Old Nov 08, 2008, 07:27 PM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
I like this version!
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Nov 08, 2008, 09:56 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
are they really going to do the thunderbirds scheme?
if they do I'll order right away
that would look great
Ron101 is offline Find More Posts by Ron101
Old Nov 09, 2008, 10:25 AM
Neil Guildford is offline
Find More Posts by Neil Guildford
Neil Jarvis
Neil Guildford's Avatar
Surrey U.K.
Joined Sep 2004
I've just started on mine. The Stumax fan has fitted in easily with a bit of dremel work.
Neil
Neil Guildford is offline Find More Posts by Neil Guildford
Old Nov 09, 2008, 10:31 AM
Wind Junkie is offline
Find More Posts by Wind Junkie
NY Slope Dog
Wind Junkie's Avatar
Syracuse, NY
Joined Sep 2003
Looks great Neil. I hope to be where you are in a few months once schedule and funds allow.
Wind Junkie is offline Find More Posts by Wind Junkie
Old Nov 09, 2008, 11:28 AM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
I'm looking at possible speed controller locations for maximum cooling. Does anyone think the benefits of cutting a slot in the inlet and inserting the fins of the esc would be outweighed by the inefficiencies to the fan?
Neil
Old Nov 09, 2008, 12:05 PM
Joined Dec 2000
Neil I mounted my ESC outside the duct where COMP ARF indicates.
I mounted my CC 110 on top using a similar mounting scenario to what the manual shows.
Neil I have a question for you. It looks as if the flange on the duct can be shortened to move the fan forward, so the fan housing face would butt against the inside corner of the duct could you confirm this please.
You want absolutely smooth flow of air in the ducting.
For this reason you do not want the ESC mounted down into the ducting.
It will be easier to attach your thrust tube also!
Old Nov 09, 2008, 12:23 PM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
Good point, I will look into this.
Old Nov 09, 2008, 12:33 PM
GRX is offline
GRX
Find More Posts by GRX
GRX
gettin on the banned wagon
GRX's Avatar
Joined Jun 2008
Mines mounted upside down over a hole in the intake, I didnt put the heatsink down in the duct but rather flush with the top and the hole is cut to within a few mm of the size of the heatsink.Comes out barely above ambient after 5.5 minutes pushing 3.5Kw. It was clocked at 154mph without doing the "rollercoaster" but from about a 25 degree entry at WOT. I've gotten well over 100 flights on this controller with no issues whatsoever. ESC
GRX is offline Find More Posts by GRX
Old Nov 09, 2008, 01:54 PM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
Thanks for your post, your using the same controller I have. I have another in a Savex L-39 running 12S at 70A with similar cooling and I've also had no problems. I'm leaning towards this method.
Neil
Old Nov 09, 2008, 02:19 PM
Joined Dec 2000
GRX is using a Schubi DS-75
Old Nov 09, 2008, 02:31 PM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
Are you just pointing that out or am I missing something?
I'm looking to run 11S and I guess that will be around 80A.
Neil
Old Nov 09, 2008, 02:51 PM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Here is my flying over the weeken.
Tamjets is offline Find More Posts by Tamjets
Old Nov 09, 2008, 03:10 PM
GRX is offline
GRX
GRX
GRX's Avatar
Joined Jun 2008
Out of curiosity, Does the contender have a different design than the original? C-ARF lists the fan as the TAM TJ100 for the contender and for the original they still list the DS-75/Lehner combo?
Old Nov 09, 2008, 06:07 PM
Joined Dec 2000
With Stu's fan you do not want to cut into the ducting in my opinion.
That is the point I am making.
Bob
Neil
Old Nov 09, 2008, 06:09 PM
Joined Dec 2000
Looks awesome Tam.
What setup did you put in this Spark.
Comp ARF Impact Bill Mixon Site Chat 5 Nov 01, 2005 05:04 PM
31% Comp-Arf Video Splummer Sport Planes 19 Aug 20, 2005 02:12 PM
Sold Comp ARF YAK 2.6 w. DA 100 Ulf Rieder Aircraft - Fuel - Airplanes (FS/W) 2 Jul 05, 2005 05:08 PM
Comp ARF whistle for AFP Fly-guy Simulators 0 Jan 06, 2005 02:47 AM
NEW Comp-ARF Extra 2x2 kody'd'punk Sport Planes 43 Dec 09, 2004 10:17 PM
