This thread is privately moderated by chaosMurphy, who may elect to delete unwanted replies.
Old Sep 23, 2007, 07:25 AM
chaosMurphy is offline
Find More Posts by chaosMurphy
Registered HotGlue Addict
chaosMurphy's Avatar
Joined Dec 2006
Watts up and no smoke
To share an observation, some nickel knowledge
and first hand experiments with respect to
model airplane electric motors.
How I got more speed for less AMPs;
Volts equate to speed.
Amps equate to duration.
Watts equate to work accomplished (Watts per pound).
Watts equal Volts times AMPs
(10V X 15A = 150W)
Best investment I ever made…
Two box store digital multi-meters.
Picture and diagram below.
With respect to propellers;
Shorter and/or less pitch usually equate to fewer AMPs >at full throttle<
AND higher rpm, more speed.
Smaller props develop higher rpm for two reasons;
1) less mass accumulated on the motor
2) fewer AMPs mean more Volts (in the form of power) available to the motor due to less internal power waste building up nothing but heat inside the battery and ESC.
Empirical static test proof … different propellers;
http://www.rcgroups.com/forums/showthread.php?t=728162
post 7 in order to selected a prop that was most efficient AND not blow my motor or ESC or puff lipo at MAX throttle.
Battery discharge specification is based on its internal resistance and how much heat it can dissipate before smoke is generated.
The higher the AMP flow through ‘any’ resistance the more heat generated.
Power (in Watt) equals AMP [squared] multiplied by resistance.
IF a component (battery for this example) has an internal resistance of 0.2 Ohm then power waste at 15 A discharge is 15 X 15 X 0.2 = 45 Watts of nothing but heat.
Gramps :>)
chaosMurphy is offline Find More Posts by chaosMurphy
All charged up and no place to fly 10Thumbs Electric Plane Talk 32 Sep 28, 2002 06:21 PM
My Eclipse just went up in smoke!?!? Sloper Mario Radios 13 Sep 25, 2002 09:52 AM
MS Plus Hornet ESC Up in Smoke! afabio Electric Heli Talk 0 May 14, 2002 10:24 PM
Glider went up in smoke! KeithK Electric Sailplanes 10 Feb 19, 2002 12:10 PM
New Dragon 35 Up In Smoke JIMJAM Electric Heli Talk 3 Nov 23, 2001 09:41 PM
