Old Nov 29, 2002, 05:19 AM
Hawker is offline
Find More Posts by Hawker
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Another Dash 8 starts taking shape...
De Havilland Dash 8, Q300 series. Right now it's 36 inches long
and the wingspan will be about 35 inches. Will use twin GWS
EDP 100C motors (RS280) with EDP5030 props. Will most likely
paint in Tyrolean colors since they look so sharp IMHO.
This was a B757 Lifelike glider that I'm converting. I'll fill in the
area where the old wing was and cut out a new segment for the
new wing, which I'm going to scale up 10 to 20% since they are
so narrow. Should help it fly better.
Btw, I'm going to lose that hump in the fuselage there, don't
worry. Just part of the process of converting.
I'll post more pics as it progresses. Hope to get the wing built
today. Actually it's going really quickly now. Won't be long.
Here's the look I'm going for...
http://www.airliners.net/open.file/241880/M/
Hawker is offline Find More Posts by Hawker
Old Nov 29, 2002, 12:06 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Awesome website for Airfoils!
http://www.aae.uiuc.edu/m-selig/ads/aircraft.html
This site has just about any airfoil you can think of. Btw, it lists the Dash-8 in there being as
Wing Root Wing Tip
DHC 18% DHC 13%
Should I stick with the same one the real plane uses, or go with something else, like a Clark Y?
Old Nov 30, 2002, 09:25 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Progress...
I went ahead and used the trusty Clark Y airfoil. Tail feathers are cut and hinged. I wanted to get a good start on the engine nacelles but time is limited tonight.
More to come.
Old Nov 30, 2002, 09:58 PM
u.s air is offline
Find More Posts by u.s air
Joined Nov 2002
dash 8
hey hawker
that's a nice look plane you are building i have brought
three of the 757 plane i started convert one in to a boeing 777
i have got the tail fin done .i saw the thread that fanman posted
about the flap i will love to add flap but that is extas weight
i have project go
dc-10 being cut out at the cnc cutter
757 work on
777 work on
learjet just about complete fanman learjet
u.s air aka jermaine
u.s air is offline Find More Posts by u.s air
Old Dec 01, 2002, 05:31 AM
Semafoor is offline
Find More Posts by Semafoor
The Netherlands
Joined Nov 2002
Re: Progress...
Wow!! Looking good. Maybe i'm also going to build a dash instead of a boeing 757. It will costs less than the boeing because it doesn't nead those hardly in holland to find ducted fans. We only have those expensive german stuff in holland instead of the great GWS products that costs less but is hardly to find here
Originally posted by Hawker
I went ahead and used the trusty Clark Y airfoil. Tail feathers are cut and hinged. I wanted to get a good start on the engine parts but time is limited tonight.
More to come.
Semafoor is offline Find More Posts by Semafoor
Old Dec 01, 2002, 07:13 AM
dottney is offline
Find More Posts by dottney
dottney's Avatar
United States, NY, Fairport
Joined Jun 2000
Hawker,
How are you going to make and attach the engine (and motors) nacels? I'm working on a twin from some rather sketchy plans and am trying to figure out how the power will be attached.
OOOO- I'd better not let my son see this, he's a full scale pilot and really wants to get hired on by a company flying Dash 8's.
Dave
dottney is offline Find More Posts by dottney
Old Dec 01, 2002, 07:26 AM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
I'm going to use blue fan-fold foam and just trace the plans with a razor for side and top views. If they come out ok and I'm happy with them, I'll install the motors/wiring and go from there. If I'm not happy with them then I'll just carve a couple using first a hot wire, then knife, that will be more solid (more of a pain though to build).
Hopefully the fan-fold method will work fine. Then I'll use Elmers Probond Poly-U glue to attach them to the wings. I'll post pics of how they turn out.
I'm making some really nice looking landing gear for it and will put the Curtek nav lights I got on it as well since I'll probably fly it more than the AN-225.
Old Dec 01, 2002, 09:43 AM
Eddie P is offline
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
Looking good Hawker! With the long fuse it looks more like the DHC-8-400!
What will be your battery setup?
Eddie P is offline Find More Posts by Eddie P
Old Dec 01, 2002, 10:15 AM
jah is offline
jah
Find More Posts by jah
jah
BALD MEMBER
jah's Avatar
North Georgia
Joined Nov 2001
Great job, look forward to your progress reports!
Jerry
PS: I am converting the C141 from 4 GWS EDF50 to 2 Vasa55's.
Later
jah is offline Find More Posts by jah
Old Dec 01, 2002, 10:26 AM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Thanks Eddie and Jah. Here are pics comparing the two. I guess
it kind of does look like the Q400. Hmmm, interesting.
Batteries, I'm probably going to use a 7.2V 720ma pack of NiCads for starters. What would you recommend?
Jah, yeah I saw you mention that. Good luck with it
Old Dec 01, 2002, 12:14 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
I have a two bladed GWS prop (ok, several of them) but I'm
wondering would it be hard to make a 4 or 5 bladed prop like the
real planes have? I know it probably wouldn't be efficient inflight,
but it'd look great to put on for static viewing. (show off to
friends). Is there such a beast or would I have to make a couple
from scratch?
Another question. I bought a GWS flight pack and it came with a
Pico receiver. They didn't tell me I needed a crystal, so now I
have to order one. Anyhow, are these things good and reliable,
and how's the range on them? As you may have already
guessed I planned on it going in the Dash-8.
Thanks.
Old Dec 01, 2002, 01:07 PM
jah is offline
jah
jah
BALD MEMBER
jah's Avatar
North Georgia
Joined Nov 2001
GWS does make a 3, and 4 bladed prop:
http://www.aeromicro.com/Catalog/pro...1_products.htm
But don't know if they would work direct drive with your motor. I flew my Zero on both on the stock 300/gearbox that comes with the Zero. On 8 cells the 4 bladed was pretty cool, but the 3 bladed did not perform as well as the stock 2 bladed prop that comes with it.
The GWS single conversion RX are ok, I use them most of my "parkflyer" planes, but I would not use them around other planes, and definetly not my bigger, heavier planes (FV1000, SU31, or the dear departed Hellcat)
Later
Jerry
Old Dec 01, 2002, 01:19 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
Thanks for the info Jah.
I have 5" props on my Dash 8, that 10" 4 bladed and the 9" 3 bladed would be HUGE on it.
Guess I'll stick with what I have.
Old Dec 01, 2002, 03:26 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
And a link to the page at Walmart. It's $129.88 btw.
http://www.walmart.com/catalog/produ...3A4200%3A78191
Old Dec 01, 2002, 05:17 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Another Dash 8 project
Hawker!
It's great to see your Dash 8 taking shape. It really looks good!!
Keep on posting photos as you go along. Are you thinking of using ailerons as well, or will you stick to rudder and elevator?
My project is still in the planning stages, awaiting drawings, but seeing your project turning out so well is really encouraging!!
By the way, this is the livery I hope to use (a bit boring, but that’s how the dash 8’s looks like at my local airport – when all the planes are repainted)
Keep up the good work!
Ben
Ben_E is offline Find More Posts by Ben_E
Dash 8 airliner - Help please!! Ben_E Scale Kit/Scratch Built 66 Sep 07, 2011 05:56 PM
Firefly taking shape thulizulu Scale Kit/Scratch Built 21 Nov 30, 2002 07:47 PM
Taking shape of a cessna j_z_123 Parkflyers 8 Oct 23, 2002 10:31 PM
my MiG 29 taking shape Seagull Electric Ducted Fan Jet Talk 1 Apr 02, 2002 08:10 AM
Teenager....Twin KP44 taking shape steve glass Electric Ducted Fan Jet Talk 4 Jun 11, 2001 06:10 PM
