Old Sep 16, 2007, 06:07 PM
dlabrie is offline
Find More Posts by dlabrie
White Mountains in NH
dlabrie's Avatar
In the White Mountains of NH
Joined Dec 2006
Question
Letters on prop sizes: RD, DD, HD, EP, Etc.
Can anyone tell me what the various letters on the prop sizes mean?
David
dlabrie is offline Find More Posts by dlabrie
Old Sep 16, 2007, 06:27 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
David
In what context? Props are measure by their diameter and pitch, with diameter listed first. There are various kinds as well, like Slow Fly, Thin Electric, Wood, etc... the letters you listed are probably manufacturers codes... like GWS uses "EP" on some of theirs... like the EP1060 that comes with a Slow Stick... it's a 10x6.0 Electric Prop as far as I know. Other manufacturers use different letters. APC uses E on some and no letters on others, like the "Slo Flyer" props have no letters, only a measurement like 9x4.7, which means 9inch diameter and 4.7 inch pitch.
4.7 inch pitch means the prop would pull forward 4.7 inches with each rotation if there was no resistance.
jasmine2501 is offline Find More Posts by jasmine2501
Old Sep 16, 2007, 06:50 PM
Laggard is offline
Find More Posts by Laggard
Wind blows
Laggard's Avatar
Minneapolis
Joined Jan 2007
Just a guess:
HD = Hyper Drive
DD = Direct Drive
EP = Electric Prop
Laggard is offline Find More Posts by Laggard
Old Sep 16, 2007, 10:31 PM
chalmrast is offline
Find More Posts by chalmrast
Gilbert, AZ
chalmrast's Avatar
Gilbert, AZ
Joined May 2007
I never understood the difference between the DD & HD GWS props. They both look the same to me .
chalmrast is offline Find More Posts by chalmrast
Old Sep 16, 2007, 10:49 PM
sting35 is offline
Find More Posts by sting35
I need more ceiling!!!
sting35's Avatar
Okinawa, Japan
Joined May 2006
Well, I found out (the hard way) that APC 8x6P means Pusher.
sting35 is offline Find More Posts by sting35
Old Sep 16, 2007, 11:16 PM
NoFlyZone is offline
Find More Posts by NoFlyZone
Joined Jul 2006
The letters on a GWS prop mean absolutely nothing. Here are two GWS props.
Upper prop is a GWS EP-1060
Lower prop is a GWS EP-1080
This is why GWS props are used to stir epoxy at my house...
Chuck
NoFlyZone is offline Find More Posts by NoFlyZone
Reply With Quote  (Disabled)
Old Sep 16, 2007, 11:40 PM
Rocket Programmer
Joined Jul 2007
Chuck
They sure do look different... same diameter, but the top one has a pitch of 6 and the bottom one has a pitch of 8... it might need that weird shape to get the higher pitch correct but I'm not sure. Those letters are just part of the stock code.
Old Sep 16, 2007, 11:44 PM
Joined Jul 2006
Well.... like I said... the letters tell nothing about the prop... EP just means "Electric Prop".
Chuck
Old Sep 17, 2007, 05:34 AM
dlabrie is offline
dlabrie's Avatar
Joined Dec 2006
Thanks for the responses.
I understand the length and pitch numbers, but had no idea about the Letters. I guess I won't worry about them when I order props; other thean the P for pusher
Old Sep 17, 2007, 05:47 AM
abenn is online now
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Maybe you shouldn't worry about them, but you should be aware.
Two letters which I'm aware of are EP (or just E) and SF, which stand for Electric Power and Slow Fly: They mean that the props are designed lighter -- for use in electric models, where there isn't motor vibration -- and shouldn't be used on glow models because they risk breaking up. I believe they're also shaped differently from "normal" props so that they will work more efficiently at the relatively low rpm most electric motors work at compared with glow.
abenn is online now Find More Posts by abenn
Old Sep 17, 2007, 07:49 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Chuck
The upper one is what I would call a 10x6 GWS HD (hyperdrive - though somehow even some of these larger diameter props in this series are listed as DD - direct drive). I use my own terminology and call only the 4" or smaller props with square blades DD (e.g. the 3x2, 4x2.5 and 4x4) - all the rest with the same blade shape as this 10x6 (even as small as 3x3, 4.5x3) I call HD. The larger props in the HD series are safe to about 80,000rpm/diameter (maybe more - I had an 8x4 at 13800rpm (110,400rpm/diam!) the other day - that was close to its limit!).
The lower prop is a 10x8 GWS RS (reduction series) - often incorrectly called a slowflyer (which has long been the Landing Products designation for their APC SF series). These RS series props - especially the larger higher pitched varieties are not very safe above ~40-50,000rpm/diam.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Sep 17, 2007, 11:18 AM
Joined Jul 2006
Hi Dr. Kiwi,
I'm printing out your response and tacking it to my workshop wall. Thank you very much for an excellent breakdown!
Chuck
Question Prop on left or right DD tail? pike Micro Helis 7 Apr 06, 2005 12:42 PM
Question Sp350 DD prop sizes Smokin' Beaver Power Systems 0 Feb 06, 2004 02:58 AM
Safe to use APC SF prop on AXI 2808/24 DD? carguy Power Systems 3 Jun 23, 2003 03:41 PM
DD prop sizes Hodgepodge Sport Planes 0 Sep 17, 2002 05:29 PM
Question about prop sizes JetJohnny Beginner Training Area (Aircraft-Electric) 4 Jun 24, 2001 09:52 PM
