Old Sep 16, 2007, 09:05 AM
HoverBovver is offline
Find More Posts by HoverBovver
Scarecow
HoverBovver's Avatar
UK
Joined Sep 2004
Gun barrel mantlet fix
The gun barrel mantlet on the HL Tiger is the wrong way round.
This requires a virtual total strip down to get access to the turret section.
Part 1. Lower hull disassembly...
HoverBovver is offline Find More Posts by HoverBovver
Old Sep 16, 2007, 10:54 AM
Scarecow
UK
Joined Sep 2004
Gun barrel mantlet fix...Part 3
Now the main course.
Part 3. Engineering a solution...
Old Sep 16, 2007, 04:32 PM
Scarecow
UK
Joined Sep 2004
Upgrading to metal rear idle wheels
Replacing the plastic rear idle wheels with metal...
Old Sep 23, 2007, 05:30 PM
cpt.bhern is offline
Find More Posts by cpt.bhern
Joined Sep 2006
Thanks for the info. HoverBovver,these are things I am going to do very soon.
I got my HL Tiger 1 about a month ago,and have not done much with it as yet.
cpt.bhern is offline Find More Posts by cpt.bhern
Old Sep 24, 2007, 05:19 AM
Scarecow
UK
Joined Sep 2004
There's more to come...watch this space.
Feel free to add any hints or tips here.
Old Sep 25, 2007, 06:24 PM
modfly is offline
Find More Posts by modfly
Doing it in the Lateral Axis
modfly's Avatar
United States, OH, Cleveland
Joined Dec 2006
nice..takes a lot of time for all this..thanks!
modfly is offline Find More Posts by modfly
Old Sep 30, 2007, 12:50 PM
Scarecow
UK
Joined Sep 2004
Metal suspension arm + Metal wheel upgrade...Part 2
I'm installing metal wheels modelled round those produced for late model Tigers with no external rubber. On these Tigers the outer most row of wheels was not installed.
Part 2. Installing metal wheels...
Old Oct 12, 2007, 05:02 PM
Scarecow
UK
Joined Sep 2004
Suspension spigot mod.
When you've installed a bunch of heavy metal stuff this is a must upgrade to the HL tiger...
Old Oct 14, 2007, 06:59 PM
sa80 is offline
Find More Posts by sa80
Joined Oct 2007
hi guys, while surfing the net i came across this site and after seeing hoverbovver,s tiger i had to get one, i mainly do 1/35 scale models, (german armour) but i think things have changed now! looks like i,m into the big boys toys, i know NOTHING about RC tanks and have a few questions they may seem stupid to you but here goes. after looking at the pics i want to remove the LED in the tiger mantlet, if i do this will my tiger still work? and how do i take it out,do i just cut the wires ? is my tiger waterproof ? and is the L shaped strips of aluminium something you made or can you buy them ? i want to repaint my tiger do i have to strip out the insides? ( i would prefer not to ) i dont wanna mess anything up. many thanks, ps i have the 1/16 heng long tiger with smoke and sound!
sa80 is offline Find More Posts by sa80
Old Oct 15, 2007, 07:32 AM
Scarecow
UK
Joined Sep 2004
Yep you can just cut the wires of the LED and everything else will still work.
Nope its not waterproof at all. There are many holes in the lower part of the hull for the suspension and various switches and the battery bay will let in water. You can make it fairly water resistant by moving all the switches, sealing all the holes and either repositioning the electronics or taping polythene around lower boards. Even with those mods I would avoid deep fording.
I use some scrap alu strips I had which I cut to size & drilled but I've seen kits on ebay that include pre-cut aluminium, correctly sized brass spigots. Keep a look out.
You don't have to strip out the electronics to paint your tiger, you just need to ensure that exposed parts that you don't want painted are masked off. However to get the best finish its much easier to handle the separated plastic shells and more-so without having to mask off internal components.
Help! looking for heng long mad truck parts thorpe31 Off-road Cars 23 Apr 13, 2014 11:38 PM
Heng Long RC Tiger tank CarreraGTSCS RC Tanks 23 Aug 04, 2010 05:41 AM
