Sorry not
Mounting the nose gear is so simple. The original blind nut only can fit 2 holes to the L-bracket I supply with the gear. The other two just drill new holes and use self taping screw. That is all you had to do. The Spark was make for the spring air gear. When using different gear had to make minor adjust. No big deal. But asking me to make new bracket is exact match to the Spark is kind of high cost for small quanity. I make the L-Bracket for my mini gear by a thousand to cut the cost. Ask me to make another 1000 to match each plane is not cost effective. You don't want me add another $30 cost for each set gear I sold do you?
Steveair2, I redrilled my mounts. I also trashed the stock steering servo mount and repositioned my servo very close to the retract. A very short push rod with less slop. This fixed the throw issue.
Tam, you retracts are awesome! Mine are installed and working perfect! Now if someone could help me with my esc!! ICE160HV, 10s. at 1/4 throttle its acts like low voltage cutoff. Also when powered up, no green light. just a yellow. what gives?? programming?? |
Dublin Ireland
Joined Aug 2005
Thanks Stoneforcer.
I might try that. I also have a castle HV 160. It's next to do so if you want me to try any set ups let me know. I had a simular problem with a CC 125 that drove me nuts so I can understand where you are coming from. Cheers Steve |
Stu. |
Guys I am still thinking of the choice for batteries.
You guys have batteries up to 5800mah from Hobbycity. I did a check and came up with the following: 5800mah 5s 30 Turnigy: 776grams What I want: Hyperion 5400mah 5s 35c : 745 x2 <-grams Hyperion 5500mah 5s 35c : 760 x2 <-grams Hyperion 6500mah 5s 35c : 867 x2 <-grams So 2x Turnigy Batteries do fit the CG nicely. The CC 160HV ESC would be above the EDF Unit. The RX Batteries can be moved back and forth to get the correct cg. I would rather take those 6500mah batteries, but if I get CG problems then rather not. Also I want to keep my Spark as light as possible. What do you guys think? Regards NS. |
I run 5800's and one set of NanoTech's(Nano's dead now) 6000mah (10 cell). To get it to balance i had the CC160 at the rear of the canopy. Both my 750 2 cell Lipo's for the radio at the rear wing mounting bolt. My RX was also directly opposite the SM110-45. The brake and retract servo's and air-valves opposite the fan as well. Keep it all back as far as possible. And it balances nicely
Chris |
So I think I would be going with these 5500mah Packs which weight around 750gramms each. I want the CC ESC above the EDF Unit installed. Both RX Packs on both sides of the fuselage. Since I am going electric, I will need to use only the brake Valve. The RX Remains in the Front where it was needed to be. I hope to get my Jet likes this Balanced. Pascal. |
Thanks Stu! I see a few guys mounted their receiver under wing to the side of the intake. I never thought about doing that before but seems to make a lot of sense rather than run long extensions into the nose if you don't have to. As long as the receiver is not right next to the fan, is there any problem mounting it back there??
Thanks, Brian |
| Thread Tools | |
| Comp ARF Impact | Bill Mixon | Site Chat | 5 | Nov 01, 2005 04:04 PM |
| 31% Comp-Arf Video | Splummer | Sport Planes | 19 | Aug 20, 2005 01:12 PM |
| Sold Comp ARF YAK 2.6 w. DA 100 | Ulf Rieder | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jul 05, 2005 04:08 PM |
| Comp ARF whistle for AFP | Fly-guy | Simulators | 0 | Jan 06, 2005 01:47 AM |
| NEW Comp-ARF Extra 2x2 | kody'd'punk | Sport Planes | 43 | Dec 09, 2004 09:17 PM |
