Old Sep 23, 2007, 10:56 PM
tim engel is offline
Find More Posts by tim engel
Joined Jul 2007
Bob Martin SR-7 or Coyote
Are there any kits being made today that look like either of these planes. I like the look of the low wing with dihedriel and swept wing. Any info is appreciated.
tim engel is offline Find More Posts by tim engel
Old Sep 24, 2007, 03:31 PM
DLD is offline
DLD
Find More Posts by DLD
DLD
David Layne
Tracy, Ca
Joined Jun 2004
Check out the Jart,http://www.jartworld.com/jartworld_pgs/jartworld.html, it should tinkle your bell.
DLD
DLD is offline Find More Posts by DLD
Old Sep 24, 2007, 10:23 PM
Doubletap is offline
Find More Posts by Doubletap
Si Vis Pacem Para Bellum!
Doubletap's Avatar
United States, CA, El Segundo
Joined Jul 2005
Unfortunately, these "pure" slopers of the 70's-80's have come and gone; kits like these are very rare nowadays and normally are produced on a very limited basis. If you are interested in these great vintage slopers, there is a thread in the Slope Soaring forum dedicated to vintage slope planes:
http://www.rcgroups.com/forums/showthread.php?t=466486
There you will find the knowledge and resources associated with this niche category.
Doubletap
Doubletap is offline Find More Posts by Doubletap
Old May 04, 2012, 02:58 PM
Mcgyver52 is offline
Find More Posts by Mcgyver52
Louisville,ky
Joined Nov 2007
SR7 Sailplane N.I.B.
Anyone interested in a Bob Martain SR7 ? I got it thinking I would have a sailplane to pull up with my Rascal but it looks like it will be too small for that. It is brand new in the box. Email me if interested.
Doug
zgconcours@insightbb.com
Mcgyver52 is offline Find More Posts by Mcgyver52
Old May 04, 2012, 08:08 PM
bjaffee is online now
Find More Posts by bjaffee
Brett
bjaffee's Avatar
So Cal
Joined Apr 2002
Doug
Post it in the classified section...you'll probably get a lot of hits on that.
bjaffee is online now Find More Posts by bjaffee
Old May 05, 2012, 09:27 PM
Shawn in NorCal is offline
Find More Posts by Shawn in NorCal
United States, CA, Auburn
Joined Oct 2010
Coyotes are dogs to fly, SR7s are fun. I've had both.
Shawn in NorCal is offline Find More Posts by Shawn in NorCal
Old May 06, 2012, 01:08 PM
Rich Speroni is offline
Find More Posts by Rich Speroni
Joined Jun 2003
Compared to what?
Compared to 25 years ago Coyotes weren't DOGS.
Rich Speroni is offline Find More Posts by Rich Speroni
Old May 06, 2012, 01:20 PM
Joined Oct 2010
Compared to the SR7 he's looking at. It's like comparing an aileron trainer and a Corvette. I was flying 25 years ago and then some...
I still have a Coyote, I think they look great, but it's still a dog. I have dreams of some day having time to build a new wing with a better airfoil and big ailerons. I should just sell it....
Old May 06, 2012, 03:53 PM
Libelle201B is online now
Find More Posts by Libelle201B
Libelle201B's Avatar
S. FL
Joined Jan 2007
Nothing wrong with the Coyote as a sloper, but it is slower than many of the newer designs for sure most likely due to the thicker wing section. It's pretty rugged and a great windy weather plane as it handles well in those conditions. The airfoil is an Eppler 374 or very close to it making it aerobatic but it definitely doesn't fly inverted as well as it does upright, you have to keep the speed up while up side down to maintain adequate control. I did modify mine by reducing the span by about 6 inches so it would fit in the cab of my truck and it didn't hurt the handling a bit.
Libelle201B is online now Find More Posts by Libelle201B
Old Nov 20, 2012, 12:58 AM
jmdairplane is offline
Find More Posts by jmdairplane
Joined Nov 2012
bob martin planes
i had all 3 planes all flew well use to fly with bob and katie on ave 33 mount washington in la ca
wish i still had one.
jmdairplane is offline Find More Posts by jmdairplane
Old Nov 20, 2012, 03:35 AM
doddlepots is offline
Find More Posts by doddlepots
Joined Feb 2006
Y'all going on about Bob Martin sailplanes brings back memories of my Bob Martin "Pussycat". I flew it on the slope, in the lightest of winds it just kept flying and flying, in the faster winds it rushed around and did elementary aerobatics and still landed on a dime; in a howling gale, with up to 6 extra AA batteries stuffed in the fuselage (no-one even used the work "ballast" back then), or even the odd stone or two, it shrieked across the slope.
On the flat, it towed up a dream on a hand-line, ditto with a high-start and even spent hours and hours thermalling, after a 60-second run of a COX .049, on a pylon, rubber-banded onto the wing.
It was perfect. Then, one day a friend of my son appeared on the slope with a beautifully built, Italian, "full-house", low-wing sailplane , with which he thought he was going to learn to fly. It seemed a tragedy to me and, as he refused to try and learn with my "Pussycat", which virtually flew itself, I finally ended up swapping the PC for his Italian job!
He decided his 27 mhz. radio was better than my 35 mhz and that the PC nose was too blunt and set about giving it a pointed nose and fit a, very dicey, 27 mhz. receiver. Not only was it "dicey", but the local taxi radios ran on 27 mhz. and many of them had "boosters", to boot.
I imagine you can imagine the end of my pride and joy. Its first re-maiden lasted all of three seconds, as, on top of everything else, he decided that a very craggy hill, with wicked turbulence and a howling gale, was the ideal place to start learning to fly.....
The "Italian" job did not last much longer. I thought it a little unwise to try and trim it at the slope and did so on the flat. Not too bad, so we decided to give it a "hand-tow" (I think i've told this one before), son and heir goes charging off across the field like Usain Bolt, straight into stiff breeze...4? seconds, I reckon, before the wings applauded. RIP
What memories.
doddlepots is offline Find More Posts by doddlepots
Rave Bob Martin SR-7 Runaway Slope 36 Feb 21, 2014 08:25 PM
fs: Bob Martin SR-7 Davey01 Aircraft - Sailplanes (FS/W) 11 Nov 20, 2004 03:19 AM
Bob Martin SR-7 for sale! rimshot Aircraft - Sailplanes (FS/W) 10 Oct 23, 2003 12:06 AM
Bob Martin SR-7 for sale! rimshot Slope 3 Oct 16, 2003 04:11 PM
WTB: Duralene fuse for sloper.. (SR-7 or Coyote if possible) Daemon Aircraft - Sailplanes (FS/W) 14 Sep 23, 2002 06:04 PM
