Old Sep 21, 2007, 09:04 AM
Letcraft is offline
Find More Posts by Letcraft
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
Help!
Longer servo arms?
Got this Lama V4 airframe/electronics that flys super..but..the stock ouput arms of the servo are clipped at the inner-most hole (outer holes were clipped off at factory, I guess?). Very little cyclic travel. If I put longer arms on the servos to get more throw will the blades then be likely to hit each other? Just would like a little more solid directional feel than stock..the stock seems way to mild. I especially notice that the way it is set up now, it sometimes takes full stick cyclic to even wade through a slight draft. What do you guys do to get a more lively cyclic? Thanks!
Edit: OK..I found the info but I don't want to spend $$s on longer inner shafts and custom flybars and CNC bits all over. Guess I will go with longer arms and dial in the servo end points till I get no blade interaction with full cyclic. Got to be better than stock..I would think.
Letcraft is offline Find More Posts by Letcraft
Old Sep 21, 2007, 11:45 AM
Letcraft is offline
Letcraft's Avatar
Mapleton, Iowa
Joined Feb 2006
Yep..had some old BCP servo arms..second hole out from center..super control and no blade interaction..this is more like it! The thing rips around now..hehe, absolutely delightful, total menace, indoors!
Old Sep 23, 2007, 03:29 PM
salvagerat is offline
Find More Posts by salvagerat
My jail picture
salvagerat's Avatar
Tucson,Az
Joined Aug 2007
yah you should probably get better servo arms then get the extreme blade cx tail boom. longer servo arms can get you more response which just means mor capabilities
salvagerat is offline Find More Posts by salvagerat
Old Sep 23, 2007, 03:58 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Closed Account
Joined Dec 2005
Letcraft .... what radio are you using?
Lou is offline Find More Posts by Lou
Discussion Longer servo arms for a Tower Pro SG50?? TTownFlyer Radios 0 Aug 21, 2007 05:48 PM
Discussion Longer Servo Arms For Waypoint W-092MB servos russ skinner Electric Plane Talk 0 Mar 05, 2007 06:03 AM
Where to find longer servo arms!!!! tdab 3D Flying 4 Jun 12, 2005 09:03 PM
Logo 10 longer servo arms.........? Jay Boyd Electric Heli Talk 10 Mar 13, 2002 10:49 AM
JR servo arms/ WINGO neal Electric Plane Talk 2 Apr 21, 2001 09:55 PM
