Old Sep 16, 2007, 05:35 PM
Helge is offline
Find More Posts by Helge
Stavanger Norway
Joined Sep 2007
Question
Hardwire tx-rx ??
Hello i am playing around with an idea to build a rc ROV and i want to connect the reciever to the transmitter with a cable so that i can dive the sub to, lets say 100m. Anybody got any ideas
Helge is offline Find More Posts by Helge
Old Sep 16, 2007, 08:18 PM
xorcise is offline
Find More Posts by xorcise
NYC
Joined Jun 2006
With that length of cable you might consider a balanced line system such as RS485, which uses standard RS232 protocol and some line control. It's a simple 2-wire bus system with, for example, LT485 IC's as the line interface to the microcontrollers.
xorcise is offline Find More Posts by xorcise
Old Sep 17, 2007, 12:07 PM
Helge is offline
Stavanger Norway
Joined Sep 2007
I have read about rs-485 and it would be perfect, but i do not know a lot about microcontrollers.. can it be used to connect a transmitter to a reciever, or do you need to program a pic and make the system from scratch? I want to keep the system simple and prefferably have all the capabilleties as integrated in a modern radiosystem.
Old Sep 17, 2007, 01:29 PM
xtal is offline
Find More Posts by xtal
xtal's Avatar
McDonough, Georgia USA
Joined Feb 2005
How big of a sub/rov or how much power will you need to
pull a 100 meters of cable thru the water...the cable
has to be strong enough to handle the stress, the sub/rov must be able to handle the weight,,, this could become very interesting..............
You probably could attach a differential driver chip to an RC encoder for the control end[send ppm differentially over twisted 2 wires] to a differential reciever chip[or voltage comparator ] attached to a rc decoder chip and use ppm for control. Could also use opto isolators..
Resonable simple and should work....
And since you are hard wired you can expannd the # of channels to ??? [ dependant on noise pickup from differential cable in water, I don't have a clue]
xtal is offline Find More Posts by xtal
Old Sep 17, 2007, 02:11 PM
Helge is offline
Stavanger Norway
Joined Sep 2007
Yepp, this can be interrestng, the rov will be aprox 100x60x40 with 6 thrusters, and will be fitted with a camera and compass, the power wil probably come from two big Lipo packs, and the main body will be made of 3M Glass bubbles mixed with epoxy resin for bouyancy. the mechanical parts is not the big problems, as i have access to the machinery to make the parts i need, my biggest challange will be the controlls.
The way i see it i wil need to have two twisted pairs down one for controls and one for camera, and the drag from the cable wil not be too much as long as it is close to neutral in water.
The first thing to adress must be the ppm, how to exstract it from the transmitter and put it in to the reciever
The ppm can probably be taken from a trainer cable, but do anyone know how to connect it to the reciever??
Ok, Did some research.. i can locate the ppm ether from the trainer outlet, or between the multiplexerchip and the rf bord, and the same for the reciever..
ordering the controller now...
Old Sep 17, 2007, 06:26 PM
xtal is offline
xtal's Avatar
Joined Feb 2005
for ppm ..feed ppm to cable thru driver then you don't need a receiver,,, just a decoder and a circuit to convert the signal to a compatible input for the decoder....pic source code&hex files are available several places on net -- Bruce Abbott site and others
You may be able to kiil 2 birds with 1 stone ...by modulating a dc bias with ppm and and adding video on the rcvr end ...of course then more noise possibilities .......there may already be circuits on the net for this???
probably the most important is just how do you want to communicate
PPm, I2c, asyn Serial, so-on-so-forth. How many control channels would you need....
I think ppm would be a quick solution and easy to test..
I would probably try to use opto isolaton on trainer port if ppm is there.
Trainer port-->isolator/driver---cable---->rcvrchip-->decoder--->channels
Old Sep 18, 2007, 12:57 AM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
If you get a receiver with the DSC port (direct servo connect) you can get a cable that will plug directly from the transmitter to the receiver. Then you'd simply need to extend that cable(within reason) and it would be good to go. I know Futaba makes such a setup.
There are probably cheaper ways if you want to modify some stuff or build a circuit but they wouldn't be as simple.
TheSteve is offline Find More Posts by TheSteve
Partenavia Tx/Rx & Setup Questions cactus Foamies (Kits) 3 Oct 04, 2001 06:52 AM
Wanted- 3-4 ch tx/rx GaryO Aircraft - Electric - Airplanes (FS/W) 2 Sep 27, 2001 09:46 PM
tx, rx , crystal questions Clifford B Electric Plane Talk 37 Sep 25, 2001 08:29 PM
Wanted: Old "Cheap" TX & RX DeweyBob Aircraft - Electric - Airplanes (FS/W) 1 Sep 10, 2001 08:19 PM
need heli.i have gyro,tx,rx,hs81mgs,batts allready Kevin Graehl Electric Heli Talk 9 Aug 03, 2001 01:07 AM
