Old Nov 27, 2002, 03:53 PM
Fitz Walker is offline
Find More Posts by Fitz Walker
No "R" !!!!!!!
Fitz Walker's Avatar
United States, TX, Houston
Joined Jan 2000
Rant
OK, I give up. Where is this LiPoCalc???
A time consuming search only turns up one dead link. Does it really exist?
-FTZ
Fitz Walker is offline Find More Posts by Fitz Walker
Old Nov 27, 2002, 03:56 PM
Buckey29 is offline
Find More Posts by Buckey29
Indianapolis, IN, USA
Joined Oct 2000
Yes it does:
http://www.rtideas.com/lipocalc/
Curious, are you looking to fly your Corona on LiPo yet?
Buckey29 is offline Find More Posts by Buckey29
Old Nov 27, 2002, 10:27 PM
No "R" !!!!!!!
Joined Jan 2000
Buck,
Thanks, but that link is deader than a doornail in Denver.
No, the Corona is um... semi-retired. But I may try to slap it together to do some testing.
Old Nov 27, 2002, 10:38 PM
David Hogue is offline
Find More Posts by David Hogue
Blew out my flip flop
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
Worked for me, just now?
Later,
David
David Hogue is offline Find More Posts by David Hogue
Old Nov 28, 2002, 12:04 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
All I get is "document done", and a blank screen.
Sparky Paul is offline Find More Posts by Sparky Paul
Old Nov 28, 2002, 08:37 PM
USA, NC, Clayton
Joined Feb 2001
I still get it fine...what browser you guys using? I can get it with either IE or Netscrape
Hmm,
David
Old Nov 28, 2002, 08:51 PM
stuka is offline
Find More Posts by stuka
Marshfield, Wisconsin, United States
Joined Sep 2002
C?
What does the Field in lower right after volts 3.7 indicate?(Cells, charge rate?).
And I'm having a hell fo a time picturing 2s3p configurtations. Any links to pictures of different configuarations realted to the nomenclature xSxP? Hooking two two cells packs at 7.4 volts each, and hooking em up parralel, I can figure for 8 amp discharge applications. Could you take two seried packs at 7.4ovolts each, and use a y cable set up to create a four cell paralel pack. That way you could charge both packs individually, cable in parraele for use and then uncable and charge and not worry about charging paralel packs and the inherent problems associatied therin. ?Looks like a wrote a book!
stuka is offline Find More Posts by stuka
Old Nov 28, 2002, 10:20 PM
Ascended Master
Palmdale, CA
Joined Oct 2000
Hmm,
David
I'm using Netscape 4.7.9
I can't get onto rcairport anymore with it.. they've changed to Netscape 7 compatible.. I tried 7. POS.
Old Nov 29, 2002, 01:28 AM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Works for me on Opera 6.01.
"C" is capacity. For example, running a 1020 mAh cell at 3.06A (3060 mA) is running at 3C. LiPolys are said to be good for 3-3.5C continous and 5C or a bit more in short bursts.
BEC is offline Find More Posts by BEC
Ok I give up... toofastdave Vendor Talk 14 Aug 11, 2003 12:13 PM
Is it time to give up on this plane? soholingo Electric Plane Talk 22 Jun 24, 2003 02:37 PM
OK, I give up... JCastle Site Chat 3 Mar 13, 2002 04:49 PM
