Old Sep 16, 2007, 05:58 PM
N227CT is offline
Find More Posts by N227CT
N227CT's Avatar
Lubbock, TX
Joined Feb 2007
Help- tightening down prop/spinner with cowl?
Okay guys, need some advice. Every plane I have been building lately has been a 3D or pattern type that has a cowl. Is there some technique that I'm missing on getting the prop/spinner tightened down onto the outrunner while the cowl is on? The only way I've found is to take off the hold down screws on the cowl and move it TOWARDS the canopy giving me room to clamp down on the front part of the outrunner or hub so I can tighten down the prop spinner combo. Any advice would be greatly appreciated!!!
John
N227CT is offline Find More Posts by N227CT
Old Sep 16, 2007, 06:12 PM
Malves is offline
Find More Posts by Malves
Joined Jun 2004
That's how I always do, too. I always wanna make sure that thing is tight on, even if it means a lil more work.
Malves is offline Find More Posts by Malves
Old Sep 16, 2007, 09:04 PM
N227CT is offline
N227CT's Avatar
Lubbock, TX
Joined Feb 2007
I just wished they'd made some rubber coated pliers so it wouldn't scrach up the propeller hub.
Old Sep 16, 2007, 09:27 PM
Malves is offline
Joined Jun 2004
There's a product called Plasti Dip that you can coat a plier with for that purpose. Do a search on the net or your local hardware store.
Old Sep 17, 2007, 07:30 AM
Pistolera is offline
Find More Posts by Pistolera
I got it! I got it!
Joined Mar 2006
I've never had a need to hold the motor or prop adapter hard. I just reach into the cooling air opening with 2 fingers on the motor and snug up the prop nut. The direction of rotation of the prop vs the nut will ensure that it doesn't loosen up, and actually tightens up a bit further with running.
Just my experience....Earle
Pistolera is offline Find More Posts by Pistolera
For Sale Folding Prop spinner with prop tomi Aircraft - Electric - Airplanes (FS/W) 2 Oct 24, 2005 06:11 AM
Can't find this prop/spinner, help! Ray280 Electric Plane Talk 3 Feb 14, 2004 07:58 AM
Question Vario Prop Hubs with Spinner? kelvin Power Systems 5 Dec 21, 2003 11:26 PM
FS: Phasor 45/3 Brushless motor and Jeti 70/3P SC with prop and spinner gavoss Aircraft - Electric - Airplanes (FS/W) 0 Sep 06, 2002 10:08 AM
For Sale TERRY with prop and spinner j porter Aircraft - Electric - Airplanes (FS/W) 0 Nov 22, 2001 12:16 PM
