Old Nov 20, 2008, 05:52 AM
stumax is offline
Find More Posts by stumax
The blade numbers go up to 11
stumax's Avatar
Sydney, Australia
Joined Aug 2002
Neil, the lip is wide enough to have half of it (about 6mm) covered by the exhaust tube and then there's enough for some tape to go around it. The best tape is probably 12mm wide glass strand reinforced tape as it won't split.
BTW, Bob, I noticed that you seem to have no washer under the head of the fan mounting screw - is this correct? you really need one to keep the head of the screw from pulling thru the grommet. I'm looking forward to seeing how it goes with a smaller exhaust and less power than Bob B had in his.
Stu.
stumax is offline Find More Posts by stumax
Old Nov 20, 2008, 09:34 AM
Neil Guildford is offline
Find More Posts by Neil Guildford
Neil Jarvis
Neil Guildford's Avatar
Surrey U.K.
Joined Sep 2004
Thank you both, I'll try this.
I didn't use the rear disc and instead installed the whole thing and cut it off 5mm from the tail afterwards. These measurments are what it became, 85mm tall & 88mm wide.
So another variation to test...
Neil
Neil Guildford is offline Find More Posts by Neil Guildford
Old Nov 21, 2008, 06:36 AM
Bob P is offline
Find More Posts by Bob P
Senior Member
Bob P's Avatar
Wiltshire England
Joined Feb 2001
Stu
I followed your advice in the Installation instructions in the manual and fitted washers at the bearers and on top. The top one doesn't show well in the pic.
Bob
Bob P is offline Find More Posts by Bob P
Old Nov 21, 2008, 10:01 AM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
I just did a trial run with a Turnigy 100A 12S speed controller and found it wouldn't work on 10S (or any configuration I had). I exchanged it for a Master Hacker 90 Acro and it worked fine. The limiting factor being this controller will only run to 10S, so I'm going to need another.
My 10S 3700 Rhino's with the Stumax fan read 60A 2150W from cold at a temp of 7deg outside.
Neil
Old Nov 21, 2008, 10:10 AM
Robert Belluomini is online now
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
Sounds like you have a bad ESC. Bummer
Robert Belluomini is online now Find More Posts by Robert Belluomini
Old Nov 21, 2008, 10:12 AM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
The Turnigy goes into programing mode straight away and nothing else...the throttle doesn't change anything.
I have another Turnigy in my L-39, I may take that out to try before I buy something else.
Neil
Old Nov 23, 2008, 12:57 PM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
A few pictures of the version I ordered..I think it really suits the Spark.
Neil
Old Nov 23, 2008, 01:15 PM
Knife Liddle is online now
Find More Posts by Knife Liddle
Lee Liddle
Knife Liddle's Avatar
Carrollton, Tx
Joined Dec 2006
I like the colors and the stripe treatment on the fuse/fin. I don`t like the insignias on the wings. And I think third color of accents stripes, like black, would really set it off nicely.
Not trying to be critical, just throwing out some ideas for something different than the next guy`s Spark. Overall, I`d say it`s a nice choice.
Knife Liddle is online now Find More Posts by Knife Liddle
Old Nov 23, 2008, 01:30 PM
markbrown1 is offline
Find More Posts by markbrown1
markbrown1's Avatar
Surrey England
Joined Apr 2006
Neil
Looks good. At last a decent colour scheme that follows the lines of the airframe.
cant wait for this one.
M
markbrown1 is offline Find More Posts by markbrown1
Old Nov 23, 2008, 01:35 PM
nighthawk117 is offline
Find More Posts by nighthawk117
United States, MA, Hadley
Joined Oct 2006
Neil, that looks great, is this a custom scheme?
nighthawk117 is offline Find More Posts by nighthawk117
Old Nov 23, 2008, 01:47 PM
Neil Jarvis
Surrey U.K.
Joined Sep 2004
Yes it is, Surprisingly it only took about 2 months for delivery...take note next guy, ask for black lines on yours.
Neil
Old Nov 23, 2008, 01:54 PM
Gordon is offline
Find More Posts by Gordon
Gordon's Avatar
Joined Aug 2000
Looks very nice Neil.
BTW, on 10S TP 5000 V2s I got around 2.5kW. Maybe it was a degree or so warmer. I'm using a Graupner clamp-ammeter and DVM to measure.
Will you be at Classic Jets on 12 Dec?
Gordon.
Gordon is offline Find More Posts by Gordon
Old Nov 23, 2008, 02:44 PM
Ron101 is offline
Find More Posts by Ron101
Pursuit of Happiness
Ron101's Avatar
Brentwood, California
Joined Jul 2007
Neil...
All I can say is Wow...
the spark is my next plane and I've been keeping an eye out for a good scheme.. That is just perfect and really picks up the lines of the model very well... really nice job man
Ron
Ron101 is offline Find More Posts by Ron101
Old Nov 23, 2008, 03:54 PM
LeadSled is offline
Find More Posts by LeadSled
Just here to fly stuff
LeadSled's Avatar
Everywhere
Joined Dec 2005
Neil, that paint scheme looks great. It completely changes the look of the plane. If I get another Spark, I might have to do that one.
I got three flights with my Spark today after doing a pm on it last weekend (too windy to fly). This is a really great plane to fly.
Here is a question for Spark pilots. I have the CARF Bohetec wheels/tires. After 40 plus flights the tires are starting to wear. Where can I find replacement tires? I emailed the CARF rep and did not have any luck. He said I needed to order a whole wheel/tire and brake package. If I can't find any tires I guess I'll just switch to MPI wheels/tires.
LeadSled is offline Find More Posts by LeadSled
Old Nov 23, 2008, 04:23 PM
Gordon is offline
Gordon's Avatar
Joined Aug 2000
On my 16lb Hawk with over 60 flights on it from a full-size runway with hi-friction tarmac, the Eurokit wheels with inserts have hardly any wear at all. I don't have any brakes though, which might be the difference.
http://www.eurokitlucca.it/Old_Site/...l_frameset.htm page 52, rubber wheels with aluminium rim.
Do you land with the brakes partly on?
Gordon.
Comp ARF Impact Bill Mixon Site Chat 5 Nov 01, 2005 04:04 PM
31% Comp-Arf Video Splummer Sport Planes 19 Aug 20, 2005 01:12 PM
Sold Comp ARF YAK 2.6 w. DA 100 Ulf Rieder Aircraft - Fuel - Airplanes (FS/W) 2 Jul 05, 2005 04:08 PM
Comp ARF whistle for AFP Fly-guy Simulators 0 Jan 06, 2005 01:47 AM
NEW Comp-ARF Extra 2x2 kody'd'punk Sport Planes 43 Dec 09, 2004 09:17 PM
