Old Jan 16, 2008, 06:08 AM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Mitja,
Can you post the plan untiled so that it is all on one page?
thank you
Mark
kram242 is offline Find More Posts by kram242
Old Jan 16, 2008, 07:40 AM
ultralajt is offline
Find More Posts by ultralajt
ultralajt's Avatar
Ljubljana Brnik, Slovenia
Joined Sep 2004
Originally Posted by kram242
Mitja,
thank you
Mark
Yes! Here it is!
Mitja
ultralajt is offline Find More Posts by ultralajt
Old Jan 16, 2008, 08:16 AM
kram242 is offline
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Thanks!!!
Old Jan 17, 2008, 05:00 AM
ultralajt's Avatar
Joined Sep 2004
There are already some ULTRON`s build by this set of plans, that I publish in megazine (previously mentioned TIM Magazine), so here are some pictures:
http://forum.modelarji.com/datoteke/...800600_111.jpg
http://forum.modelarji.com/datoteke/img070_195.jpg
http://forum.modelarji.com/datoteke/rajko2_191.jpg
http://forum.modelarji.com/datoteke/robi3_884.jpg
http://forum.modelarji.com/datoteke/...7_2229_157.jpg
Old Jan 22, 2008, 08:52 PM
aleXtino is offline
Find More Posts by aleXtino
dumbthumb
aleXtino's Avatar
World's Ass - Chile
Joined Dec 2004
Ive started to build an Ultron. I picked coroplast 3mm (6mm for A&R) instead of depron, just because I got it at hand. Ive done another 3D before with depron (RIP); Id never work bf with coro, lot to learn.
Ill try to figure out one servo wing; I started to think on it since my gws pico rx its only 4 ch. Anyway, I dont see why 2 servo wings on a 3D, if any can explain maybe Im missing something... More power..?
Pics soon.
aleXtino is offline Find More Posts by aleXtino
Old Jan 23, 2008, 01:33 AM
ultralajt's Avatar
Joined Sep 2004
Pics soon.
As first, I must tell you that This model if build from Coroplast will never fly well as 3D aerobat. It will be simply to heavy to perform well and at low flying speeds. Also, you can kiss godbye the howering ability.
But if you prefer faster flying and "conventional" aerobatics, then it will be good, but you must keep contrill throws inside reasonable values. (lower that for 3D aerobatics)
regarding 2 servos in the wing, there are here because you can use mixing ability of your RC transmitter, and simultaneously rise or lower both ailerons in some aerobatic figures. Raising both ailerons simultaneously, can somethimes help to perform stabiler harrier for instance...
Best wishes for building of your Ultron. Pleas post some photos of your progress.
Mitja
Old Jan 27, 2008, 01:29 AM
ultralajt's Avatar
Joined Sep 2004
Couple of last days was really nice for flying, so I made some flights with my Ultron and open my 2008 fligt season!
Here is a VIDEO:
Relaxing flying (9 min 59 sec)
I am still a bit rusty, but I hope that some further practising will make me fly better.
Regards!
Mitja
Old Jan 28, 2008, 08:59 PM
7ECflyer is offline
Find More Posts by 7ECflyer
Joined Jul 2004
I love the model. You mentioned early in the thread that you were working on a builder's manual. Is that available?
7ECflyer is offline Find More Posts by 7ECflyer
Old Jan 31, 2008, 05:16 AM
ultralajt's Avatar
Joined Sep 2004
Sorry, not yet. Lack of spare time dont allow me at this moment to make it.
But there is no hard thing that one cant do.
So shortly:
It is basically like other common foammies.
The main diffenernce at Ultron is that wings are joined by a wing joiner made from 6 mm depron, capped with a carbon strip top&bottom, to achieve proper bending strength. At assembly, wing halves are joined permanently using glue.
For bending wing skin, I tape a decorative self adhesifve tape on the profile nose area, prior bending it.
At line of the sharp nose profile bend, i use razor knife to cut shallow V groove on the inside side of depron. This allow depron to bend sharp over the airfoil nose without breaking.
First third of wing skin is bended and I bend it using a piece of aluminum tube, and press&roll it over inside side of depron. Wgen depron gets allmost proper curvature, the bending is finished.
ESC and reciever are attached to the model with self adhesive tape, but battery is attached with Velcro tape, to be removable.
I made pull pull controlls for the elevator and ruder. I use common thread and after setting proper length and tension, I drag a drop of CA glue over threads to harden pull pull system in order not to streech under tension.
The ailerons controlls are done by bending a 1 mm thick steel wire in Z manner both ends and connect them with servo horn and aileron horn.
Controll surfaces horns can be made from CD plate material, thin plywood, expired credit card material, or phenolic plate...
Mitja
Old Apr 04, 2008, 02:36 AM
RJPIoW is offline
Find More Posts by RJPIoW
Parkesflyer
RJPIoW's Avatar
United Kingdom, Ryde
Joined May 2006
Mitja - I built a Katana using a built up thick section wing very similar to your Ultron concept. I was not convinced that the aerofoil section was any better than a flat plate wing - it was heavier because of the ineternals and lots of glue. I think that at Reynolds numbers lower than 100,000 a flat plate is actually better.
have you read:
http://jef.raskincenter.org/published/airfoil.html
... an interesting article that made me consider changing some old design principals
I am currently building an EPP version of your Ultron with a 6mm EPP flat wing and tailplane, and 3mm EPP fusalage sides. I have worked out that it will weigh 9oz with a 45gm motor which will give a wing loading of 3oz/sqft.
I am hoping that this combination with your very large moving surfaces will provide a great 3D machine. Your design looks great - I will let you know how my EPP version flies
Richard
RJPIoW is offline Find More Posts by RJPIoW
Old Apr 06, 2008, 01:07 AM
RJPIoW is offline
Parkesflyer
RJPIoW's Avatar
Joined May 2006
c of g
Mitja - if the assembly sketch is 1/5 scale then I calculate that you have your centre of gravity 84mm behind the leading edge of the wing - is this correct ?
For 10% static margin I calculate that it should be 101mm from the root leading edge which would improve its 3D capability - you have been flying it what do you think ?
Richard
Old May 25, 2008, 02:01 PM
geoffroy is offline
Find More Posts by geoffroy
Joined Apr 2008
Hi Mitja and all,
After the gupy, here is my Ultron. I'm clearly not a 3D specialist. However, I can say that the general flying characteristics of this plane are very good! The plane can fly very slowly even if mine is heavy (460g). The command are powerful and the rolling speed is crazy.
Battery : LiPo 11,1V - 1450 mAh - 25C (135g)
Motor : Hype E-Motor Alpha AL28/1250M (58g)
Propeller : 9 x 4
controller : Castel Creations Thunderbirds 18A (17g)
Receiver : R16SCAN (17g)
Servos : Hitec HR55 (9g)
total weight: 460g.
Once again, many thanks for sharing your plans.
more details on my website
geoffroy is offline Find More Posts by geoffroy
Old Jun 11, 2008, 12:04 AM
uniquexme is offline
Find More Posts by uniquexme
hobby-asia.com
uniquexme's Avatar
Malaysia
Joined Apr 2006
i m building it real soon. thanks for the plane.
can show me some idea on how to install the landing wheel?
uniquexme is offline Find More Posts by uniquexme
Old Jun 24, 2008, 09:49 AM
geoffroy is offline
Joined Apr 2008
Ultron with on-board camera
Here are some pictures of my Ultron with an on board camera.
Ultron: electric 3D RC plane in Belgium (4 min 30 sec)
For more details:
http://www.lumay.be/index.php?mainMe...project=Ultron
Old Jun 26, 2008, 05:58 AM
tann200 is offline
Find More Posts by tann200
Estonia
Joined Sep 2005
Thanks for the plans, very nice design indeed.
tann200 is offline Find More Posts by tann200
Please help: Buying my first 3D plane Allan_A 3D Flying 18 Jan 26, 2009 12:39 AM
My first 3D depron plane - UltraMicro LieRaider Lynxman 3D Flying 15 Nov 10, 2004 08:21 PM
Question Help with my first built-up model Gerdawr Free Flight 18 Oct 23, 2004 08:16 PM
My first foamy - Fancyfoam model Buckey29 Foamies (Kits) 1 Jul 25, 2004 10:26 AM
Yippee! finished my first 3d plane! nub111 3D Flying 8 Jul 19, 2004 07:33 AM
