Espritmodel.com Heli Air
Old Sep 12, 2007, 12:11 AM
I'd rather be flying...
djdaveq's Avatar
New York City
Joined May 2005
will my 2.4 video down link interfere with my spectrum 2.4 rx & tx ?
will my 2.4 video down link interfere with my spectrum 2.4 rx & tx ? dont want to crash due to glitch!!
i want to do airel photos with a trex 600, what are my options men?
thanks.
dave
djdaveq is offline Find More Posts by djdaveq
Old Sep 12, 2007, 01:59 AM
ebill3's Avatar
United States, WA, Puyallup
Maybe, maybe not.
If the video link complies with FCC requirements to "not cause interference", you may be OK. However, many imported systems could care less about FCC requirements.
Might learn more in this forum.
Bill
ebill3 is offline Find More Posts by ebill3
Old Sep 12, 2007, 02:28 AM
Electric Airplane Junkie
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
Probably not, but the Spektrum WILL interfere with the Down link.
Switch to a 900MHz system for down link and it seems to be better.
brian
bhchan is offline Find More Posts by bhchan
Old Sep 13, 2007, 02:06 AM
Australia, NSW, Attunga
Joined Dec 2006
thanks.
dave
G'day Dave,
The camera will interfere with the RX, so always turn the camera on first, then the DX7 will not use that channel, & you will be fine.
alan0899 is offline Find More Posts by alan0899
Old Sep 13, 2007, 02:24 AM
Deletedfor proving Nauga wrong
Joined Mar 2005
What I have heard (never seen it... no one is doing video with a 2.4 ghz radio system around here... yet)
If the 2.4 ghz camera's transmitter is too close to the 2.4 ghz RX there might be problems.
So.. just to be paranoid... keep them separated as best you can.
fhhuber506771 is offline Find More Posts by fhhuber506771
Old Sep 13, 2007, 08:05 AM
d_wheel's Avatar
Deep in the Heart of Texas
Joined Jun 2004
The answer is yes and no. In my experience, if you keep the video transmitter separated from the guidance receiver by a couple of feet or more you will be able to use it but your range will still be affected somewhat. On the other end, your guidance transmitter will cause massive interference to the video receiver on the ground. If you are closer than 30 feet to the video receiver, all you will see is horizontal lines on your video screen. I went to 900mhz video equipment and it has worked out very well.
Later;
D.W.
d_wheel is offline Find More Posts by d_wheel
Old Sep 13, 2007, 05:40 PM
djdaveq's Avatar
New York City
Joined May 2005
i think im gonna run a 1.3 GHZ camera system instead that should not be a problem right?
Yippee! Video to celebrate 3 Weeks with my Trex 450S rcasey212 Mini Helis 8 Jun 04, 2007 03:59 PM
Discussion Video Down-Link Antenna IamLegend Aerial Photography 4 Sep 29, 2006 03:27 PM
Discussion Easystar with video down link. eflightray Aerial Photography 40 Sep 16, 2006 07:01 PM
My 8U Piccolo settings don't work with my 9CHP?? Chasvo Micro Helis 5 Sep 01, 2004 01:03 PM
WANTED! DC5-2.4 8:1 Motor! Need to get my Littlebee up and running! Carbine Aircraft - Electric - Airplanes (FS/W) 2 Jul 16, 2004 08:01 PM
