Mar 04, 2008, 05:50 AM
Brighton, MI USA
Joined Jun 2000
If your are using Nimh, they do best hot off the charger. So, there is not much use in charging them at home. Or at lest you should top them off at the field.
The PA-2 on mine came all set up with the gain control on the channel 6 knob, although the manual walks you through the procedure to set this up. Since it was on this control knob, the gain could be set any where. I used the first flight to try dial in the setting that worked best. I would suggest that you have your instructor trim out the NexStar and set the gain on the PA-2. Them mark your transmitter and mark this part of your pre-flight checklist.
-Jim
