you! I need a replacement airframe. My current TC has.. well.... "seen better days".
Hit N Run is offline Find More Posts by Hit N Run
Old Sep 30, 2012, 03:40 PM
GCplane is offline
Find More Posts by GCplane
GCplane's Avatar
Manassas, Virginia
Joined May 2008
On my maiden float flight (video a few posts back), I could not taxi downwind with the Taylorcraft without a water rudder. I built a water rudder from scratch. I used a Hanger 9 giant scale aileron hinge. I got a sheet of plastic and cut out a rudder shape. I epoxied on a 4 way servo arm and the hinge. I first drilled #60 size holes and tied the items with heavy duty cotton thread from a sewing store.
I soaked the epoxy into the thread for a strong bond. I used a T-pin for a hinge pin. The floats are sitting in a Styrofoam holder (not part of the float). I painted the rudder and a couple pieces of the homemade cable mount bracket with rust-oleum paint. As you can see it is almost a perfect match.
GCplane is offline Find More Posts by GCplane
Old Sep 30, 2012, 07:19 PM
motoman97 is offline
Find More Posts by motoman97
Fly low and slow ?
motoman97's Avatar
Canada, AB, Calgary
Joined Oct 2007
This looks pro
motoman97 is offline Find More Posts by motoman97
Old Oct 01, 2012, 01:04 AM
prmiller10 is offline
Find More Posts by prmiller10
prm10
Houston, Texas
Joined Aug 2010
480 Motor Rattling? HELP!
I was installing the Park 480 1020Kv motor on to my TC. As I was screwing on the motor the right front side of the motor box started to peel or crack off from the rest of the box. I was not sure what to do but being the somewhat of a newbie I started CAing the out of the motor box and that one particular spot trying to make it fit back together. It is still slightly displaced but I maidened anyways and it did not fly quite as easily as most of everyone else's on this thread. I'm still trying to read through this forever long thread but so far have not found anything like this.
Another issue which might have resulted from above is when I get up to about 3/4 throttle the plane has a pretty significant rattle to her which creates a lot of vibration throughout the entire plane. Although I did not get quite to 3/4 throttle it is still concerning to me and would like to know the possible causes of this rattling.
Please help this is starting to become my favorite plane I just need some guidance before I have the confidence to put her back up again.
prmiller10 is offline Find More Posts by prmiller10
Old Oct 01, 2012, 06:51 AM
GCplane is offline
GCplane's Avatar
Manassas, Virginia
Joined May 2008
Put a bead of Gorilla Glue along the inside corners of the box and into that crack. I used a tooth pick to apply the glue. Check your propeller balance.
Old Oct 01, 2012, 02:55 PM
Magic k2 is offline
Find More Posts by Magic k2
Things that do fly
Magic k2's Avatar
In my house ;-) The uk
Joined Dec 2008
Its an arf,,i would soak every joint i could reach with cyno as they are not that fussy at the factory,you can get long tips for the cyno bottles or dip wire into the glue and then it will run down the wire onto the joints,,i would cyno that motor box inside and out or it will work loose dude
Magic k2 is offline Find More Posts by Magic k2
Old Oct 07, 2012, 05:09 PM
dinopilot is offline
Find More Posts by dinopilot
dinopilot's Avatar
United States, SC
Joined Sep 2010
Eflite Taylor Craft Maiden (4 min 14 sec)
My maiden
dinopilot is offline Find More Posts by dinopilot
Old Oct 09, 2012, 10:54 AM
ty_horn is offline
Find More Posts by ty_horn
Philippians 4:13
Seward, NE
Joined Nov 2006
hey dino.
It looked like your control surfaces were pretty touchy! Mine were the same on maiden... I programmed in some expo and all is good now!
ty_horn is offline Find More Posts by ty_horn
Old Oct 09, 2012, 02:57 PM
Magic k2 is offline
Things that do fly
Magic k2's Avatar
Joined Dec 2008
Originally Posted by ty_horn View Post
hey dino.
Ye i go for full throws and then soften up the sticks with expo ; )
Old Oct 09, 2012, 05:04 PM
dinopilot's Avatar
United States, SC
Joined Sep 2010
Yea i got it sorted out. I'm less aggressive on the sticks and now I'm doing some scale flights lol.
Old Oct 21, 2012, 08:22 AM
GCplane is offline
GCplane's Avatar
Manassas, Virginia
Joined May 2008
My scratch built rudder worked very nice. Notice how it turns nicely while taxiing. It also takes off and lands nicely. Here is the proof. (A rudder photo is a few posts back). I could not turn at will on the maiden flight before I put on the rudder.
Taylorcraft Float Flight (2 min 4 sec)
Old Oct 21, 2012, 04:10 PM
racer7696 is offline
Find More Posts by racer7696
Joined Oct 2009
Taylorcraft on 27" floats wont take off
Hey guys just tried to maiden my tcraft and I could not get it to come up out of the water.I am useing 27 inch balsa floats .I have the balance point of the wing about an inch forward of the step of the floats .from the prop to the begining of the floats there is approx 6 inch of float .The only thing I can think of is that somehow it is to far back on the floats.When its in the water it sits pretty level maybe a little tilted back.I wasnt able to take any pics but I will try to tomorrow.Any ideas would be appreieated.I am useing the 480 motor with the 12-6 prop so power should not be the issue
racer7696 is offline Find More Posts by racer7696
Old Oct 21, 2012, 06:31 PM
GCplane is offline
GCplane's Avatar
Manassas, Virginia
Joined May 2008
I am also using a 480 motor in the videos that I posted with an 11x5.5 APC prop. Most likely the wing angle is wrong. When it is sitting in the water the front center of the leading edge of the wing should be about 7/16 inch higher than the center of the trailing edge. Put little blocks under the front legs to raise the nose. I hold a fair amount of up elevator as I increase speed.
When the plane breaks from the water I relax the elevator. Weight is another possibility. My floats are only about 7 oz for both floats and the struts all together. Next time I get my plane down from the ceiling where it is hanging I will try to remember to weigh it again now that I am all done (except I want to add some stripes on the floats.)
Old Oct 21, 2012, 06:58 PM
Cub Fan is offline
Find More Posts by Cub Fan
Balsa just crashes better
Cub Fan's Avatar
Bradenton, FL
Joined Nov 2004
if the water has no ripples it also creats a suction that sticks the plane to the water and you also have less lift with no breeze.- but as GC pointed out you need to have the angle the plane sits on the floats correct or it can create a problem lifting off.
Jay
Cub Fan is offline Find More Posts by Cub Fan
Old Oct 22, 2012, 03:50 PM
Magic k2 is offline
Things that do fly
Magic k2's Avatar
Joined Dec 2008
https://vimeo.com/51848756
Sweet landing dude ;0)
New Product E flite Taylorcraft for 450 or 480 P-51C Scale ARF/RTF 23 May 23, 2009 05:11 AM
Discussion E-Flite park 450 outrunner, 980kV - suggested plane(s) or kits? dougaustin Power Systems 4 Jul 01, 2006 02:49 AM
Wanted E-Flite Park 450 Outrunner Twmaster Aircraft - Electric - Power Systems (FS/W) 3 Jun 17, 2006 11:41 AM
For Sale E-Flite Park 450 outrunner motor(3 days old) wilsonbueno Aircraft - Electric - Power Systems (FS/W) 3 Mar 01, 2006 10:10 PM
Question E-flite Park 450 vs Hacker A20-20L Jimmy Hoffa Power Systems 2 Dec 19, 2005 02:29 PM
