Old Sep 18, 2007, 01:41 PM
Maybz is offline
Find More Posts by Maybz
medium-sized Lewbowski
USA, CO, Denver
Joined Jan 2005
Mini-HowTo
Painting the EPP eagle
Here's how I painted my EPP eagle using spray cans and paper patterns.
Materials:
-Tracing paper or Vellum
-Super 77 glue
-Fusion brown (espresso)
-Fusion khaki
-Fusion black
-Fusion yellow
-scissors
I used these photos as reference.
Maybz is offline Find More Posts by Maybz
Old Sep 18, 2007, 04:29 PM
bat is offline
bat
Find More Posts by bat
bat
bat's Avatar
cincinnati
Joined Jun 2003
I gotta see this bird fly.
bat is offline Find More Posts by bat
Old Sep 18, 2007, 09:38 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
1 -I Drew a simple feather pattern on Vellum (tracing paper). You can use the same pattern for both wings. I chose to use a different pattern for the top and the bottom of the wing. Cut the pattern at key color change points. Also make a simple 'swoosh' shape that closely follows the shape of your feathers.
Old Sep 18, 2007, 09:43 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
2. TOP FEATHERS - It's best to work from light to dark, starting with the lightest colors first. I used Super77 to tack the cutouts to the foam. Lightly spray the paper and let the glue dry for 10~20 seconds before applying. If you stick it too soon you will get glue residue on the foam, too late and it simply won't stick. I started by painting the long feathers first. I laid down a khaki base and then started adding shape using the swoosh template and brown paint.
Old Sep 18, 2007, 10:07 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
3. TOP FEATHERS - I kept adding layers of darker colors - eventually adding black at the feather tips and along the sides. I used the same swoosh pattern throughout the entire process - although I had to make a better one from cardboard after the paper one gave out. Occasionally stop to wipe the dripping paint from the template. Lastly, I added a single khaki stripe to each feather using the slit template.
Old Sep 18, 2007, 10:16 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
4. TOP FEATHERS - After finishing the big feathers I moved on to the outer LE feathers. I covered up my work with the paper pattern and a light coat of 77. Krylon Fusion sticks very well to the foam so no worry about peeling paint. I used brown and black in this area and then followed up with some khaki highlights. I also added black shadows between the major color changes.
Old Sep 18, 2007, 10:21 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
5 TOP FEATHERS - I did the wing root/LE last and started by applying a brown base coat. To give the effect of lots of little feathers I moved the root paper pattern forward a few inches and then sprayed right along the edge of the paper. I then repeated this all the way forward to the LE. I then went back and did the same thing using black - but with much lighter applications. Once satisfied with the results I did my best to repeat everything on the right wing top.
Old Sep 18, 2007, 10:30 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
6 BOTTOM FEATHERS - for the bottom side I decided to start at the root (remember, this whole thing is an experiment). I laid down a brown base coat using a criss-cross pattern to try and add more 'feather' effect. I then started adding small feathers using the same technique as before - shifting the paper pattern a few inches and then spraying right along the edge. I used brown first and then went back again with black. It doesn't take much paint to get the effect - light coats will usually do the trick.
Old Sep 18, 2007, 10:33 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
7 BOTTOM FEATHERS - I moved on to the middle section next using only a light dusting of brown followed by brown accent lines. I used my slit pattern to make the accent lines.
Old Sep 18, 2007, 10:38 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
8 BOTTOM FEATHERS - The big feathers came last this time. I used the same technique as the top side but with less paint and fewer colors. I started with brown edging to set the spacing, then added khaki filler lines, then went back with more brown and finally black at the tips and shadows. I used the swoosh and slit cut for everything. The bottom wings are lighter than the top both for realism and for easier orientation when flying (in theory at least). Again, I reused the paper patterns to mask finished areas.
Old Sep 18, 2007, 10:42 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
9 BOTTOM FEATHERS - last step on the bottom was to go back and add black shadow lines between major feathers groups. I used the same paper patters but left a deliberate gap between them where I wanted a black line. Your swoosh should be pretty paint-soaked at this point so you might let it dry before starting on the other bottom wing half. After finishing both sides I went and sprayed all around the the LE and TE with black to cover any remaining white foam.
Old Sep 18, 2007, 10:55 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
10 - BODY AND TAIL FEATHERS - I forgot to take pictures while painting these parts but by by now it should be easy to see how I did it just by looking at the finished pictures. The process is the same as the wing. I started with the yellow beak and feet using paper templates to mask the white areas. The beak tip has some orange on it and I chose to paint the motor also just to hide it better. The main body is brown with black feather accents using the same edge-painting process. The tail feathers are mostly bare foam with just a few khaki accent lines (yup, same swoosh pattern). I also added some khaki accents around the edge of the beak and between the brown and white using the same paper patterns but moved 1/4".
Old Sep 18, 2007, 11:03 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
Here are a few more pics of the finished project along with more reference shots. Total time was 5~6 hours including making a second pot of coffee and quick trip to Ace to get more paint. I used no Sharpie pens or masking tape and was back in the air the same day that I started.
Old Sep 18, 2007, 11:35 PM
Maybz is offline
USA, CO, Denver
Joined Jan 2005
Here's some vid I shot this evening at the park...
http://www.rcgroups.com/forums/showt...85#post8203666
Old Sep 19, 2007, 03:40 AM
rjarois is offline
Find More Posts by rjarois
rjarois's Avatar
royal oak, michigan
Joined Sep 2004
maybz, very good instructional for feather painting!! good job. randy.
rjarois is offline Find More Posts by rjarois
Question EPP Eagle? IPFlyer Foamies (Kits) 4389 Aug 14, 2016 09:45 PM
Question Painting EPP zippogeek Foamies (Kits) 9 Mar 21, 2015 11:57 AM
Discussion EPP Eagle fuzzyhead Foamies (Scratchbuilt) 2 Sep 28, 2008 09:54 AM
Discussion decorating and painting EPP poker_run Foamies (Scratchbuilt) 5 Aug 12, 2007 09:03 AM
Discussion Painting EPP? Tram Foamies (Kits) 12 Jun 27, 2007 12:06 AM
