Old Apr 21, 2008, 03:28 PM
FlattyFlier is offline
Find More Posts by FlattyFlier
Joined Dec 2003
No, it will be slimy unless cleaned with alcohol, but it will not hurt styro or EPP foam.
FlattyFlier is offline Find More Posts by FlattyFlier
Old Apr 21, 2008, 10:12 PM
Keemos is offline
Find More Posts by Keemos
Keemos's Avatar
Erial, NJ
Joined Apr 2004
Originally Posted by jpilkinton
Will the fuel hurt the foam? I don't care about the color changing. I just don't want to be flying and the engine fall off in mid flight due to melted foam from the fuel.
I agree with Jake... glow fuel will not hurt the foam. I used to have a CUB power by .15 glow engine way back in the 80's.
Keemos is offline Find More Posts by Keemos
Old Apr 21, 2008, 11:39 PM
Joined Dec 2003
I use a $1 store mini spray bottle filled with 50-90% rubbing alcohol that spray the plane down with and wipe it clean with a paper or terry towl. Cleans right up, as the thin alcohol gets into the little bumps and crevises and gets the oil out.
Cox used to make RTF .049 2-3ch. airplanes way backwhen I first started. They came out with the first Lazy Bee design in a .049 powered 2ch. RTF package with an all styro airframe, as well as a couple others!
Old Apr 22, 2008, 12:54 AM
jpilkinton is offline
Find More Posts by jpilkinton
Jacksonville, AR
Joined Mar 2008
Cool, thanks for the heads up guys.
jpilkinton is offline Find More Posts by jpilkinton
Old Apr 22, 2008, 10:31 AM
Joined Dec 2003
One more hint, dont run dark colored fuels, they will turn the plane that color! Pinks and blues will discolor the least, but you cant escape it completely, unless you get some clear (or any color) Ultracote or low temp covering to cover the area most prone to get greased!
Old Apr 23, 2008, 03:26 AM
Jacksonville, AR
Joined Mar 2008
OK. The fuel that I just bought has a blue color. Man I didn't realise how expensive model fuel is. I bought a gallon and it was $26(at a local hobby shop). It's been like 30 years since I bought glow fuel.
Too bad I can't run unleaded with an oil mix!
$4 a gallon sounds better than $26 a gallon.
Old Apr 23, 2008, 08:05 AM
Andrew0820 is offline
Find More Posts by Andrew0820
Western KY
Joined Sep 2003
Make sure it has a sufficient percentage of oil, with the oil content being at least 60 to 80% castor.
At around 8 to 9 minutes an ounce, you have enough fuel for 17 to 18 hours of flying. That works out to about $1.50 an hour -- where else can you have that much fun for a buck and a half?
Andrew0820 is offline Find More Posts by Andrew0820
Old Apr 23, 2008, 10:23 AM
borisp is offline
Find More Posts by borisp
Zagreb, CROATIA
Joined Jun 2002
... Man I didn't realise how expensive model fuel is. I bought a gallon and it was $26(at a local hobby shop)....
Some more calculations:
18 hours -> 1080 minutes
I bought my 1300 mAh Hextronik LiPo's at HobbyCity (aka UnitedHobbies) for about the same price (when shipping added).
Flight time per cycle is roughly 8 minutes.
1080 / 8 = 135 cycles
They all puffed after 20-30 cycles or latest 3 months of use. Whatever comes first.
So reaching 135 cycles would be pure theory. 135 cycles without drop of performance and capacity - science fiction.
Be happy!
borisp is offline Find More Posts by borisp
Old Apr 24, 2008, 02:25 AM
Jacksonville, AR
Joined Mar 2008
Yeah that's true. My wife was there when I bought it. Her jaw dropped quick when he said the price. But like I told her, that will last me a while. And now we have more stink'n rain and too high of winds, I think this gallon will last me a year or more.
I am currently working on a cylindrical fuel cell about 6-8 inches in length that will(or should) give me plenty of flying time at one shot. I don't know for sure, since I have not ran my engine yet. I plan on testing this weekend.
Old Apr 24, 2008, 02:41 AM
Jacksonville, AR
Joined Mar 2008
OK, I think I seen this somewhere about using diesel in these cox engines.
Has anyone tried using pump diesel with these cox engines before? Both engines have the same theory. I know the compression is far lower on the cox, but I am curious about it. I have seen head kits for using diesel that don't use glow elements to aid in combustion, but I'm thinking the glow element would help the cox ignite the fuel better than no glow plug at all.
Curious minds want to know...........
Old Apr 24, 2008, 08:02 AM
Jupeli is offline
Find More Posts by Jupeli
Pirkkala, Finland
Joined Jan 2005
You'll need the diesel conversion head, which I think are pretty easily available. A glow plug is based on a chemical reaction between the glow element, (dunno what it actually is made of) and methanol, thus diesel fuel won't work. OS Engines made a bioethanol engine a while ago, the OS .55 AX BE, which needs a special glow plug. Ever wonder why?
Jupeli is offline Find More Posts by Jupeli
Old Apr 24, 2008, 08:23 AM
Western KY
Joined Sep 2003
JP --
You cannot get enough compression using the standard COX head to run diesel. There are conversion heads available, but to expect any longevity from your engine, the crank will also need to be replaced with an aftermarket version. The OEM crank is not beefy enough to withstand higher compression required by diesel fuel. The typical point of failure is in the web just below the crankpin.
COX glowheads are becoming difficult to locate and can be quite pricey -- the Sure Start at $6.99 from COX Models can really be thought of as an inexpensive head with a free engine attached. A good replacement head is the Galbreath head/NELSON plug combination available from Larry Driskill at Kitting It Together. It is one of the few aftermarkets that will work as well or better than the original head. If you order an aftermarket head, it may be a good idea to pick up a pack or two of head shims (gaskets) -- some of the Sure Starts I have purchased recently have been notorius for leaking around the head. Additionally, the copper gaskets are easily damaged and may need replacement.
If you intend to use anything over a 6x3, you may want to reduce the compression even more and an extra shim will give you this option. I agree with Jupeli -- 6x3 is about max for most runs. Texaco competitors have used 7" props, but with reduced compression.
andrew
Out of curiosity, what brand and mix of fuel did you buy?
Old Apr 24, 2008, 08:30 AM
GunnyGlow is offline
Find More Posts by GunnyGlow
piro-maniac........
GunnyGlow's Avatar
United States, CO, Aurora
Joined Dec 2007
It's a catalytic reaction between the methanol in the fuel and the platinum in the glow plug.........
GunnyGlow is offline Find More Posts by GunnyGlow
Old Apr 27, 2008, 12:54 AM
Jacksonville, AR
Joined Mar 2008
JP --
It is Traxxas Top Fuel 20% nitro. I did get it to start with the large prop but before it could get up to speed, it dies. So I used a smaller prop from a GWS slow stick electric. Now it starts and gets up to speed rather quickly, but then dies quickly. I am having a fuel delivery problem. So I decided to tear the engine down and clean it completely and make sure there were no shavings from the factory and make sure everything is square.
Old Apr 27, 2008, 02:35 PM
bebopgolf is offline
Find More Posts by bebopgolf
bebopgolf's Avatar
Columbus, Ohio
Joined Feb 2007
ssx + thunder tiger .07 and call it the micro glow stick
What do you think?
http://2dogrc.com/ecommerce/os/catal...ng-p-2340.html + http://www.acehobby.com/ace/00_engines.htm or http://www.towerhobbies.com/products.../gbga1026.html + http://www3.towerhobbies.com/cgi-bin...1&I=LXPUE0&P=3 or
http://www.mega-rcmodel.com/index.ph...111770&Ntype=2 + http://www3.towerhobbies.com/cgi-bin...1&I=LXPUE0&P=3
bebopgolf is offline Find More Posts by bebopgolf
Torn Between Electric and Glow fly4fun Electric Plane Talk 47 Mar 20, 2008 10:54 AM
Electric power for a 25 pound model... Jason M Electric Plane Talk 7 May 22, 2002 12:38 PM
Ezoners at Old Warden/Traplet Vintage and Electric Event May 25/26? Thomas B Electric Flight Events 4 May 21, 2002 01:41 PM
GLOW/GAS .25 wing (80mph) DEATHspiral Aircraft - Fuel - Airplanes (FS/W) 1 Apr 02, 2002 10:24 AM
GLOW WING .25-.28 (80mph) DEATHspiral Aircraft - Fuel - Airplanes (FS/W) 0 Apr 01, 2002 10:14 PM
