Old Nov 12, 2012, 06:49 PM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Originally Posted by bill henderson View Post
hi ,what thrust angle did you use and how did you determine location on the fire wall i have the power 90 ,regards bill in ontario canada
About 2 degrees down and 2 deg right (washers glued to back of Electra-Fly {Great Planes} motor mount). Smeared some silicone RTV on firewall, set mount (with motor mounted, of course) on firewall, fit cowl in place (fuse vertical), then centered the prop washer in the hole! Let it sit that way for a few hours, remove cowl, marked holes...pried loose from RTV....cleaned it off....
Hope this helps!
Regards,
Gary
bamaguy is offline Find More Posts by bamaguy
Old Nov 21, 2012, 12:43 PM
airega1 is offline
Find More Posts by airega1
Norfolk Intl, Virginia, United States
Joined Jan 2004
Nitro models tucano
Hi, any idea where to get a new canopy for this plane?
airega1 is offline Find More Posts by airega1
Old Nov 21, 2012, 03:31 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
New Canopy? I have one, but it comes with the plane.
Wind_of_Change is offline Find More Posts by Wind_of_Change
Old Dec 17, 2012, 10:09 AM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Any videos of this flying? I am considering using this for an FPV formation flying group.
techspy is offline Find More Posts by techspy
Old Dec 23, 2012, 04:17 PM
airega1 is offline
Joined Jan 2004
Hi did you get instrctions with your kit?
Question Embraer Tucano or Shorts Tucano mamethot Scale Fuel Planes 3 Aug 13, 2007 05:07 AM
Embraer TUCANO 312F from CAM TGSN Slope 8 Feb 08, 2005 01:39 PM
FS: Embraer Tucano ARF NIB gouda Aircraft - Electric - Airplanes (FS/W) 4 Jan 18, 2005 09:28 PM
FS/T: Het Embraer Tucano, typhoon 6/20 & aluminum spinner SeanJ Aircraft - Electric - Airplanes (FS/W) 11 Jan 17, 2005 02:21 AM
