Old Aug 17, 2008, 06:29 PM
Bat21 is offline
Find More Posts by Bat21
Anchorage, Alaska
Joined Sep 2002
Originally Posted by modfly
ah man..always something
I hate it when they trick you like that!
Bat21 is offline Find More Posts by Bat21
Old Aug 17, 2008, 09:29 PM
Eric Henderson is offline
Find More Posts by Eric Henderson
Eric Henderson's Avatar
United States, NV, Las Vegas
Joined Dec 2005
Originally Posted by VF84Sluggo
Great post, Eric. Thanks.
I'm planning on running the stock fan with Don's 4800/EDO. I want to keep the mod as simple as possible but hopefully still see a more sprightly Viper.
You will see half the usual take-off run. The ability to do large loops from level flight etc.
I am assuming that you will also use the 40A Pentium ESC or equivalent.
The HL stock fan was a tight fit so I would only fit it once :-)
Eric H.
Eric Henderson is offline Find More Posts by Eric Henderson
Old Aug 17, 2008, 10:06 PM
VF84Sluggo is offline
Find More Posts by VF84Sluggo
Wood flight decks, guns only!
VF84Sluggo's Avatar
Gulf Breeze, FL
Joined Nov 2007
Eric H.
I flew my Viper this afternoon, and I am ready for better performance. Thanks for the heads-up about the fan fit. I'll be careful. And yes, I'll be running the 40A Pentium.
What battery do you run with this setup?
Sluggo
VF84Sluggo is offline Find More Posts by VF84Sluggo
Old Aug 18, 2008, 12:56 AM
Joined Dec 2005
Sluggo
TENERGY 2200mAh 30C 66A. IMHO The only way to go if you like grunt!!!
Eric H.
Old Aug 18, 2008, 08:10 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Originally Posted by The Don
I just ordered (hopefully) all the airframe parts to build one.
ST11806 VERTICAL TAIL SET, BLUE ANGELS
Don
I couldn't find that part on the site, did you phone in the order?
Joe 1320 is offline Find More Posts by Joe 1320
Old Aug 18, 2008, 11:07 AM
VF84Sluggo's Avatar
Gulf Breeze, FL
Joined Nov 2007
Eric H.
Good, thanks. One question, though: The 40A Pentium can handle 66A?
Old Aug 18, 2008, 01:05 PM
Michael Paxton is offline
Find More Posts by Michael Paxton
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
Nashville TN.
Joined Mar 2006
OOps!
Michael Paxton is offline Find More Posts by Michael Paxton
Old Aug 18, 2008, 01:43 PM
Joined Dec 2005
It's a good question.
The max draw I measured was 47A. It was not for long either because the pack delivery settled just below 40A.
What the battery is capable of and what we take out of it does not have to be the same. In fact, this Tenergy will deliver 110A in a short burst.
However, this pack in this set-up, never gets close to being hot even at WOT for the whole flight. Neither does the externally mounted ESC
Regards,
Eric H.
Old Aug 18, 2008, 02:01 PM
Aubard is offline
Find More Posts by Aubard
Aubard's Avatar
Maysville, Kentucky, United States
Joined Aug 2003
Another F/A-18 is in the sky!
I finally got around to assembling my F/A-18 "Red Vipor" last week. Since I'm relatively new to EDFs I decided to go with the stock setup and use my own radio (an old Hitec Laser 6 with a GWS R-4P Rx) instead of the included radio.
I did a quick maiden on Friday night to check it out and it flew very nicely. I've since logged four more flights and am beginning to get the "feel" of this plane. Since I'm not interested in speed, I am perfectly content with the stock setup. With a fresh battery pack it will loop from level flight and the roll rate is nice, especially when I switch the ailerons to high rates. Landings are simply a matter of lining up with the runway and reducing throttle. It sits down very easily and will slow down without wanting to stall.
All in all I'm very happy with this plane and really enjoy watching it carve up the sky.
modfly - Again, thanks for your input on the CoG location. Mine's a little nose heavy, but flies fine. I'm getting an easy 5-6 minutes of flight-time on the stock battery pack with enough juice left over for another circuit or two to line up for landings. Haven't hit the LVC yet.
Davis
Aubard is offline Find More Posts by Aubard
Old Aug 18, 2008, 02:17 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Excellent report Aubard....best not to hit the stock hard LVC. The LVC in this plane hits at a very low voltage so there is the potential for puffing the lipo if flown to stock LVC. I installed a DE Smart SBEC in mine with soft LVC and it pulses the motor before I ever see the stock hard LVC.
modfly is offline Find More Posts by modfly
Old Aug 18, 2008, 03:12 PM
Aubard is offline
Aubard's Avatar
Joined Aug 2003
modfly,
I think that's good advice. I plan to install a Park BEC before too long, just for the extra margin of safety.
Most of my flying is at half throttle (or a click or two above), so I'm getting decent flight-times and when I land the battery pack is only a bit warm, not even approaching hot.
I hope to get a couple more flights tonight, if the wife doesn't have too many chores lined up for me.
dcl
Old Aug 18, 2008, 03:15 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
Aubard..use the DE Smart SBEC it has the soft LVC..the Park SBEC does not.
http://www.dimensionengineering.com/SmartBEC.htm
This SBEC will hit soft LVC before the stock hard LVC so you will never see the hard LVC.
Old Aug 18, 2008, 03:51 PM
Aubard is offline
Aubard's Avatar
Joined Aug 2003
Thanks, I'll check it out.
Old Aug 18, 2008, 09:50 PM
VF84Sluggo's Avatar
Gulf Breeze, FL
Joined Nov 2007
Regards,
Eric H.
Yes, I should have realized just what you said...max power/amps are not always being demanded from the battery. And, as the flight progresses, less is available anyway.
I looked in to the Tenergy's. Looks like a very good battery, not just for the Viper but also for my Power10/40A ESC modded PZ T-28. I plan on ordering a few 2200/30C's tonight.
Old Aug 18, 2008, 09:55 PM
modfly is offline
modfly's Avatar
USA, OH, Akron
Joined Dec 2006
don't let this happen...http://www.rcgroups.com/forums/showa...mentid=2016882
Id say don't operate on grass
Article Hobby People BH Models Chipmunk 61 ARF Review pda4you Glow to Electric Conversions 44 May 16, 2010 04:15 PM
Eam F-18 Arf Jim Phelps Electric Ducted Fan Jet Talk 41 Dec 17, 2002 10:32 PM
EJF - press releases, ejets.tv, F-18 ARF, F-18 Super Hornet for 90 mm EDF Robert Wagoner Electric Ducted Fan Jet Talk 4 Jun 24, 2002 01:11 PM
EAM's F-18 ARF bruff Vendor Talk 33 Apr 08, 2002 10:24 PM
