Old Sep 19, 2007, 09:14 AM
pbunnstf is offline
Find More Posts by pbunnstf
Joined May 2006
That look like an unregulated power supply. The voltage will quickly squat with light loading down to 13-14 volts. You are reading the unloaded peak voltage with no load connected.
pbunnstf is offline Find More Posts by pbunnstf
Old Sep 19, 2007, 02:18 PM
ImaBiggles is offline
Find More Posts by ImaBiggles
Master of 1 point landing
Naperville, IL
Joined Jul 2005
In looking at the PS - it is unregulated and I seriously doubt it is properly protected from thermal overload or even fused. I know you think you got a good deal, and perhaps it would be fine if you stuck a fuse on it and ran some outdoor lights.
For your charger - you would be much better served converting an old PC power supply (as little as $5) to feed your charger.
Lots of links in these forums on how to do that. Takes only a couple of minutes.
ImaBiggles is offline Find More Posts by ImaBiggles
Old Sep 19, 2007, 06:56 PM
finishman2000 is offline
Find More Posts by finishman2000
nooobama
United States, PA, Stroudsburg
Joined May 2004
it is fused and is now working fine. I troed a computer ps and din't like it much.
finishman2000 is offline Find More Posts by finishman2000
How to make own Power supply at home? convert from PC power supply? HumbleBoss Batteries and Chargers 16 May 01, 2016 02:13 PM
Question Starting PC Power Supply (AT) bergfalke4 Batteries and Chargers 14 Apr 26, 2016 07:57 PM
Help! PC Power Supply AT the same as ATX? Craig Mckinley Batteries and Chargers 3 May 21, 2007 02:56 AM
12v power supply outputting 15v? malor Batteries and Chargers 5 Jun 09, 2004 01:52 PM
Wanted: IBM Think Pad Power Supply (2A 15V) juantrinidad Batteries and Chargers 2 Feb 11, 2003 05:10 AM
