I'm talking about packs that can repeadedly absorb momentary amp spikes without eventual voltage sags that, in fact, can very well happen with a jammed flight control (s). Flight controls can often partially jam under positive and negative rapid onset G loadings in turbulence or aggrivated jerky flight maneuvering - or if the airplane has been sat in the sun for a long time and materials expand (closing in fine gaps between flight control surfaces) or if the airplane was not set up optimally, of there is a servo that suddenly starts to fight a flight control limit or a servo starts to buzz or hangs up. Also, when voltage remains optimal under load, the servos respond more crisply and accurately, meaning more positive flight control that does not "feel soggy" at speed or heavy maneuvering. That's all I'm saying. Sounds like you are pretty comfortable with yours, well done, and that's just fine by me!
Latest blog entry: The Gas Turbine Engine (with images)
One thing that I saw first hand the other day on my Bandito was my rudder slightly binding in the heat at Oakdale. All the flight controls are tightly faired for aerodynamics but I had to use a little 800 grit to clear out the threshold of the rudder surface that was rubbing against the top of the fixed fin. I thought, "wow, that could have taken out the whole jet on a marginal battery or even prehaps a good battery if it were bad enough". It's amazing, structurally, what happens in an airframe when loaded up with G's (based on full scale testing programs and evidence in RC). Hinge lines are no longer straight, controls flex and push against servos causing stall and massive loading - it can be a hostile environment for the RX electrical bus, wires, and the RX battery. How does this relate to the Spark? Well, it's just another example of a extremely capable modern EDF with a lot of servos. I'll try to stay out of the discussion, as I only admire all your Spark work from the spotter's position and don't have one (yet) of my own
Ok, so I got the Jet1A mains retracts and struts in today and have them mounted. Couple questions though...
When you have to make new screw holes to mount the retracts but they are too close to an old set of holes, what the best way to fill in the old hole for strength? Epoxy? I know that it is recommended to have a slight amount of tow-in on the mains, but with the flat spots already on the hardened steel pins, I can't adjust the tow. One main is straight, the other has a bit of tow-out. I imagine that on grass it won't matter too much, but what about on pavement? Will simply correcting with the rudder/nose wheel be enough to control it ok? Now that I have the final (hopefully) retracts in place, I am going to want to re-glass the area to fill in the openings that were made for the circle spring on the wire retracts. I see that I can order the paint from Comp-Arf, so what material is best to fill in the hole? Just use fiberglass resin and cloth? Lastly, the Tamjet brakes will work with some modification such as grinding down the attachment points on the back and drilling a pin to keep the whole thing from spinning. Do you think this is worth doing or does anyone know of a thinner "generic" brake hub that will work? Thanks guys. Edit: I guess the disc brakes here will work. Not too bad for $90 a set, but they may be too big. http://www.altecare.com/wheelbrake.htm |
Techspy I have had good luck with the BVM brakes and wheels.
http://www.bvmjets.com/Pages/wheels.htm#Construction |
Tips
Here is what I suggest
| Thread Tools | |
| Comp ARF Impact | Bill Mixon | Site Chat | 5 | Nov 01, 2005 04:04 PM |
| 31% Comp-Arf Video | Splummer | Sport Planes | 19 | Aug 20, 2005 01:12 PM |
| Sold Comp ARF YAK 2.6 w. DA 100 | Ulf Rieder | Aircraft - Fuel - Airplanes (FS/W) | 2 | Jul 05, 2005 04:08 PM |
| Comp ARF whistle for AFP | Fly-guy | Simulators | 0 | Jan 06, 2005 01:47 AM |
| NEW Comp-ARF Extra 2x2 | kody'd'punk | Sport Planes | 43 | Dec 09, 2004 09:17 PM |
