Old Nov 10, 2010, 06:26 AM
fredo21 is offline
Find More Posts by fredo21
Never too much detail
fredo21's Avatar
Australia, VIC, Hampton
Joined Jan 2007
Mine is still in a box Gary. Unfortunately there are two or three planes ahead of it in the build Q. Still planning on electric, HK air retracts. Considering a HobbyKing 50-65B 400kv using 8S. Mine is retract ready but I am planning on moving the front gear forward into the cowl and adding gear doors. Oh and planning on repainting it black like the RAF version. Lots of plans, we will see when I actually get into it. Weight is a concern, as I am planning on glassing the flying surfaces with 25g cloth.
Anyway will be great to see how your one goes.
Stuart
fredo21 is offline Find More Posts by fredo21
Old Nov 10, 2010, 09:37 AM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
I'm going to move the nose gear forward, using one of my many "extra" motor mounts as well. I'll start on it this weekend, but completion will have to wait a bit before as I need to afford the $190 for those e-flite electric retracts! I have a unused air retract system, but I prefer to go electric on this bird.
Your black version will really look cool! I wish my 69 year old eyeballs were good enough to fly it! I need all the color I can get.
bamaguy is offline Find More Posts by bamaguy
Old Nov 12, 2010, 03:38 AM
fredo21 is offline
fredo21's Avatar
Joined Jan 2007
Hi Gary,
Some of them have a bit of yellow trim.
Stuart
http://www.militaryairshows.co.uk/new/lowlevel.jpg
RAF Tucano Formation - All Saints 'Pure Shores' (4 min 24 sec)
Old Nov 12, 2010, 09:51 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
Thanks for posting the video, Stuart. My Tucano Shorts T-1 (Airshow scheme) arrived today. Everything seems to be in good order, but there are a couple of fuse formers that will receive some additional adhesive. Unlike a few other versions of this NitroPlanes Tucano ARF, mine came "retract-ready". Also, the guide tubes for the rudder and elevator control were missing as reported by a few other folks. All things considered, it is an outstanding buy at NP's current sale price of $130!!! This plane REALLY looks cool. The photos don't do it justice. The instructions are very poor, but anyone who has built a few "kit planes" won't have problems. It is NOT your typical Great Planes, Hanger 9, or E-Flite ARF in the instruction arena!
I just may put in my Saito 100 four stroke instead of taking the E-Flite 110 and related electronics out of my Epic LT (also from NitroPlanes) just yet. I'll convert it at a later date. I still really like the Epic and the Saito should do a decent job of pulling the Tucano around...it just won't go vertical forever like it would with the EP setup.
Gary
Old Nov 12, 2010, 10:34 PM
hawkerone is offline
Find More Posts by hawkerone
hawkerone's Avatar
Joined Apr 2010
I'm well into the build on my Grey Tucano. It came retract ready, but I'm going with fixed gear and have a new ASP 120 4S I'll be using. It does not have the tubes for the elev/rudder installed and while it came with blocks and wire main gear, there's no nose gear in the box. The nylon mounts are included, just no strut. The wing is covered with a slick white China cover and then painted with grey paint, which chips very easily. Instructions just about aren't. This is not an easy build. It should look sharp flying, but with the small wings I'm looking at it's going to be a hot lander.
Getting the engine aligned is going to be a bit of a fiddle. Their 'instructions' show lineing it up on an 'X' molded on the firewall. On the model, there's no 'X'. So nothing comes easy here.
hawkerone is offline Find More Posts by hawkerone
Old Nov 17, 2010, 04:48 PM
Wind_of_Change is offline
Find More Posts by Wind_of_Change
More Combat Please!
Wind_of_Change's Avatar
Utah
Joined Dec 2003
Hey guys,
I'm subscribing to this thread because I just picked one of these up... out of the dumpster at a fly-in event. A guy built it, maidened it, and somehow rolled it over on his first landing and landed on it's head. The canopy & cowl were slightly scratched and the tip of the rudder broke off, but those are easily repairable things.
I'm really not a fan of gray airplanes, if only because I can't see them in the air, so I'm doing a custom paint job on mine... something sporty looking.
I'm a bit miffed that this one doesn't have wheel wells. Usually you can do one or the other, but this one apparently has NO allowance for retracts. I may just have to modify it. What's the point in doing a custom color scheme if the thing's flying around with it's "pants down" so to speak. Right?
Anyway, looks like I'm joining the Tucano club... even though I've got a perfectly good EMS PC-21 sitting in the box waiting to be built. This'll be a good warm-up plane for that, at a fourth the price in gear.
I've got a Monster 110 in there with an HV80 Castle ESC, will be pushing 10S 4000mah packs on a 13.4 x 13.5 APC three-blade prop.
I'm a bit sad that the guy I got this from didn't have the guns on it, and I have no idea how to get ahold of him. Any of you guys not using your wing guns that would be willing to part with them?
Wind_of_Change is offline Find More Posts by Wind_of_Change
Old Nov 17, 2010, 05:50 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
I just bought the "Airshow (blue/yellow/light gray bottom)" from Nitroplanes. Mine is the "retract ready" version...so I won't have to do surgery on the wings, just add some additional glue to the retract beams. See ScaleBrads progress starting at post #9.
As I mentioned in my earlier post #30, I'm going to power it initally with a nearly new Satio 100, and later with my E-Flite 110 on 8S/4800mAh-35C out of my Epic LT. That setup pulls the LT around with great authority on a two blade APC. Will try a 3 blade shortly.
I am not going to use the gun/gun pods on this model. You may have them for whatever it costs to ship to Utah
Old Nov 17, 2010, 06:11 PM
More Combat Please!
Utah
Joined Dec 2003
bamaguy,
Sweet! I'll PM you my address so you can check on USPS online to see what it costs to ship. Slowest method possible is fine. It'll be a week or two before I'm ready to mount them.
A friend of mine flew his Tucano this weekend at an airshow I went to, he was doing about 130 mph flying on 12S with a Power110 with an APC 13x13 4-blade pattern prop. That thing HAULED BUTT!
Old Nov 18, 2010, 11:34 PM
More Combat Please!
Utah
Joined Dec 2003
Would any of you guys with the retract ready version be willing to take pics of the wing bottom gear mount & wheel well from a couple angles, as well as the nose wheel well for me? It'll speed up the hack job I've gotta do on this plane to get retracts in it. (shudder). TIA.
I'm starting in on a custom paint job on mine this weekend. Gray just doesn't cut it for me, but it works great as a primer base!
Old Nov 21, 2010, 06:53 PM
bamaguy is offline
bamaguy's Avatar
Joined Feb 2009
Adding Retracts
Again, check Scale Brad's postings earlier in this thread, starting with post #9 as to how he did his retract installation. Here are some photos of my wing witch was "retract ready". Note the novel method he used for the nose gear...an excellent idea; it's virtually impossible to get in the nose and install rails to mount the nose gear, anyway. Besides, the end result of his method is more "scale", especially with a 105 degree retract. You will want 85 degree for the mains as the wing has quite a bit if dihedral.
Old Nov 22, 2010, 11:08 AM
More Combat Please!
Utah
Joined Dec 2003
Thanks for the pics, Bamaguy, those are very helpful.
Gonna be a bugger to do, especially the nose gear.
I really like the lower exhaust stacks on the planes in that video. I wish they'd have done that on this model.
Old Dec 07, 2010, 09:28 AM
rcyogi is offline
Find More Posts by rcyogi
Joined Dec 2010
Hey guys,
I also just got this plane, was not too happy with the paint on the fuse, and got all clean up with this awesome paint remover. Plane look really good for
$130. I have a Magnum 90, and an OS 120. Will the 90 be enough? If I put the 120 I will have to butcher the cowl
rcyogi is offline Find More Posts by rcyogi
Old Dec 07, 2010, 09:35 AM
rcyogi is offline
Joined Dec 2010
Old Dec 07, 2010, 09:41 AM
More Combat Please!
Utah
Joined Dec 2003
rcyogi,
To post pictures, click the edit button on your last post, then click the "manage attachments" button under "Additional Options". That's the easiest way to add several images.
Old Dec 07, 2010, 09:59 AM
rcyogi is offline
Joined Dec 2010
Thanks!!! That was easy!
Question Embraer Tucano or Shorts Tucano mamethot Scale Fuel Planes 3 Aug 13, 2007 05:07 AM
Embraer TUCANO 312F from CAM TGSN Slope 8 Feb 08, 2005 01:39 PM
FS: Embraer Tucano ARF NIB gouda Aircraft - Electric - Airplanes (FS/W) 4 Jan 18, 2005 09:28 PM
FS/T: Het Embraer Tucano, typhoon 6/20 & aluminum spinner SeanJ Aircraft - Electric - Airplanes (FS/W) 11 Jan 17, 2005 02:21 AM
