Old Dec 23, 2007, 08:35 PM
rdalcanto is offline
Find More Posts by rdalcanto
rdalcanto's Avatar
Salt Lake City, UT
Joined Sep 2003
If you order the ARF version, will a 4 channel receiver work? (I don't see the need for a 6 channel). Do you steer the nose wheel with the rudder stick (channel 4)?
Thanks!
rdalcanto is offline Find More Posts by rdalcanto
Old Dec 23, 2007, 09:05 PM
dawnron1 is offline
Find More Posts by dawnron1
"Have Glue - Will Travel"
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
rdalcanto,
A four channel receiver will work fine, and yes you'll steer the nosewheel with the rudder stick and use the rudder channel.
You'll love it!
Ronnie
Thanks!
dawnron1 is offline Find More Posts by dawnron1
Old Dec 23, 2007, 09:08 PM
rdalcanto's Avatar
Salt Lake City, UT
Joined Sep 2003
Originally Posted by dawnron1
rdalcanto,
You'll love it!
Ronnie
Cool! Does it need a lot of down elevator to fly inverted? Does it do outside loops well?
Thanks again!
Old Dec 23, 2007, 10:24 PM
snoshoe62 is offline
Find More Posts by snoshoe62
Boycot Crappy CC Controllers
snoshoe62's Avatar
United States, MI, Port Huron
Joined Jun 2006
I flew mine for the first time today, was kinda windy thought it would handle the wind better but I guess it is a foamy. Because it was windy had to use alot of full throttle and was about done in 5 minutes so not an acurate test of flight time. Being all blue ya gotta keep ur eye on it, once I couldnt tell top from bottom but worked it out. I would be real worried with with the silver diamond back edition coming out.
snoshoe62 is offline Find More Posts by snoshoe62
Old Dec 24, 2007, 08:54 AM
rdalcanto's Avatar
Salt Lake City, UT
Joined Sep 2003
I'm getting ready to order....! But I NEED to know, will it do outside loops?!?
Thanks $$$
Old Dec 24, 2007, 09:21 AM
rdalcanto's Avatar
Salt Lake City, UT
Joined Sep 2003
Dam! I couldn't resist. I ordered it. After switching to helis ten years ago because I was bored with airplanes, I had to get the jet I've always wanted since I was a kid. I remember helping a guy flies his Foamy EDF a few years ago at the field. I don't recall what it was, but it had so little power the thing could barely fly, and I thought "I'm never wasting my money on one of these!" However, with brushless motors, it seems like a whole new ball game now! I thought about going for the A4, but the $100 difference didn't seem worth it, and I would rather have real landing gear and be able to do those cool nose high approaches and runway landings, than go really fast.
Old Dec 24, 2007, 03:17 PM
rdalcanto's Avatar
Salt Lake City, UT
Joined Sep 2003
I'm thinking of using Gorilla glue instead of epoxy to save weight. Any thoughts?
Thanks.
Old Dec 24, 2007, 11:18 PM
marcusg is offline
Find More Posts by marcusg
Nor Cal,USA
Joined Sep 2000
Fellas, could you use a 3s 2100 mah battery from a Trex helicopter for this jet using the stock power setup ? Thinking about getting one of these. Thanks in advance.
Marcusg
*UPDATE*
Went ahead and just ordered it from Hobby Lobby using that 20% discount.
marcusg is offline Find More Posts by marcusg
Old Dec 26, 2007, 07:39 PM
rdalcanto's Avatar
Salt Lake City, UT
Joined Sep 2003
I haven't even received mine yet, and I'm already wondering if you can fit the Alfa EDF 60/15 Mk. 2 fan and Jetscreamer motor in this thing?
Old Dec 27, 2007, 12:13 PM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
I fit a lsjs to the stock motor mount that comes with it, and used the stock fan and also a gws fan, they both work great and give good vertical, I don't know that you really need the alfa fan, unless you want to reduce current a bit, I still got 6 minute flights with a 2100 pack with the 64mm and lsjs.
Frank
burkefj is offline Find More Posts by burkefj
Old Dec 27, 2007, 02:02 PM
rdalcanto's Avatar
Salt Lake City, UT
Joined Sep 2003
Frank
Did you have to change the ESC? Do you know what amps you are pulling with the lsjs?
I'd like to stick to the 1300 pack if possible (weight and cost), even if I'm down to 5 minute flights. I would like to get to 1:1 thrust:weight if possible, so I can do a slow flybye with the nose up, hit the throttle, get a little speed, and then go vertical for some rolls....
Old Dec 27, 2007, 02:53 PM
Ben-Rod is offline
Find More Posts by Ben-Rod
HOW HIGH DOES IT GO???
Ben-Rod's Avatar
Jacksonville, Florida
Joined Nov 2004
Does anyone know of a link for the gray/black version, and also when it will become available?
Ben Rodriguez
Ben-Rod is offline Find More Posts by Ben-Rod
Old Dec 27, 2007, 03:01 PM
marcusg is offline
Nor Cal,USA
Joined Sep 2000
Frank
Frank, is your 2100 pack the same kind we use for the Trex heli or is this for a different "dimension" sized battery pack ? Thanks in advance.
Marcusg
Old Dec 27, 2007, 04:33 PM
burkefj is offline
burkefj's Avatar
Joined Oct 2006
You will pull around 24-26 amps full throttle with the lsjs and the gws or stock fan, it is too much for a 1300 pack, I replaced the esc with a CC 36 amp version. I'm running a standard TP 2100 pack, 5 oz, about 3/4x4x1" approx. I don't know if it is true 1:1 thrust to weight with this setup, but you can definitely do a high alfa, and then accelerate out without dropping the nose much.
Frank
Old Dec 28, 2007, 05:33 PM
snoshoe62's Avatar
Joined Jun 2006
Frank
All you needed was the LSJS motor or adapter too? After this drop in and 2100mah 3s batt was it really a significant increase in performance? I see the LSJS is rated to 290 watts, I dont think thats much better then stock. But Id like to do something to get more out of mine, its kinda boreing stock.
Article Hobby People BH Models Chipmunk 61 ARF Review pda4you Glow to Electric Conversions 44 May 16, 2010 03:15 PM
Eam F-18 Arf Jim Phelps Electric Ducted Fan Jet Talk 41 Dec 17, 2002 09:32 PM
EJF - press releases, ejets.tv, F-18 ARF, F-18 Super Hornet for 90 mm EDF Robert Wagoner Electric Ducted Fan Jet Talk 4 Jun 24, 2002 12:11 PM
EAM's F-18 ARF bruff Vendor Talk 33 Apr 08, 2002 09:24 PM
