Old Apr 14, 2011, 03:40 AM
neversommer is offline
Find More Posts by neversommer
neversommer's Avatar
Luzern/Switzerland
Joined Aug 2008
Originally Posted by icicles View Post
1521-1.5Y is awesome on 10 cells with Stuart's 110-45 fan, 5800mah batteries
If you don't mind 127 amps that is.
Chris
Do you have it in use? How long can you fly with that setup?
What is your Top Speed?
Also...where do you get such 5800mah batteries from?
Hyperion does only have 5400,5500 and highest is 6500mah.
Would be cool to know
NS.
neversommer is offline Find More Posts by neversommer
Old Apr 14, 2011, 04:55 AM
STEVEAIR2 is offline
Find More Posts by STEVEAIR2
STEVEAIR2's Avatar
Dublin Ireland
Joined Aug 2005
Originally Posted by stoneenforcer View Post
not sure why you cant mount all the fan batts up front and put the esc in its place. Or put the 3s up in the belly side along side the fan. Im using one LION pack since its lighter than A123's. My Lion pack is powering everything, including my retracts. Its a 2100. Im going to use rx pack postion to finalize my CG. Skip the powerbox, just another lead weight and cause of crash.
I eliminated the front rx plate. My rx sits behind the battery bullkhead with the satelite on the side of the intake. the lion will most likely sit same general location but underneith.
Thanks Again Stoneforcer.
I will have a look when I get home.
Cheers
Steve
STEVEAIR2 is offline Find More Posts by STEVEAIR2
Old Apr 14, 2011, 06:38 AM
icicles is offline
Find More Posts by icicles
icicles's Avatar
Australia, ACT, Canberra
Joined Jul 2006
NS.
Top speed, don't know really, guessing up around 300k's
I have used 5800mah and 6000mah. All from Hobby King, twin 5s packs. Had a Nano Tech die. One cell had a high resistance, so it was on the cards
These videos are of the first two flights. Not great but it may give you an idea. As i move the Cof G back it is landing nicer, ensuring i am not carrying any up trim. I normally get 5.30 min flights, that's enough. Plenty of throttle work
Comp ARF Spark Stumax SM110-45 first flights (3 min 42 sec)
Comp ARF Spark Stumax SM110-45 first flights (4 min 10 sec)
I've had many flights on it now. The more i fly it the more i like it. Hoping to go out this weekend again.
Chris
icicles is offline Find More Posts by icicles
Old Apr 14, 2011, 08:09 AM
Luzern/Switzerland
Joined Aug 2008
http://www.youtube.com/watch?v=cixD3...eature=related
http://www.youtube.com/watch?v=usSJZZbYgNo
Chris
She seems to track down very nicely. Sound is amazing for a 4 Bladed Rotor Blade.
The speed seems allright.
If you get 5:30 Flights..that sounds about ok for me. Flying with over 300km/h for 6-8 Minutes will need to give me a new heart to replace through the adrenaline rushing through my body.
I guess you do a bit more then 300km/h, hard to tell but.
My goal is 300km/h or more. I would be very happy with a 320km/h level flight.
Regards
NS.
Old Apr 14, 2011, 07:32 PM
Z06kal is online now
Find More Posts by Z06kal
DS JUNKY
DA VALLEY, CA
Joined Jun 2004
Chris
First Video:
Pass 1 up wind 128mph
Pass 2 down wind 182mph
pass 3 up wind 152mph (unclear difficult to read big error possible)
Second Video:
Pass 1 down wind 198mph
Pass 2 down wind 183mph
Pass 3 up wind 157mph (not well defined unclear)
Pass 4 up wind 170mph
Pass 5 down wind 163mph (not well defined unclear)
Pass 6 up wind (not readable)
Hard to tell for sure as the audio is not real clear on the graph. I'd say the setup does around 175-180 in no wind.
We predicted about 180 on the math for 4500 watts so it seems to line up just fine.
Z06kal is online now Find More Posts by Z06kal
Old Apr 14, 2011, 11:51 PM
icicles is offline
icicles's Avatar
Joined Jul 2006
Originally Posted by Z06kal View Post
First Video:
Second Video:
Cool, thanks muchly.
I have measured 4600 watts so right in the ballpark
Chris
Old Apr 15, 2011, 04:28 AM
schiwo1 is offline
Find More Posts by schiwo1
Joined Nov 2009
Originally Posted by like2fly! View Post
Hi,
For stronger, lighter Titanium struts see post #392 (im reading through the thread daily...), these are the struts
Hi like2fly,
thanks for the hint. Order is already placed
Best
Stephan
schiwo1 is offline Find More Posts by schiwo1
Old Apr 15, 2011, 05:04 AM
Luzern/Switzerland
Joined Aug 2008
Hmm...so the 1521-1.5y does around 300km/h or like 310km/h, uses 120amps and flight time with a 5000mah battery may be relatively short.
Not sure if that is worth the try.
Old Apr 15, 2011, 06:33 AM
stoneenforcer is offline
Find More Posts by stoneenforcer
High Dynamic Thrust
stoneenforcer's Avatar
United States, FL, Mt Dora
Joined Feb 2007
im shopping for some 6000's for this issue. I have 5000's on hand but I know the timer will have to be way to short.
40C 5s 6000 anywhere?? i dont see em around. NO TP referrels please.
stoneenforcer is offline Find More Posts by stoneenforcer
Old Apr 15, 2011, 06:35 AM
High Dynamic Thrust
Joined Feb 2007
ICICLES... are you running low timing on your ESC or high??
ty.
Old Apr 15, 2011, 06:38 AM
Luzern/Switzerland
Joined Aug 2008
Why no Thunderpower? Aren't they any good?
They have those new G6 Line with a 6600mah on top of the line, they look to be very powerful!
I am thinking of the Hyperion 6500mah 35c 5S to buy.
The dimensions are:
160.0 Long
47.0 Wide
58.0 Height
867 Weight
Do you reckon it would cause an issue with the cg with 2 of such packs?
There would be also the Hyperion 5500mah ones which are a bit lighter.
If I get 4 Minutes with these 5500mah packs, I would be very happy.
6500mah Packs will give us a good 6 minutes or 7 minutes for sure.
NS.
Old Apr 15, 2011, 07:21 AM
icicles is offline
icicles's Avatar
Joined Jul 2006
ty.
LOL i can't remember. Sorry. I think it is low from memory. I'll check when i get the chance
I find 5 1/2 minutes long enough. I even think the turbine boys keep their flights short too. I find things happen pretty quick.
I couldn't be happier.
Chris
Old Apr 15, 2011, 08:59 AM
Tumbler is online now
Find More Posts by Tumbler
Tumbler's Avatar
United States, NJ, Vineland
Joined Feb 2003
How come no one uses the Stu 100? I really like the sound of that one. Not that the 110 doesn't sound cool too, but I like that turbine sound of the 100. I hate to give up a ton of performance just for sound though, so wondering why no one is using it. Something at least 180mph+ around 100 amps is ideal for me. I don't need 200mph at the cost of 130-140 amps.
Brian
Tumbler is online now Find More Posts by Tumbler
Old Apr 15, 2011, 10:35 AM
like2fly! is offline
Find More Posts by like2fly!
who dares wins
like2fly!'s Avatar
London,England
Joined Apr 2005
Originally Posted by schiwo1 View Post
Hi like2fly,
Best
Stephan
Hi Stephan,
The Titanium struts from central are(were?) prone to snapping at the point where they are gripped for bending if your landing is not great. The grip point caused a weakness. The posts reporting this were from 2009 so perhaps they no longer have this weak point?
Please check the struts when you recieve them.
like2fly! is offline Find More Posts by like2fly!
Old Apr 17, 2011, 07:38 AM
schiwo1 is offline
Joined Nov 2009
Hi Stephan,
Will do so. Can only be better the than the original Springair.
In the meantime I completed a few further flights with my newly arrived 11s 25C 4000 packs. Attached is a GPS and a Unilog chart of one flight.
I could reach about 300km/h / 186 mph (GPS speed) on level acceleration (no dive) along with the TJ100 and the Neu 1515 3D motor at approx 4,2 KW.
This is not the limit I guess. Since the batteries were new, unformatted, and not pre-heated I expect a better voltage level and up to 4,4 KW after a few more flights.
The second chart includes the Power and rpm over the course of the flight. The TJ 100 reaches up to 46000 rpm - a bit scary but an amazing sound.
Best
Stephan
Comp ARF Impact Bill Mixon Site Chat 5 Nov 01, 2005 04:04 PM
31% Comp-Arf Video Splummer Sport Planes 19 Aug 20, 2005 01:12 PM
Sold Comp ARF YAK 2.6 w. DA 100 Ulf Rieder Aircraft - Fuel - Airplanes (FS/W) 2 Jul 05, 2005 04:08 PM
Comp ARF whistle for AFP Fly-guy Simulators 0 Jan 06, 2005 01:47 AM
NEW Comp-ARF Extra 2x2 KodyK Sport Planes 43 Dec 09, 2004 09:17 PM
