Old Jul 18, 2009, 02:58 AM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by crhammond
I flew my Spark for the first time today. Easy to takeoff and land and flies like a pattern plane - very nice.
Mine is way slow on the TP Prolite V2 10s 20c/40c packs. Also my gear needed convincing to go up and down (inverted and push helped them.)
Minor mishap on landing - I should have had some more grease on my brakes cause when I applied them they locked up and the 5/32 wire holding my struts on sheared off on the next crack in the runway. My fault for making the flat spots too big. Luckily I had tip protectors on and the damage was fairly minor (the wheel punched a small hole in the belly and I one stab got the 6-grit treatment.)
It's all fixed up for a Jet rally this weekend. I shimmed and lubed the retracts and they are working a lot better now. I hope to get a bunch of flights on Sunday. I have some XPS 5s 5000 30c/50c packs that I hope will give me a big boost over the prolite V2's but they are 3oz heavier. I probably need to push the plane a lot harder too as I only used 3000 mah in 5 mins. Full throttle it was maybe doing 100... maybe. Certainly not a rocket but it flies like a dream. Didn't need a click of anything.
This makes a great trainer jet - really nice ground handling for takeoff and super easy to land (at speed) - about the same as my 2M pattern plane. This is my first jet and I am hooked!
Good job. Spark is a fun plane to fly and landing is easy.
Wait next week get the trailing strut and going to 2.5" on the main. That is even more solid on the ground handling.
Tamjets is offline Find More Posts by Tamjets
Old Jul 18, 2009, 08:45 AM
Joined Sep 2005
You TL struts look awesome Tam. I am using Robart 650's right now with Robart brakes. They look awesome but it is a heavy setup and the wheels protrude from the bottom of the wing by 1/4" which I know is not helping my speed at all.
I will get a set of yours when they are ready... I'll call you Monday and make sure you still have my CC# and address so I can get some of the first ones
2.5" mains will probably work off grass. This runway I used is an old cold-roll surface with some fair size cracks... I was sceptical how the Spark would track but with the TL nose gear and 650 struts it just cruised right over them.
Your setup will probably save me 3 or 4 oz. I am around 10.5lbs right now with very light 10s batteries. I'm amazed how well this wing floats on landing.
Maybe an F:16 next year
crhammond is offline Find More Posts by crhammond
Old Jul 18, 2009, 08:57 AM
Watt me worry?
Madmax1965's Avatar
Florida
Joined Mar 2006
Steveaire:
HACKER spin 99 and a JETI spin 99 are they the same?
I have both models of this controller and I believe they are the same. I think Hacker and Jedi have hooked up together on the controller. I am using the Hacker Spin 99 with my Neu powered TJ-100.....works well.
Madmax1965 is offline Find More Posts by Madmax1965
Old Jul 18, 2009, 04:33 PM
Dublin Ireland
Joined Aug 2005
Thanks Madmax
I saw a Hacker for sale on the BMFA site for £180 unused.I was tempted but you could get a new Jeti for £169.Thats why I wanted to know were they the same.
I bought a new Castle Creations 110hv for £100 second hand but new.
Should do the job.
Thanks again
Cheers
Steve
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Jul 18, 2009, 05:23 PM
demetrius's Avatar
Van Nuys
Joined Mar 2004
Tam, how much for the struts? Also, what do you have for steering without the wire pull, that will work for the L-39 Savex?
demetrius is offline Find More Posts by demetrius
Old Jul 18, 2009, 08:13 PM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
I had local customer had same kit. I'll borrow his kit to made the complete set up for it.
If finish in time. I'll to LA Jets.
Old Jul 20, 2009, 02:01 PM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Spark landing with trailing struts video
Spark landing
Spark landing with trailing struts (0 min 42 sec)
Old Jul 20, 2009, 03:14 PM
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Sweet Tam
you can see the nice little bounce the gear sucked up
I want to get a set once I get back from my trip this week...
how much is a set with brakes?
My livermore club is rough and kind of hard on the plane
later
Ron
Ron101 is offline Find More Posts by Ron101
Old Jul 20, 2009, 03:30 PM
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
What's the weight on those struts Tam? They worked flawlessly the other day, and they looked great too. Just the looks alone are great, but they really let the landings and braking look more like a turbine operation. Ron, do you guys have a Petromat surface at Livermore?
Eddie P is offline Find More Posts by Eddie P
Old Jul 20, 2009, 04:28 PM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Eddie,
It weight 1.1oz each in full lenght.
Ron,
Once I got it all add up for the cost to made them. Then I'll post the price.
My estimate is around $40 to $45 each strut.
Old Jul 20, 2009, 05:24 PM
Ron101's Avatar
Joined Jul 2007
We do Eddie.... and it's pretty rough... my A-4 is not bothered by it at all.. the bigger wheels and struts suck it up. But the small wheels and wire gear bounce the spark around pretty good on taxi.. so it would be nice to smooth it out
Tam .. that's a great price and you will sell a ton of them at that price...
put me down for a set.. just mains and brakes...
I can sell my wire struts and brakes...
did you have to open the cut outs a lot to get them to fit the old wire gear cut outs? from the pics it doesn't look like you had to trim it all that much?
will the retracts I have work..or is the wire thicker? if I have to replace the retracts I'll just keep what I have.. but if I just have to cutoff the wire and slip those over it that would be easy
later
Ron
Old Jul 20, 2009, 05:40 PM
Official Boat Bum
Eddie P's Avatar
Joined Mar 2000
Yeah, petromat is waaaay better than dirt as far as cleanliness, drainage, maintenance and consistency. But it sure does have it's limitations on little wheels and wire struts unless it's rolled every week like a golf green, and 99 percent of petromat runways aren't. I think you are gonna like those struts, I was pretty impressed by them and they make the airplane look like a mean machine. Hey, now that I think about it, your NACA ducts will look great with those struts!
Old Jul 20, 2009, 06:45 PM
Ron101's Avatar
Joined Jul 2007
Hey...are you giving me a hard time on my $20 Naca ducts again...lol
you guys don't like me 60/90 rule either...lol.. if it's under 60 or over 90 stay home... ... I'm kidding on that one..but as you can tell I'm a bit of a fair weather kind of guy
are poor runway hasn't been rolled since the day it was laid...like 4 years ago.. I have a club just up the street from the EBRC the flying electrons.. real nice runway but it's only 450 ft... so far I don't have the balls to try it...
but I hope to soon.. that field has power also.. I rotate which field I fly at..lol
can't wait to try the struts out... that will be cool
Ron
Old Jul 22, 2009, 06:00 PM
electric power,what else!
eJets's Avatar
near Zurich - Switzerland
Joined Dec 2005
Hi,
Today was my second flight, the first flight on a short cut gras runway. the spark was airborn after 80-100m / 240-300ft.
Lowering the Ailerons for Take-off and Landing works fine but still workingfor on well balanced mix for the elevator while lowering the Ailerons (the spark goes on the nose)
BTW: does your elevator for normal flight is also a littel deflected up? ...or shall I move my CG (150mm) futher back?
Hope see you Guys on Sunday while visiting LA Jets - a long 6000mi way....
cheers from Switzerland
eJets
eJets is offline Find More Posts by eJets
Old Jul 22, 2009, 06:05 PM
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Originally Posted by eJets
Hi,
Lowering the Aierons for Take-off and Landing works fine but still searching for a well balanced mix for the elevator.
eJets
I having my new Spark building right now. Hope can finish by tomorrow for maiden. Friday noon head to LA.
What time you coming on sunday from LAX?
BTW,
My Spark elevator and aileron had zero trim. I move the C.G further back. I don't have exactly number. But we can check it out on sunday.
Comp ARF Impact Bill Mixon Site Chat 5 Nov 01, 2005 04:04 PM
31% Comp-Arf Video Splummer Sport Planes 19 Aug 20, 2005 01:12 PM
Sold Comp ARF YAK 2.6 w. DA 100 Ulf Rieder Aircraft - Fuel - Airplanes (FS/W) 2 Jul 05, 2005 04:08 PM
Comp ARF whistle for AFP Fly-guy Simulators 0 Jan 06, 2005 01:47 AM
NEW Comp-ARF Extra 2x2 kody'd'punk Sport Planes 43 Dec 09, 2004 09:17 PM
