Old Sep 24, 2007, 05:48 PM
red-panda is offline
Find More Posts by red-panda
red-panda's Avatar
Vancouver, BC
Joined Aug 2004
Walkera 4#3 mods
I thought I'd start this thread to separate modifications from the general discussion thread. I've had my 4#3 for 2 days now, and have already stripped and re-built it with various mods
1, BA 2.5 servos. Held in place with double-sided tape. I had to trim a bit of plastic from the main frame for a good fit, the existing servo arms fit, the pushrods need to be shortened about 2mm.
2, Remove plastic cover from 4in1 to improve cooling.
3, Direct drive tail rotor using a 45mm. prop from a Plantraco Micro-blimp. To my amazement this worked perfectly. There are probably other props around that will work.
4, Base-loaded micro antenna, I got mine from Zebrahobby.
5, Semi-scale Bell 47 cockpit and tail boom, left over from putting a Ka226 fuselage on my 5#6.
6, Lowered and widened skids, again left over from the 5#6, and re-bent.
After all this I discovered I'd lost 2.5gm. off the weight!
I'm currently wating for an 0703 tx, in the hope I can lose some of the twitchiness by cutting down servo travel, and adding expo.
Chris
red-panda is offline Find More Posts by red-panda
Old Sep 24, 2007, 07:44 PM
buster7467 is offline
Find More Posts by buster7467
morgantown, wv
Joined Mar 2004
That looks pretty interesting.
buster7467 is offline Find More Posts by buster7467
Old Sep 24, 2007, 09:14 PM
skizziks is offline
Find More Posts by skizziks
United States, NJ, Manville
Joined May 2006
Does the #5-6 tail boom flex ???.....I was thinking myself that the #5-6 canopy would be lighter..
skizziks is offline Find More Posts by skizziks
Old Sep 24, 2007, 10:18 PM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
How did the stock heli fly? What did you not like about it? How long was the flight time?
Gino CP is offline Find More Posts by Gino CP
Old Sep 24, 2007, 10:20 PM
bekylane is offline
Find More Posts by bekylane
Heli girl!
bekylane's Avatar
USA
Joined Apr 2007
Cool mods there!
A mod I would love to see is a "mothed" 4#3
bekylane is offline Find More Posts by bekylane
Old Sep 24, 2007, 11:41 PM
red-panda's Avatar
Vancouver, BC
Joined Aug 2004
skizziks, Yes the boom does flex a bit, but not enought to cause problems as the tail rotor thrust is pretty low.
Gino, Stock heli was fine but twitchy, can't tell you flight time as I never flew continuously through a full pack. Nothing I didn't like about it, but I don't trust Walkera servos, and prefer scale looking helis to pod+boom.
bekylane, It could be "mothed", but the cost of lighter servos alone would be more than the basic heli. It'll take a richer person than me to do that mod!
Chris
Old Sep 25, 2007, 03:31 AM
klausbub is offline
Find More Posts by klausbub
Germany
Joined Sep 2006
thumbs up!
i really like that bell 47 G style!!!
stock look is not realistic. (as most bigger rc helis look like unrealistic things).
i really like bubble canopys and grid tails.
regards!
klaus
klausbub is offline Find More Posts by klausbub
Old Sep 26, 2007, 03:22 AM
generalbacardi is offline
Find More Posts by generalbacardi
Joined Sep 2007
How about a Spektrum DX7/AR6100 setup?
generalbacardi is offline Find More Posts by generalbacardi
Old Oct 11, 2007, 11:52 AM
IgorT is offline
Find More Posts by IgorT
Helicopter addict
Slovenia, Europe
Joined Aug 2005
The boom from the 5#6 is not that strong. It might be strong enough to withstand the forces exerted by the tail prop, but it's very prone to breaking in crashes. Especially since you now have some added weight on it...
You could make it MUCH stronger using a short 1mm CF rod hidden and glued inside it. It would hardly add any weight..
Otherwise, nice mod.
IgorT is offline Find More Posts by IgorT
Old Oct 11, 2007, 11:54 AM
IgorT is offline
Helicopter addict
Slovenia, Europe
Joined Aug 2005
There are servos that are lighter than the BA2.5?
Where and how much do they cost? Not that i would ever consider buying them, but it really makes me curious..
Old Oct 11, 2007, 01:45 PM
mahbouni is offline
Find More Posts by mahbouni
Heli Hooligan
London
Joined Dec 2006
What ever servos you try, they will need to be able to run on 3.7v and also the 4-in-1 will need to be able to supply enough current to power them. I tried some alternative servos on my Walkera 52 and they caused the 4-in-1 to reset.
mahbouni is offline Find More Posts by mahbouni
Discussion Submicro Walkera 4#3 FP - 4 channel piccoz sized heli! sketchaholic Micro Helis 6422 Mar 07, 2008 06:27 PM
Cool Walkera 4#3 Video Out!! massimo Micro Helis 96 Feb 29, 2008 12:54 AM
Discussion Walkera 4#3 HELP!? MConstable Micro Helis 5 Sep 13, 2007 03:01 PM
Discussion Walkera 4#3 axelen Micro Helis 11 Aug 19, 2007 07:19 AM
Discussion Walkera #4 and 3 cell lipo davidcollins001 Micro Helis 4 Apr 03, 2006 08:24 AM
