Old Sep 23, 2007, 11:54 AM
frankyfly is offline
Find More Posts by frankyfly
frankyfly's Avatar
Italy
Joined Sep 2004
F-22 coroplast plan wanted
Recently I got some coroplast.
Does anybody has ever build an F-22 raptor pusher jet or similar ?
Do you have some link to plans to be used ?
T.I.A.
Franky
frankyfly is offline Find More Posts by frankyfly
Old Sep 23, 2007, 04:27 PM
kevingill is offline
Find More Posts by kevingill
kevingill's Avatar
Joined Dec 2004
Hiya,
What thickness of coroplast have you laid your hands on?
I've thought about making a coroplast Eurofighter Typhoon using depron foam plans, but the wife would kill me
There are several F-22 depron foam plans around - just a thought.
Alternatively, you could start with a Mugi and add-on (so to speak).
kevingill is offline Find More Posts by kevingill
Old Sep 24, 2007, 03:47 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Thank Kevin,
It's a thin board. It shoul be 2 or 3 millimeter.
I thought about using the foam plan. The coro I have is too thin, I have to solve for the flexibility adding some bamboo skewers and or CF roads.
Franky
Old Sep 25, 2007, 03:20 AM
Smooth Spanky is offline
Find More Posts by Smooth Spanky
Hack of all trades...
Smooth Spanky's Avatar
Detroit, Michigan
Frankyfly:
I know I've seen guys build coro jets, but wasnt' able to find any on this forum for you. I'd suggest checking over at spadworld, I know there's some stuff there, but I'm not sure if they are pushers or not...worth taking a look though.
Smooth
Smooth Spanky is offline Find More Posts by Smooth Spanky
Old Sep 26, 2007, 09:18 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Thank you Smooth,
See what I've buid so far.
I got the plan from the foam scratchbuild forum here .
Franky
Old Sep 26, 2007, 10:37 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Securing FINS.
This is the way I fix the fins to the fuse.
Franky
Old Sep 28, 2007, 04:25 PM
kevingill's Avatar
Joined Dec 2004
Well it's looking pretty good so far!
The method of gluing the fins is similar to the way I build a Mugi.
I usually tape the joint or place a bead of hot-melt glue to give a good hold.
What battery/motor/prop are you thinking of installing?
I've seen a recent thread on the scratchbuilt foamies where an F22 weighed 7oz all up. I haven't noticed a lot of difference in weight between thin correx and foam built wings to be honest, but correx just bounces whereas foam breaks up!
Looking forward to more build pictures.
Old Sep 29, 2007, 04:14 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Kevin so far the bare frame is about 5 oz (150 gr).
I plan to stay around 7-8 oz (250-300 gr) AUW.
This is the motor I ordered.
Franky
Old Sep 29, 2007, 04:19 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Some building update...
Removable nose for hard landings.
Franky
Old Oct 03, 2007, 05:09 AM
frankyfly's Avatar
Italy
Joined Sep 2004
Some update..
It weights 7.5 oz. as it is.
Franky
Old Oct 17, 2007, 02:58 PM
kevingill's Avatar
Joined Dec 2004
Any update on the F-22 Frank?
Keen to see how the fella flies!
Old Oct 18, 2007, 01:09 PM
frankyfly's Avatar
Italy
Joined Sep 2004
Hi Kevin, I'm still searching for the right motor.
Probably I'm going to use a micromotor (Kv 2100) or a higher torque (Kv 1800) with 3S and GWS 7/3 prop.
Due to work commitment I should have happy hours in two weeks time.
Franky
Wanted Wanted - F-16, F-18 and F-22 RTF aalhait Aircraft - Electric - Helis (FS/W) 3 Nov 30, 2006 08:29 PM
Wanted: Wattage F-22 The Blue Max Aircraft - Electric - Airplanes (FS/W) 6 May 12, 2003 02:14 PM
Wattage F-22 EDF conversion..motor/fan choices Ed Waldrep Electric Ducted Fan Jet Talk 6 Sep 10, 2001 01:21 AM
What ever happened to the F-15 and F-22 kits from EJF realdeal Electric Ducted Fan Jet Talk 1 Jul 09, 2001 07:06 PM
wattage f-22 BeechSkipperDude Foamies (Kits) 8 May 14, 2001 06:35 PM
