Old Mar 24, 2008, 07:24 AM
Jim Young is offline
Find More Posts by Jim Young
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
NexStar Battery Packs
Hi,
The NexStar comes wired for two power battery packs. You either need two 8 cell NiCd/Nmhd (9.6V) or one 3S and one 2S (Total of 5S) LiPo packs. There are two Dean's Ultra connectors wired in the NexStar and you just plug one pack into each and you're ready to fly.
There is a separate receiver pack that powers the receiver that is included with the package. What you need to remember is to check your receiver battery with an expanded scale volt meter(has a load built in) or with a regular voltage meter with some kind of load( ~20 Ohms will draw 250mA). A fully charged 4 cell pack should read 4.8V. Anything less than 4.4V under load you should think about re-charging.
-Jim
Jim Young is offline Find More Posts by Jim Young
Old Mar 26, 2008, 09:39 PM
AeroWolff is offline
Find More Posts by AeroWolff
United States, ID, Post Falls
Joined Mar 2008
Nexstar qeustions
I have some qeustions about the Nextstar Select EP. Just got a new one, and new to thr RC flying. Hope to learn from some experienced flers. I did post a qeustion under the general airplanes thread in hopes to find a answer about the offset motor mount. Hope to hear from the experienced.
I'll need help with the forums also I'm new to this. Thanks for you patience.
AeroWolff is offline Find More Posts by AeroWolff
Old Mar 27, 2008, 05:46 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Hi AW,
If you are talking about the motor/propeller being offset to the right, this is called right thrust. This help correct the "p-factor" which is due to the swirling air coming off the prop that tries to yaw the plane to the left. This is most noticeable when the accelerating and lots of planes have some right thrust or right rudder built in to help correct of this.
Is this what you are talking about?
-Jim
Old Mar 27, 2008, 08:26 AM
Joined Mar 2008
Yes. I was wondering why! I'm new to rc planes. Bought this bird and a Hobby Zone super cub to start out with. Thanks much. Dan
Old Mar 28, 2008, 08:30 PM
Elyranger is offline
Find More Posts by Elyranger
North Country Flyer
Elyranger's Avatar
Minnesota
Joined Mar 2008
NiCd/Nmhd or LiPo
I just purchased the Nexstar but haven't purchased the battery or charger. My question is, what is the best way to go, NiCd/Nmhd or one 3S and one 2S (Total of 5S) LiPo packs.
Elyranger is offline Find More Posts by Elyranger
Old Mar 29, 2008, 08:00 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
As far as batteries go, I think it is a question of your experience. LiPos will provide better performance, but they need special care and handling. Do some research so you know what your are getting into. If you go with LiPos make sure to get a good balancing charger and something to charge them in (e.g., Liposack, etc..). Nicd/Nmhd are more forgiving of rough handling and may be better suited for people new to electric flight.
-Jim
Old Mar 29, 2008, 06:39 PM
North Country Flyer
Elyranger's Avatar
Minnesota
Joined Mar 2008
Liposack
Thanks Jim I appreciate the information.
Old Mar 29, 2008, 07:24 PM
Stephen M is offline
Find More Posts by Stephen M
Stephen M's Avatar
Canada, ON, Georgina
Joined Apr 2001
Jim
What is your opinion of the A123 cells? I too am nervous about LiPos and their durability with respect to physical durability. I have a lot of NiCad experience so soldering up cells is not an issue. Figure they may have the pros of NiCad/NiMH as far as handling goes.
Stephen
Stephen M is offline Find More Posts by Stephen M
Old Mar 30, 2008, 09:12 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Hi Stephan,
I think the A123 cells would be a worth a look for this plane. I don't have any first hand experience with these cells yet, so I can't give any specific recommendations. But they appear to be more tolerant of rough handling so they may be a better choice for a beginner.
-Jim
Old Apr 04, 2008, 07:51 AM
ASAMech is offline
Find More Posts by ASAMech
Flying Electric!
United States, MI, Westland
Joined Jul 2006
Im getting ready to maiden, just one question, i have a 10x5 with 2 4s TP Extreme 2200mah in parallel. What kind of time should i start with and will this setup draw too much? (Jeti 70Amp ECS)
ASAMech is offline Find More Posts by ASAMech
Old Apr 05, 2008, 08:26 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Hi,
You should be drawing less current than the recommended setup (4s vs 5S). Because of this, you will need a higher throttle setting to maintain flight. I would strongly recommend that you invest in a Wattmeter (AstroFlight or other brand) so you know what current draw you actually have. As far as duration, I would recommend a 5 minute flight, and then monitor how many W/hr you put back in your packs. If you put back 2A/hrs, then you know that 10minutes is your max flight time.
Best of luck,
-Jim
Old May 01, 2008, 09:06 AM
aevazy is offline
Find More Posts by aevazy
Joined Apr 2008
what lipo batter do i need for nexstar ep? and how many?
aevazy is offline Find More Posts by aevazy
Old May 02, 2008, 05:49 AM
Designer/Builder
Jim Young's Avatar
Brighton, MI USA
Joined Jun 2000
Please read post #61.
-Jim
Old May 07, 2008, 11:56 AM
FUP is offline
FUP
Find More Posts by FUP
FUP
Joined May 2008
I just picked up the NexStar EP to learn on, but in playing around with the transmitter, reset the throw limits. I'm sure I'll be able to sort them out, but can anyone tell me what they had been set to from the factory?
FUP is offline Find More Posts by FUP
Old May 12, 2008, 11:48 AM
stuttgartpilot is offline
Find More Posts by stuttgartpilot
Joined Mar 2008
Battery Installation
Could someone please help me with the battery installation. The book does not cover it completely and the picture is no good. What are you supposed to do with the velcro strips and with the wood piece that comes with it?
stuttgartpilot is offline Find More Posts by stuttgartpilot
Hobbico SuperStar EP Select RTF w/Ailerons Newby Kyonic Beginner Training Area (Aircraft-Electric) 8 Aug 20, 2008 12:42 PM
For Sale NEW Hobbico SuperStar EP 4ch RTF w/Ailerons NEVER FLOWN!! plus Brand New Upgrades Bmr4life Aircraft - Electric - Airplanes (FS/W) 11 Aug 07, 2006 10:06 AM
Increasing flight time on a Hobbico SuperStar EP Select Plane AMarkIII Electric Plane Talk 2 May 18, 2005 07:48 PM
Hobbico superstar EP select is a winner tic Beginner Training Area (Aircraft-Electric) 8 Nov 13, 2003 02:05 PM
