Old Sep 22, 2007, 02:18 AM
Thermalin is online now
Find More Posts by Thermalin
I'm a pilot... 100 yrs to late
Thermalin's Avatar
USA, FL, Palm Harbor
Joined Jan 2005
Question
Balance CG of low wing plane
I see in ads for cg balancers the low wing aircraft are shown inverted. Is this so it will hang in a more stable manner having the majority of the weight below? I would think wether it's balanced right side up or upside down, the cg location would be the same.
I'm getting ready to begin balancing my four star .40 and after 4 months of work... I don't want to re-kit it on takeoff.
Thermalin is online now Find More Posts by Thermalin
Old Sep 22, 2007, 03:30 AM
linw is offline
Find More Posts by linw
Wellington, NZ
Joined Aug 2006
Yep, just because it is stable while upside down. Makes no diff to CG.
Good luck with the maiden, Mike. We certainly don't want to see it back in kit form
linw is offline Find More Posts by linw
Old Sep 22, 2007, 10:50 AM
downunder is online now
Find More Posts by downunder
downunder's Avatar
Adelaide, South Australia
Joined Sep 2003
The CG will be in the same place of course but we're not concerned where the vertical location is (somewhere near the centre of the fuselage) but only its position lengthwise. Putting a model on a balancer so that its vertical location is below the support just lets it act like a pendulum and hang in a stable position.
downunder is online now Find More Posts by downunder
Old Sep 25, 2007, 04:31 AM
jetmech05 is offline
Find More Posts by jetmech05
Jacksonville Fla.
Joined Mar 2007
almost impossible to balance a low wing right side up..I'll bet it would fall off the balancer before you got it. inverted is the way to go
jetmech05 is offline Find More Posts by jetmech05
Old Sep 25, 2007, 09:53 AM
RICMOD5634 is offline
Find More Posts by RICMOD5634
RICMOD5634's Avatar
Fremont, Mi.
Joined Oct 2006
Here's how I did my 4*60. mark the CG from the LE of wing on the center bottom of the Fuss. then put a small Eye screw in that spot. Take it out and put a drop of CA (thin) in the hole (to harden the treads). When dry replace the Eye screw and tie mono fishing line or heavy string (enough to support the wt.) then hang it from something in a open area. It should hand prefectly flat, front to back and side to side. Change placemant of things inside or add wt. at high points.
RICMOD5634 is offline Find More Posts by RICMOD5634
Old Sep 25, 2007, 09:41 PM
Thermalin's Avatar
Joined Jan 2005
Why wouldn't you want it slightly nose down as in conventional high wing right side up balancing? (I like the eye screw idea.. lets you balance fore/aft and left/right all at same time)
Old Sep 25, 2007, 11:46 PM
indoruwet is offline
Find More Posts by indoruwet
God's gift to mankind for flying anything.
Joined Aug 2004
Only valid if you want the CG at one certain point, and you better know where that point is.
I use the *sling method* to check the CG. Always right side up.
I assume that a few pilots know what that is. Hang the plane in slings on the wings and a plumb line pointing to the CG.
indoruwet is offline Find More Posts by indoruwet
Old Sep 26, 2007, 01:04 PM
Thermalin's Avatar
Joined Jan 2005
I usually start in the middle of the range on the plans and adjust after a few flights if necessary...
What is the sling method... from what I'm envisioning.. a sling on each wing... (think stork carrying a baby in a sling) will keep the plane nose from pitching up or down??
Old Sep 26, 2007, 04:12 PM
Joined Aug 2004
This makes sense ? Only works if CG is somewhere in the sling area ... which it always is ...
The sling should be wrapped around the rod on top a few times to create a bit of friction.
Old Sep 26, 2007, 06:03 PM
Thermalin's Avatar
Joined Jan 2005
I;ll have to give it a try.. I think I can see how the fuse will swing for and aft now... but seems like it would be insensitive to minor changes. Would it beneficial to have a the dowl at the top be as small in diameter as possible to increase the accurace. Think of it being a large diameter and you'll see what I mean.. would limit the sensitivity which you don't want.
Old Sep 27, 2007, 12:53 AM
Joined Aug 2004
The sketch is not *to scale*
The top dowel is actually a 1/4 inch diameter steel rod.
Old Oct 04, 2007, 08:56 PM
tailskid2 is offline
Find More Posts by tailskid2
tailskid2's Avatar
USA, AZ, Phoenix
Joined May 2003
Upside down...
I like to use the Great Planes CG Balancer...
tailskid2 is offline Find More Posts by tailskid2
Latest blog entry: VQ Ki-61
How do you balance a low wing plane olly49 Parkflyers 2 Sep 01, 2005 06:16 PM
Low wing plane for AP? flatland2d Aerial Photography 1 Mar 26, 2005 02:52 PM
Question low wing plane with no ailerons John Bright Modeling Science 9 Jan 26, 2005 04:02 AM
Spad Low wing plane CHEAP! fenderjw Aircraft - Fuel - Airplanes (FS/W) 1 Jun 29, 2004 09:47 AM
Would this design count as a low wing plane? fdisk Foamies (Kits) 13 Feb 02, 2003 06:32 PM
