Old Dec 02, 2007, 09:27 PM
darmar is online now
Find More Posts by darmar
USA, PA, Pittsburgh
Joined Jul 2001
We've seen that already.
Now tell us where to get these kits other than blue angels version.
darmar is online now Find More Posts by darmar
Old Dec 02, 2007, 10:08 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
Amen to that question... I wan the Black and grey one....
ATIS is offline Find More Posts by ATIS
Old Dec 06, 2007, 11:32 AM
velyter is offline
Find More Posts by velyter
Aviator
Bellevue, WA
Joined Dec 2007
F18 Foamy Scale Decals
I made some somewhat crude Blue Angel decals to make it look more scale in flight. It built fast and easy so today is it's first flight. It of course it not true scale.
I also
velyter is offline Find More Posts by velyter
Old Dec 08, 2007, 12:59 PM
gmc-mi is offline
Find More Posts by gmc-mi
Michigan
Joined Jul 2003
Originally Posted by burkefj
You are right, I've got the mirage also, and with the same stock components the F-18 is a much much better performer. I found that using a 2100 battery pack and a 36 amp tbird speed control upped the performance a good amount, the stock battery was limiting the performance, and so was the speed control, allowed 2-3 more amps to be drawn at least. If you use a light receiver, like a berg or 6100 you save a bit of weight and the little heavier 2100 is compensated for by the thrust increase.
Frank
Frank,
What did you remove to fit the 2100 pack in? Looks like I would need to remove the divider between the battery and receiver compartment - removing the foam and plastic. Anything else special?
I saw it fly at NEAT before I bought it (came home and ordered it..) Would like more capacity for longer flight... looks like about 2.5 oz more in battery weight between stock 1300 and TP 2200...
Thanks!
Greg
gmc-mi is offline Find More Posts by gmc-mi
Old Dec 08, 2007, 03:43 PM
ATIS is offline
Member 120mph Club
ATIS's Avatar
Greg... it gets 8-10 minutes on the stock lipo... thats a lot of time... my SU-27 gets 4 minutes on a 3s 2500 lipo...
Old Dec 09, 2007, 12:29 AM
burkefj is offline
Find More Posts by burkefj
burkefj's Avatar
Joined Oct 2006
Greg, yes, just remove the foam and plastic between the divider. The stock battery I measured was 3.5 oz, and a 2100 tp is 5, so only 1.5 oz more weight. Actually to get the benefit of the bigger battery for extra power, not just flight time, you really should replace the speed control with a 30 or 36 amp, I got about 2-3 more amps draw and increased thrust as a result, so my runtime is still about the same but I have more power to more than compensate for the weight increase, on mine I used a berg receiver, and that saved a few grams also, and removed the rudder control wire since I didn't find rudder on the is plane to do much, but steering was important.
I do slide my battery back once it is inside the bay all the way to the rear that I can, and use a piece of foam stuck inside the forward bay to keep it from sliding.
I never got 8 minutes on the stock battery, first one puffed on the first flight after 5 minutes.
Frank
Originally Posted by gmc-mi
Frank,
Thanks!
Greg
burkefj is offline Find More Posts by burkefj
Old Dec 11, 2007, 11:31 AM
helifann is online now
Find More Posts by helifann
Joined Dec 2005
Well I'll second on replacing the speed control,my bec has given out a couple of times leaving my plane w throttle but no servo control! Still in one piece!
helifann is online now Find More Posts by helifann
Old Dec 12, 2007, 10:06 AM
rickbones is offline
Find More Posts by rickbones
rickbones's Avatar
Joined Sep 2005
The plane looks great, does anyone have any experience on higher altitudes and EDF"s I live at 6,550 feet; would this plane make it off the ground up here?
rickbones is offline Find More Posts by rickbones
Old Dec 12, 2007, 02:28 PM
meatpuppet is offline
Find More Posts by meatpuppet
Joined Jan 2007
Definitely need to change the servos. Great plane, but on the 4 flight, one of the elevator servos got stuck in the up position. Managed to save the plane with only the nose breaking off. I changed the servos and esc, and it is now my favorite plane.
Anyway, I'm using a Spektrum DX6 and thunderbird 36 esc. I was wondering if there was a way to set it up so that I can reverse the direction of the motor with the transmitter. Like a reverse thrust, so I can use it for landing.
meatpuppet is offline Find More Posts by meatpuppet
Old Dec 12, 2007, 06:43 PM
bc-slowflyer is offline
Find More Posts by bc-slowflyer
Lower, Lower
bc-slowflyer's Avatar
Penticton,BC, Canada
Joined Feb 2004
Great review Ronnie!! I love how that plane handles at low speed. Nothing twitchy about it at all.
Thanks;
Rod
bc-slowflyer is offline Find More Posts by bc-slowflyer
Old Dec 12, 2007, 06:52 PM
dawnron1 is offline
Find More Posts by dawnron1
"Have Glue - Will Travel"
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
Thanks;
Rod
Thanks Rod!
Ronnie
dawnron1 is offline Find More Posts by dawnron1
Old Dec 13, 2007, 02:04 PM
kdfi73 is offline
Find More Posts by kdfi73
Acampo, Ca. USA
Joined Oct 2006
Still new at EDF's. Does anyone know if the F18 can be repainted for a more milatary look? Or will the extra paint weigh it down too much?
thanks
kdfi73 is offline Find More Posts by kdfi73
Old Dec 13, 2007, 07:15 PM
dawnron1 is offline
dawnron1's Avatar
Ft. Worth, Texas
Joined Jan 2004
kdfi73,
I'm planning to repaint mine in a darker 'navy blue' color. I don't think you'll have a problem as long as you go with a light coat.
Ronnie
Old Dec 15, 2007, 12:21 PM
snoshoe62 is offline
Find More Posts by snoshoe62
Boycot Crappy CC Controllers
snoshoe62's Avatar
United States, MI, Port Huron
Joined Jun 2006
Any recent buyers know if Hobby lobby got the paint issues worked out on this yet?
snoshoe62 is offline Find More Posts by snoshoe62
Old Dec 15, 2007, 09:43 PM
JOHNNY LOVE is offline
Find More Posts by JOHNNY LOVE
Joined Jul 2007
Hummmm???
Has anyone put any modifications on the hobby-lobby f/a-18 Yet?
Like a faster motor etc.
JOHNNY LOVE is offline Find More Posts by JOHNNY LOVE
Article Hobby People BH Models Chipmunk 61 ARF Review pda4you Glow to Electric Conversions 44 May 16, 2010 04:15 PM
Eam F-18 Arf Jim Phelps Electric Ducted Fan Jet Talk 41 Dec 17, 2002 10:32 PM
EJF - press releases, ejets.tv, F-18 ARF, F-18 Super Hornet for 90 mm EDF Robert Wagoner Electric Ducted Fan Jet Talk 4 Jun 24, 2002 01:11 PM
EAM's F-18 ARF bruff Vendor Talk 33 Apr 08, 2002 10:24 PM
