United States, AL, Tuscaloosa
Joined Nov 2004
Guys,
This question may belong in another thread, but since it pertains to my Spark, I'll ask it here. There's a lot of talk about "conditioning" new lipo batteries but opinions vary. I'd like to hear from as many of you as willing, as to your methods of conditioning new lipo packs. Obviously with the high cost of larger packs, I'd like to maximize the life and power of these packs. Thanks also for the replies on the reciever battery question, that was good stuff! Tam, What's the exit size on your thrust tube on your new Spark? Thanks all, Harry |
Harry, 72-74mm is pretty much standard for TJ100. If running the new 40C. I would only doing on 10s. |
Well the landing gear saga continues...
Went to the field today to test out the new gear and work on using the airbrake for slowing down my landings. Pre-flight check showed one of the mains sticking in the retracted position. I could move it forward and backward a bit and it would release. I was planning on practicing landings anyway so I just decided to leave them in the down position anyway and check out the sticking issue later. So, takeoff was uneventful although I did have to correct a bit with rudder while on the ground due to one gear having a bit of tow-out. I made one slow circuit with the air brake fully extended to see how the handling is affected. Seemed ok so I came in for landing and was doing ok, had a bit of cross wind but had it lined up. In the last few feet (5-10) it just lost all lift and dropped. In spite of the claims that it will fly really slow, I guess I crossed that threshold. Damage is one sheered pin on a main, front bulkhead for the front gear is broken off. It appeared that it broke the wood, but mostly came loose from the fiberglass by braking the epoxy. So all in all it is an easy fix but I need to make sure the air brake servo isn't damaged from the belly flop. Also, the other main seems to have bent the sheer pin so it isn't lined up now. I will definitely have to get a handful of those pins. Not sure if I should continue trying the airbrake assisted landings or just get the wheel brakes working, land hot and apply air and wheel brakes upon touchdown. Oh well, I better get to work. |
Techspy....bummer as they used to say. Hope you can fix the damage and get back in the air.
I got to say I fly my cheap Starfire with less wing area than the Spark(10s...TJ100) and I land without any airbrakes. I know the Starfire is not a Spark but I found if you come in on power and flat to the runway the plane would land fine.....plus I use no brakes. I guess most pilots don't like to come in a flat appraoch because you are hauling @ about three-four foot off the deck....cut the power and flare. Of course I do have a good sized paved field. When you get that plane back together just go out and fly the hell out of it.
You get it fix and fly again. About the nose former broke off. I had that happen before with the nose gear mount too solid. That is why I refer to use the aluminum L-bracket. If any bad landing. The only damage is the L-bracket got bend. You just need to replace the L-bracket instead fixing the former. |
| Thread Tools | |
| Comp ARF Impact | Bill Mixon | Site Chat | 5 | Nov 01, 2005 04:04 PM |
| 31% Comp-Arf Video | Splummer | Sport Planes | 19 | Aug 20, 2005 01:12 PM |
| Sold Comp ARF YAK 2.6 w. DA 100 | Ulf Rieder | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jul 05, 2005 04:08 PM |
| Comp ARF whistle for AFP | Fly-guy | Simulators | 0 | Jan 06, 2005 01:47 AM |
| NEW Comp-ARF Extra 2x2 | kody'd'punk | Sport Planes | 43 | Dec 09, 2004 09:17 PM |
