Old Jun 16, 2009, 04:37 PM
alll is offline
Find More Posts by alll
manuLRK
Belgium
Joined Sep 2004
Blanked, no readings, high bright display
I purchased a IMAX B6 recently. It worked well for many charging cycles. But recently, the display flickered, letters disappeared, and finally the display stayed highlighted (bright light), but no readings anymore. Got it once back, after unplugging the power, but at the end of the charge (beep, beep, …) the display had no readings anymore!
Is there a way to reset the unit, or to change the brightness?
Thank You,
Manu
alll is offline Find More Posts by alll
Old Jun 17, 2009, 03:01 AM
still charging is offline
Find More Posts by still charging
still charging
still charging's Avatar
Fort Worth, Texas
Joined Dec 2008
I had a similar malfunction with mine and returned it promptly for a replacement. I then had problems with the second one as well. That went back and I just went with a Hyperion charger since it's moderately priced and will balance within .01 without having to mess with those tiny little resistors, lol. If I were you I would get your cash back and opt for a better charger. It really is worth it in the long run imho. §tay up!
still charging is offline Find More Posts by still charging
Old Jul 24, 2009, 08:29 AM
Coelho is offline
Find More Posts by Coelho
Valinhos/Brazil
Joined Feb 2009
I was just thinking buy this cycler, but now... What other cycler you may recomend with better quality but not too expensive
Rgds
Coelho is offline Find More Posts by Coelho
Old Aug 20, 2009, 03:31 PM
jarrodh is offline
Find More Posts by jarrodh
Joined Aug 2009
hey, i just baught the imax b8, and it says able to charge 1-8 cell lipos, but i can seem to find where to plug in my 2cell battery?? theres no slot they start at 3??
any ideas??
jarrodh is offline Find More Posts by jarrodh
Old Aug 21, 2009, 01:27 PM
Thanos is offline
Find More Posts by Thanos
Athens, Greece
Joined Apr 2009
Well, I just got my B6 for $38 plus $19 for shipping (but that included a BL motor, ESC, two LiPo's). I used it and compared it to a Hyperion charger and there are no significant differences. It charged and balanced to 4.19 - 4.20 - 4.20 my 3c lipo. Maybe I am just lucky, or they have improved their stuff after all these comments of yours!! Since I got it mainly for the lipo's I am satisfied. BUT there is one thing: while charging NiMH, I can't get it to AUTO mode. It is stuck to MANUAL. Manual says I have to press INC and DEC together but nothing happens. It also says to make it blink and then press... but it never blinks.. Am I doing something wrong? The only think that blinks is the current at the down / right side. Any ideas?
Thanos
Thanos is offline Find More Posts by Thanos
Old Aug 21, 2009, 01:48 PM
Thanos is offline
Athens, Greece
Joined Apr 2009
OUUUUPS!!! I am realy sorry... I thought I gave it another try and it works!! I guess the current option has to be blinking and then the two buttons to be pressed together.
Thanos
Old Aug 21, 2009, 07:30 PM
QuarX is offline
Find More Posts by QuarX
It´s your fault HAHAHA
España, AL, Granada
Joined Mar 2009
Hi,
I have a problem that drives me crazy.
My ImaX-B6 not charge over 1,5 amp.
Passed 5 or 7 seconds show the error BREAK DOWN ???????
If the charger current is set to 1.4 not problem.
I checked mosfet´s; shunt´s none of the components appears to be damaged.
Seems to be activate a software limitation or protection in the internal program for any reason.
this charger killing me
I apreciated some info that indicates where is the problem.
Thanks in advance
Jose,
QuarX is offline Find More Posts by QuarX
Old Aug 22, 2009, 02:27 AM
jarrodh is offline
Joined Aug 2009
any ideas??
nevermind, i figured it out..lol
Old Oct 02, 2009, 06:18 AM
Tommygunn is online now
Find More Posts by Tommygunn
My name is Tom
Tommygunn's Avatar
Italy, Emilia-Romagna, Misano Adriatico
Joined Aug 2009
Does anyone know if the manufacturer has corrected the problem?
If so, can anyone tell from the info on my circuit board whether it indicates that my charger is a new version, or whether I should replace the resistors?
Tommygunn is online now Find More Posts by Tommygunn
Old Oct 02, 2009, 01:12 PM
bennetje is offline
Find More Posts by bennetje
Joined Feb 2006
As far as I know they never solved the problem
Ben
bennetje is offline Find More Posts by bennetje
Old Oct 19, 2009, 03:24 PM
habakuk_cz is offline
Find More Posts by habakuk_cz
Joined Oct 2009
what will happen if I will set the maximum voltage of cell to less then 4.2 volts?
habakuk_cz is offline Find More Posts by habakuk_cz
Old Oct 19, 2009, 04:13 PM
bennetje is offline
Joined Feb 2006
Then the charger will still not balance right. It may not overcharge a cell, but some cells will be charged to a higher level than others (so some cells will be discharged earlier than others, possibly even overdischarged).
Ben.
Old Oct 19, 2009, 05:10 PM
Joined Oct 2009
better than destroying the cells, I think. when I will charge with balancing, it should hold at least a little accurate balance of the cells.
Old Oct 20, 2009, 12:02 PM
bennetje is offline
Joined Feb 2006
Better charge normal without balancing. The cells end up worse than started with after balance charging!
Ben.
Old Dec 03, 2009, 09:37 PM
invert is offline
Find More Posts by invert
invert's Avatar
Joined Jun 2008
Well im on a budget and my choices were the Align RCC-4CX 2-4 cell balance charger and the iMax B6 .I ended up going with the iMax B6 so I hope I made the right choice ...
invert is offline Find More Posts by invert
Discussion Final word on the TopFlite Cessna 310 - read this if you want to buy m898 Glow to Electric Conversions 65 May 20, 2015 10:36 AM
Discussion Before You Buy that Ultra-Cheap "Made in China" ARF Read This TheSaint Life, The Universe, and Politics 84 Jun 14, 2007 11:07 AM
Don't read this if you hate Tiger Moths Al P Parkflyers 9 Mar 26, 2002 10:49 AM
JR 652 Problem! Read this if you own a JR! R. Green Electric Plane Talk 0 Dec 11, 2001 10:31 PM
PLEASE READ THIS before posting yet another "too many forums" topic! Andy W Site Chat 0 Oct 05, 2001 08:15 AM
