Old Aug 25, 2009, 07:17 PM
techspy is offline
Find More Posts by techspy
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
Forgot to specify, I am using a FASST system. I also have it in a P51 with a Y for the ailerons and a Y for the flaps.
techspy is offline Find More Posts by techspy
Old Aug 25, 2009, 07:57 PM
TheTick is offline
Find More Posts by TheTick
Spoooooon!
TheTick's Avatar
San Fernando Valley, California, United States
Joined May 2003
Thanks techspy. A friend had just mentioned that it was something I need to double check before Y'ing. Sounds like I'll be just fine.
TheTick is offline Find More Posts by TheTick
Old Aug 25, 2009, 07:59 PM
rvincent is offline
Find More Posts by rvincent
Renegade Fun Forever!!
rvincent's Avatar
Fontana, California, United States
Joined Jul 2004
Just not supposed to use reversing "Y's" is all
rvincent is offline Find More Posts by rvincent
Old Aug 26, 2009, 02:27 AM
Neil Guildford is offline
Find More Posts by Neil Guildford
Neil Jarvis
Neil Guildford's Avatar
Surrey U.K.
Joined Sep 2004
I'm also running my elevators on a Y with Futaba Fast. I turned one of the servos around so no need for a reverser.
Neil
Neil Guildford is offline Find More Posts by Neil Guildford
Old Aug 26, 2009, 03:29 AM
Tamjets is offline
Find More Posts by Tamjets
Tamjets's Avatar
San Jose, CA
Joined Jun 2006
Hitec 5125 fit good and you can reverse the servo with the programer.
No need any reversal harness.
Tamjets is offline Find More Posts by Tamjets
Old Aug 26, 2009, 06:22 AM
jfetter is offline
Find More Posts by jfetter
HAL... Open the damn doors!
jfetter's Avatar
Miramar, Florida
Joined Jul 2007
IMO the Hitec servos in general have poor centering, all you need to do is sit behind your jet and watch the elevators center 2 clicks high, then 1 click low, sometimes wandering to center over a 1/4 to 1/2 second while hey search. Perhaps 7 of 10 times they return to center properly but the other 3, they do wander. I never believed this until a buddy of mine told me to sit and watch them one day. Then he said "what do you think this does in flight" and he was right, hard to trim 100% and sloppy exits from manuevers. Don't take my word, put it up against a JR 3421 (that would be the equivalent for elevator, rudder or ailerons on that size jet) and see for yourself. I thought it was a gimmick until I saw the centering difference...
Jack
jfetter is offline Find More Posts by jfetter
Old Aug 26, 2009, 06:40 AM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
I also had problems with centering the HS 5125's in my Spark. Mine now has JR's.
Old Aug 26, 2009, 09:51 AM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Did you guys use a programer? Or just put them in the plane and go for it?
Old Aug 26, 2009, 09:55 AM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
I burnt in my 5125's on the programmer.. have over 20 flights with no problems and they center perfect... plane is rock soild in the air
I think it's the luck of the draw with Hi Tech's... I'm sure the JR's are better
but my Hi Tech's are working perfect
Ron
Ron101 is offline Find More Posts by Ron101
Old Aug 26, 2009, 03:16 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
yeah i burn everything in with Hi-tech programmer. Fun to just fiddle with them anyway! haha and nice to do a build with pre setup pre centered servo's
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Aug 26, 2009, 08:53 PM
JimPatrick is offline
Find More Posts by JimPatrick
Los Gatos Airport
California
Joined Aug 2008
Does the Hitec programmer have a function to burn in servos by running them from end to end????
I have an old PIC controller I use for this, but could use something better....
JimPatrick is offline Find More Posts by JimPatrick
Old Aug 26, 2009, 09:10 PM
Ron101 is offline
Ron101's Avatar
Joined Jul 2007
Yep Jim,
and you can set the speed fast or slow.. I do 15 minutes slow...let cool
15 minutes mid ... let cool.. then 15 fast...done
works for me... my friend is an electrical engineer and told me that 90% of the time new electronics will fail in the first ten min.
I've caught about 4 or 5 servos bad out of the box now... they could have done in the plane
Ron
Old Aug 26, 2009, 09:20 PM
Los Gatos Airport
California
Joined Aug 2008
I run most servos for 45 minutes, have not found a bad Futaba, have found a bad JR cheapie and Airtronics.
I burned in some Hitec low profile ailerons servos because they were WAY too stiff in the gear train.
After 90 minutes of burn in you could finally turn them by hand and the free running current dropped in half.
The gears are just to tight and need breaking in.
Old Aug 26, 2009, 09:28 PM
harrymc is offline
Find More Posts by harrymc
Just Happy To Be Here!!!
harrymc's Avatar
United States, AL, Northport
Joined Nov 2004
Ron,
What model Programmer do you use?
I'm looking at the HPP-21 +, at about $50 or the HFP-20, at about $150 . I've also just bought a set of HS-7985MG's for another aircraft so I want to make sure I get the correct programmer. Clearly, if the HPP-21+ will do the job, I'd sure like to save some money. What u think?
I'm also having issues with my 5125's in the tail like jfetter mentioned, and with the DS3421's in the wing...no problem. It's getting really frustrating!
Harry
harrymc is offline Find More Posts by harrymc
Old Aug 26, 2009, 09:42 PM
rvincent is offline
rvincent's Avatar
Joined Jul 2004
Please explain "burn in"
Comp ARF Impact Bill Mixon Site Chat 5 Nov 01, 2005 04:04 PM
31% Comp-Arf Video Splummer Sport Planes 19 Aug 20, 2005 01:12 PM
Sold Comp ARF YAK 2.6 w. DA 100 Ulf Rieder Aircraft - Fuel - Airplanes (FS/W) 2 Jul 05, 2005 04:08 PM
Comp ARF whistle for AFP Fly-guy Simulators 0 Jan 06, 2005 01:47 AM
NEW Comp-ARF Extra 2x2 kody'd'punk Sport Planes 43 Dec 09, 2004 09:17 PM
