Old Sep 19, 2007, 05:31 AM
quax is offline
Find More Posts by quax
quax's Avatar
NRW, Germany
Joined Apr 2004
Mini-HowTo
Motor PWM to PPM impulse converter
For my coax heli I've build a PWM to PPM converter with an ATtiny13. I think, a little hint to that converter may also be placed here
http://home.versanet.de/~b-konze/koa...bl-koax_01.zip
Here is the original coax-thread:
http://www.rcgroups.com/forums/showthread.php?t=744169
cul
quax
quax is offline Find More Posts by quax
Old May 20, 2008, 12:26 AM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
Nice work.
Which file would I use for 5G6?
TIA
Dave
david_dewit is offline Find More Posts by david_dewit
Old May 20, 2008, 03:38 PM
quax is offline
quax's Avatar
NRW, Germany
Joined Apr 2004
My best experience was using the 10ms version. With the 20ms version the tail was swinging.
cul
quax
Old May 20, 2008, 03:55 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Need to file this away when I get home for future use.
village_idiot is offline Find More Posts by village_idiot
Old Jun 08, 2008, 04:18 AM
Australia
Joined Sep 2001
Hello quax,
What is value of cap on converter?
TIA
Dave
Old Jun 08, 2008, 05:06 AM
Almaz is offline
Find More Posts by Almaz
Almaz's Avatar
United States, IL, Chicago
Joined Nov 2006
That is great! By any chance do you have the code in basic? I don't have programmer for ATtiny13. I use microchips for my project with Enhanced JDM PIC programmer and would like to know more info how to convert it using PIC MicroChip.
Almaz is offline Find More Posts by Almaz
Old Jun 08, 2008, 12:33 PM
mcross is offline
Find More Posts by mcross
For Sale-everything over 250 g
Souderton Pa. USA
Joined Mar 2002
Hi quax,
I would also like to use a PIC chip, 10Fxxx if possible, for a single channel converter. I would like to use a brushless motor with the Parkzone Cessna brick rx/servos.
Thanks in advance for any help you can offer.
mcross is offline Find More Posts by mcross
Old Jun 08, 2008, 03:13 PM
quax is offline
quax's Avatar
NRW, Germany
Joined Apr 2004
Hi,
I think, a PIC version of the converter is also available out there in the web.
Because I'm not very familiar with PICs, but with AVRs, I made an AVR version. Maybe the code can be transferred to a high level language, but I don't know. The pulse generation needs a capture compare unit, but I think, they are also available unsing PICs
cul
quax
Old Jun 08, 2008, 04:14 PM
mcross is offline
Souderton Pa. USA
Joined Mar 2002
Thanks Quax,
All I can find are lots of servo pulse to motor PWM converters, I'll keep looking.
Old Jun 08, 2008, 05:53 PM
Australia
Joined Sep 2001
Originally Posted by david_dewit
Hello quax,
TIA
Dave
Old Jun 09, 2008, 02:49 AM
quax is offline
quax's Avatar
NRW, Germany
Joined Apr 2004
Hello quax,
TIA
Dave
Should be a ceramic 100nF cap, as it is used for circuits to block spikes.
cul
quax
Old Jun 15, 2008, 06:36 PM
Australia
Joined Sep 2001
I made converter as described for 5g6 2.4G and it is not working??? Studio4 said programmed ok. When powered up led on converter is solid for three seconds then starts flashing. Escs beep continueously, nothing from motors, servos work.?????? Tried all three programs 6ms 10ms and 20ms.
Dave
Old Jun 16, 2008, 02:07 PM
quax is offline
quax's Avatar
NRW, Germany
Joined Apr 2004
Hi Dave,
did you uncheck he CKDIV8 button?
cul
quax
Old Jun 16, 2008, 05:28 PM
Australia
Joined Sep 2001
Hi Berard,
Yes I did. Maybe I am not doing it properly.
I am using studio4 which has different fuse box. I might make pony prog programmer today and use that. I have programmed many many pics before and some avr.
Dave
Old Jun 16, 2008, 05:33 PM
Inciting Riots
Joined Dec 2006
Setting fuses in AVRStudio is pretty trivial.Try setting the divX8 fuse and see what happens. The uncheck the box and program it again. Which programmer are you using to program this chip?
