Tucson, AZ
Joined Oct 2008
The Trojan is a bit better in the wind. The T-Craft is really sensitive to crosswinds, and handling them requires a bit of finesse that isn't needed with the Trojan. |
One thing the Taylorcraft will teach you is use of the rudder. Don't just slam the throttle open and never touch the rudder during flight. The Taylorcraft, like its full sized counterpart, likes you to use the rudder. A little cross control in a cross wind will keep things going correctly. It also does a wonderful side-slip to kill altitude.
Gary |
rudder
Stan
United States, CA, Santa Maria
Joined Dec 2006
Cool, I have actually erally learned to use the rudder in flying my 3D stuff. Rudder is really necessary so i am comfortable with it's use for scale too. My Multiplex twinstar is very fond of rudder use too. sounds like this is steady though. should have it up hopefully by next week.
Joined Jan 2007
Just maidened my TC. Went by the book on the CG and it was way nose heavy.
Trimed it up a lot while flying and it flew great. I have the bigger motor in it and it climbs great. Since I'm a "heli" guy and under 60, all the plank guys at my club went nuts when they saw me with this bird. Everyone said it was to "pretty" to fly LOL. I took your guys advice and cut out the battery door to get the battery in, reinforced the motor mount and wood around the wheel supports. I also made a "tray" to hold the battery in place side to side. Can't wait to fly again but the wind is over 20.. Cheers, and thanks for the help |
Daniel,
Don't cut out the bottom of the fuselage. Use your Dremel tool and notch between the two magnets on the ply cross brace at the rear where the hatch sits. Somewhere way back in this thread I showed a picture of how I did that. I can get big fat 2200 GForce lipos in mine with no problem. Hacking up the bottom of the plane is not necessary. Gary |
http://www.rcgroups.com/forums/showp...&postcount=696 |
Joined Jan 2007
Daniel,
I cut out the door support just like the pic that cyberjay attached. Sorry it sounded like I cut the door. I also made a balsa "tray" that is glued under the seat to hold the battery in left to right. I like to fly acrobatic so I felt the strap and velcro was wimpy.. Cheers, Steve |
CyberJay,
Thank you. You found the post before I did. It was awhile back... Daniel, Note the black velcro on the bottom of the battery tray and the hold down strap. Plenty of lipo holding power. I do snaps, outside loops and inverted spins with mine and have never had a lipo come loose. Gary |
Great thread
Thanks for all the good info on here. This thread is getting as good as "that big one" Stan |
| Thread Tools | |
| New Product E flite Taylorcraft for 450 or 480 | P-51C | Scale Electric Planes | 23 | May 23, 2009 05:11 AM |
| Discussion E-Flite park 450 outrunner, 980kV - suggested plane(s) or kits? | dougaustin | Power Systems | 4 | Jul 01, 2006 02:49 AM |
| Wanted E-Flite Park 450 Outrunner | Twmaster | Aircraft - Electric - Power Systems (FS/W) | 3 | Jun 17, 2006 11:41 AM |
| For Sale E-Flite Park 450 outrunner motor(3 days old) | wilsonbueno | Aircraft - Electric - Power Systems (FS/W) | 3 | Mar 01, 2006 10:10 PM |
| Question E-flite Park 450 vs Hacker A20-20L | Jimmy Hoffa | Power Systems | 2 | Dec 19, 2005 02:29 PM |
