Old Sep 27, 2007, 08:09 AM
jackosmeister is online now
Find More Posts by jackosmeister
DroneWorlds - TEAM NEW ZEALAND
jackosmeister's Avatar
Auckland NZ
Joined Aug 2007
Elf Hobby 9g servo
* Dimension: 26 x 13 x 24mm
* Weight: 9g
* Operating speed: 0.12sec/60degree (4.8v)
* Stall Torque: 1.6kg/cm
* Temperature range: -30-60degree
* Dead band width: 2ms
* Operating voltage: 3.0V-5.0V
HS56
●Stall torque:1.8kg.cm(4.8V)
2.2kg.cm(6.0V)
●Motion speed:0.16sec/60(4.8V)
0.13sec/60(6.0V)
●Rating voltageC 4.8-6V
●rotation current:180mA(4.8V)
●Temperature range:-20C~+60C
●Dimension:24 x 12 x 24mm
●Weight:11.2g
So they aint total clones.
Unlesss I actually have HS56 servos. (stickers pulled off them from factory - which makes me think something dodgy)
jackosmeister is online now Find More Posts by jackosmeister
Old Sep 27, 2007, 09:27 PM
Auckland NZ
Joined Aug 2007
She just went for her first real flight in the park, no training wheels. Flying perfectly
Thanks for your help guys
Ive just brought a little 2.4Ghz wireless camera that im going to strap to it - Vids to come
Old Sep 27, 2007, 10:06 PM
Auckland NZ
Joined Aug 2007
Finished - Well.... for the moment....until my bank statements are happier....
Cheers for your help, here she is -
Old Sep 28, 2007, 11:46 AM
nybbler is offline
Find More Posts by nybbler
United States, NJ, West Orange
Joined Aug 2007
Need a bit of info on finishing CopterX
I just got a CopterX SE (hey, Gandalf, I haven't binned the Belt CP yet, but I may well, if this thing flies as good as it looks). Is the kit supposed to include the motor mounting screws and washers? Mine didn't :-(. It also has nothing to back the servo mounts; the instructions show plastic nuts like the T-Rex, but there aren't any. Do I need to get some?
Also I bought four 9g servos, and the manual seems to call for a smaller servo on the tail; is this critical?
nybbler is offline Find More Posts by nybbler
Old Sep 28, 2007, 12:09 PM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Mine included 2 sets of motor screws. There are two sets of motor screw holes. One pair has smaller diameter. Use those to mesh the 13T pinion properly. My kit didn't include the nuts required to mount the servos. I just dug a few from my old Tamiya days junk pile.
Nice work Jackosmeister. Very clean. Oh, you can use the notch below the rear cyclic servo to run the servo wire.
Gino CP is offline Find More Posts by Gino CP
Old Sep 28, 2007, 12:20 PM
nybbler is offline
Joined Aug 2007
OK, screws but no washers? I probably have them, then; there's three bags of unidentified hardware, two of which each contain a set of four screws with slightly different diameter between the two bags. I was expecting a set of two screws with washers.
Old Sep 28, 2007, 02:05 PM
Auckland NZ
Joined Aug 2007
screws and nuts are what comes in the rtf kit.
Score 1 for copterX, I was flying yesterday with a mate who has a T-rex S with a dx6, He said ^&*( i should have brought one of those! haha.
Old Sep 28, 2007, 10:46 PM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Grounded over here. Typhoon in town. I'll be rigging up the sim soon.
Old Sep 29, 2007, 04:20 AM
Likestofly is offline
Find More Posts by Likestofly
Tennessee
Joined Jan 2007
Was wondering if anyone had a preference or opinion on the AE vs SE before I place my order.
Likestofly is offline Find More Posts by Likestofly
Old Sep 29, 2007, 05:39 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
Apart from the aluminum vs cf frames and fins, they are identical mechanically. Unconfirmed reports say the AE is lighter. But seeing how little material is used for the frame and fins, this difference could be negligible.
Old Sep 29, 2007, 06:14 AM
Gandalf_Sr is offline
Find More Posts by Gandalf_Sr
Ted M
Gandalf_Sr's Avatar
Ann Arbor, MI, USA
Joined Feb 2007
Jacko Nice pics, that's a fine looking bird! If you really want to pee your mate off, tell him that I have a Trex 450 SE V2 and I had to write 'CopterX' on my CopterX SE skids so I can tell the difference. Your CopterX AE is equivalent to a Trex 450 SA in every respect (other than price )
Nybbler Use an old credit card, drill a hole in it and then cut out a small square around the hole; makes great backing for servo screws.
I was flying the CopterX on Wednesday and did a long downwind run losing height when I realized the ground was coming up fassssst I hit full throttle and the CopterX made this wonderful growling noise that made others at the flying field look around. The heli recovered perfectly - 3200 rpm CF blades going +10. That Scorpion motor is a beast - it can hit 49Amps! - and it backs up my belief that having lots of power can get you out of difficult situations as long as you push the stick the right way - the Belt CP would have been a mangled pile of bent tail boom and broken blades under the same situation.
Gandalf_Sr is offline Find More Posts by Gandalf_Sr
Old Sep 29, 2007, 07:57 AM
HeliSmith is offline
Find More Posts by HeliSmith
=>] Smack 3D Head [<=
HeliSmith's Avatar
United States, CA, Chico
Joined Feb 2007
Not critical. CG is the only worry and I run a 9650 on my tail. That thing is huge and I can let go of cyclic and just play with pitch for 5 to 10 seconds which is way good enough for me... I ran a TowerPro SG90 there for months before getting the 9650.
HeliSmith is offline Find More Posts by HeliSmith
Old Sep 29, 2007, 08:15 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
I think there is room to slide the lipo down and forward. You need to put velcro to secure it along with the velcro straps.
Old Oct 02, 2007, 06:59 AM
siang is offline
Find More Posts by siang
Auckland
Joined Sep 2007
hi all, great info but I'm lost coz i'm super new to this. bought a copterx, still cant hover it yet. lol. however starting to be able to hover my lama V4 (tail in of course) that i bought 2 months ago. question is to jacko, do u fly every sun on a good weather? would appreaciate it if u can test my copterx if it's properly set up. lol. I live in auckland too.
siang is offline Find More Posts by siang
Old Oct 02, 2007, 07:52 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
That's right, have someone go over your heli. Then put trainers. It will be unlike a coaxial. But a lot better handling than ,say, a micro with a motor tail.
Have you gone through all the screws with Loctite Blue?
Discussion copterx 450 kyleo1234 Mini Helis 33 Jul 17, 2011 05:05 AM
Cool Official SJM325 (450 class) Thread RC-TEK Mini Helis 484 Aug 17, 2010 07:48 PM
Discussion copterx 450 looking good mudder Micro Helis 2 Dec 20, 2008 07:57 AM
Discussion The RCT-450 (325mm) Thread Scott_RC-TEK Mini Helis 5 Oct 08, 2008 11:45 PM
Wanted *UPDATE* Complete T-Rex 450/CopterX 450/HBK2 Tail ass'y (plastic OK) broggyr Aircraft - Electric - Helis (FS/W) 3 Jun 12, 2008 01:29 PM
