Old Sep 11, 2007, 01:24 PM
MILLERTIME is offline
Find More Posts by MILLERTIME
Taking care of the pond.
MILLERTIME's Avatar
United States, CA, Sanger
Joined Apr 2004
Build Log
Fire monitor
Im building a fire monitor for my tugboat. I started with a piece of 5/8 brass rod, I drilled a 3/16 hole off center ( see picture ). I then milled it to the shape I wanted, and drilled holes for the brass tubes. Using a parting tool on my lathe I cut it into two pieces.
For the base I used some brass fittings I had in my tool box. I put a can nut on the brass fitting and drilled a 3/16 hole through it. Using a lathe I put a taper on the base bottom and top of the fitting. The cap nut will hold the base to the deck. I then added a handle made from !/16 brass wire. I was going to paint it red, but it looks so good polished I might just clear coat it.
Don M.
MILLERTIME is offline Find More Posts by MILLERTIME
Old Sep 11, 2007, 01:26 PM
MILLERTIME's Avatar
Joined Apr 2004
More pictures!
Old Sep 11, 2007, 01:46 PM
keith S is online now
Find More Posts by keith S
r/c ships and workboats
bellingham, wa
Joined May 2006
looks verry nice. Polish to a sheen and clear coat!
keith S is online now Find More Posts by keith S
Old Sep 11, 2007, 01:58 PM
Kmot is online now
Find More Posts by Kmot
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Pretty cool, Don!
Kmot is online now Find More Posts by Kmot
Old Sep 11, 2007, 03:09 PM
Capt.Crash is offline
Find More Posts by Capt.Crash
**NOT GUILTY**
Capt.Crash's Avatar
Millbrook, Alabama
Joined Jun 2004
Real purty Millertime
I got my store bought monitor kit built and placed on deck with the plumbing in the monitor done but have not found a 6 volt pump yet...nor I have I decided if I want to attach the chain drive system to be able to turn the monitor. I will need a 6 channel radio to add that function. I would be curious as to how/where everyone is putting the intake hole in the hull and what is being used to screen the intake. Suggestions for a light, but decent power (5 ft discharge stream or more) 6 volt pump would be nice too.
Capt. Slick
Capt.Crash is offline Find More Posts by Capt.Crash
Old Sep 11, 2007, 06:31 PM
Brooks is online now
Find More Posts by Brooks
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Automobile windshield washer pumps can run on 7.2 volts. If you took your 6 volt battery to the autoparts store, perhaps they would let you try a pump.
For my tug's intake, I bought some brass screen, brass tubing, and a big brass washer at the hardware store. I soldered the washer to a short piece of brass tube, then glued the screen on the washer with epoxy. The washer is mounted on the outside of the hull - CA glue did not stay stuck, but the inside is sealed with Marine Goop, so no leaks. The only hard part is getting the silicon hose over the tube, be sure to find some larger/appropriate diameter hose if you go my route. Regular blue silicon model airplane fuel line is fine for pump to monitor, but of course the larger the tube, the more water output. Squirt distance depends on nozzle orifice size - 10' easy with this setup - actually easier to put out a fire with a shorter squirt (bigger nozzle).
Brooks is online now Find More Posts by Brooks
Old Sep 11, 2007, 07:59 PM
bill g is offline
Find More Posts by bill g
billg
Cleveland, Tennessee
Joined May 2007
water pump
SONIC-TRONICS makes model airplane fuel pumos in both 6 volt and 12 volt. I use a 6 volt in both of my fireboats,powered with a 7.2 volt model car battery. The extra voltage doesn't hurt it, as it's only on for a short time.
bill g is offline Find More Posts by bill g
Old Sep 11, 2007, 08:24 PM
Randroid is offline
Find More Posts by Randroid
Anchorage, AK
Joined Mar 2007
Wonder if one of these pumps would work for fire monitors. It is designed for a camping shower.
The 6 volt replacement water pump includes a 4 foot power cable, and a watertight battery case that holds 4 "D" batteries.
Item# 1067
http://www.zodi.com/web-content/Cons...cessories.html
Randroid is offline Find More Posts by Randroid
Old Sep 11, 2007, 09:52 PM
waboats is offline
Find More Posts by waboats
Joined Jan 2007
Capt. Slick
Graupner do a nice 6V Pump (Part #1953) that might fit the bill nicely.
A little expensive over wiper-washer pumps but the quality is there..
waboats is offline Find More Posts by waboats
Reply With Quote  (Disabled)
Old Sep 21, 2007, 10:28 PM
MILLERTIME's Avatar
Joined Apr 2004
More work on the tug, mounted the monitors and ran the tubing.
I used a mini servo to control the monitors. I am using a DX6 for the tug.
Old Sep 21, 2007, 10:36 PM
Kmot is online now
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Geez, never realized how small they were till now. That is gonna be so cool on the Atlantic tug!
Old Sep 21, 2007, 11:06 PM
Umi_Ryuzuki is offline
Find More Posts by Umi_Ryuzuki
Sea Dragon-Lover
Umi_Ryuzuki's Avatar
PDX, OR
Joined Dec 2002
I like the rotating bits...
Umi_Ryuzuki is offline Find More Posts by Umi_Ryuzuki
Old Sep 22, 2007, 09:09 AM
Brooks's Avatar
Joined Aug 2003
Very neat. The monitors will squirt in different directions, rather than in parallel, as you move the servo, it appears.
Old Sep 22, 2007, 09:28 AM
norgale is offline
Find More Posts by norgale
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
That is really a neat setup. Can't wait to see how the pump sets up. Does anyone use a bilge pump in their models? I see severl different styles on Naval Combat sites. One of them may work for the fire boat.
norgale is offline Find More Posts by norgale
Old Sep 22, 2007, 09:30 AM
norgale is offline
Retired for now
Bonita Springs,Fl.
Joined Sep 2007
Brooks; Are there any pictures of your avatar boat on this forum? I'd like to see more of that ship. Pete
Discussion wiring a switch for a motor for a fire monitor robster94gt Scale Boats 10 Jul 19, 2010 12:41 AM
Question Fire Monitor Pump intake 4bells Scale Boats 7 Jan 12, 2006 12:35 PM
