Old Mar 30, 2009, 04:17 PM
gramps45 is offline
Find More Posts by gramps45
Originally Posted by dgliderguy
Pink is castor/synth, green is all synthetic. Get the pink...
thanks don
gramps45 is offline Find More Posts by gramps45
Old Apr 01, 2009, 09:14 PM
gramps45 is offline
got another new-b question. i bought a os10fsr that came with 781 muffler that have just a small hole in back for the exhaust and no other fitting. i saw the os10la on the os site and it has the 871 muffler with a bigger exhaust bipe and a nipple fitting. is the 781 muffler okay for the 10fsr
thanks
milton
Old Apr 02, 2009, 10:35 AM
dgliderguy is online now
Find More Posts by dgliderguy
Where's the lift?
dgliderguy's Avatar
United States, WA, Snohomish
Joined Mar 2001
Milton,
No reason why you couldn't use a muffler with no pressure fitting.
I run pressure in all my installations, as it ensures a more positive fuel flow in all flight attitudes, but it is not essential. Just be sure the tank is mounted close to the engine (and not three bays back, in the baggage hold!), and that the fuel level is even with the carburetor.
dgliderguy is online now Find More Posts by dgliderguy
Old Apr 02, 2009, 11:38 AM
gramps45 is offline
thanks for the help. i don't know of anyone who fly's 1/2a here. if the tank have 2 tubing, the pick up and the overflow(i think) do i plug the overflow before flying?
thanks
milton
Old Apr 02, 2009, 11:49 AM
Where's the lift?
dgliderguy's Avatar
Joined Mar 2001
Absolutely NOT. The overflow is your vent line. Without a vent, the tank would have negative pressure as the fuel is drawn, which would eventually starve the flow. Just hang the vent line out somewhere, so that when you fill the tank, the overflow ends up on the ground and not inside your plane.
Old Apr 15, 2009, 03:45 PM
unattainium is offline
Find More Posts by unattainium
Chicago
Joined Jan 2009
Originally Posted by Jupeli
They don't go hand in hand... If yo do so, you will end up underpowered. I'd guess it has something to do with prop efficiency or so. Any way, I don't know why it is so but it just is... I've been flying a .40-sized pattern plane with 450W of power from an electric motor. Not quite eguivalent to a .40 2-stroke, right? (OS .40 LA - 1hp = 746W)
A watt is a watt regardless of its source. I suspect that what you are seeing is that the peak HP of an engine occurs at a certain RPM with a certain fuel, an optimum needle setting and in a favorable climate. it is usually run rich below its maximum power. An electric motor eats electrons and they do not have nitro percentages etc or mixture tuning and the output of the electric motor is basically linear with RPM, not non-linear like the IC engine. When making a conversion you need to figure out the every day HP for the IC engine, not used its best ever performance.
To match the output at the prop requires that the IC engine be rated at perhaps 60-70% of its rated HP. Sport engines with a flat power curve will need less derating than peaky high performance engines.
unattainium is offline Find More Posts by unattainium
Old Jun 21, 2009, 03:25 PM
bebopgolf is offline
Find More Posts by bebopgolf
bebopgolf's Avatar
Columbus, Ohio
Joined Feb 2007
This video Is loooooong overdue!
pitts 2009 (7 min 11 sec)
This is the Carl Goldberg Monster Pitts electric to glow conversion flight video. I have been flying it for a while but never had anyone to video. But all the stars lined up today so here it is. It has a os .25 LA on it and flies very scale. It will tip stall fast on high rates. It is small and fun otherwise!
bebopgolf is offline Find More Posts by bebopgolf
Old Nov 11, 2009, 08:32 PM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Hello -re Goldberg Pitts
Nice video, great landing!
I have one also, and converted to 46LA, still haven't flown it. The 46LA runs fine with an 11inch prop and should pull nicely.
As an electric, I have had many incidents with this plane and was never really happy with the cg location. I would like to know where you balance yours if you can tell me.
Other mods on mine include metal gear servos located aft for rudder and elevator (the park flyer type push rods flexed too much), 1/2 A type horns, heavily reinforced support for landing gear which is salvaged from a 40 size trainer.
I have another one new in the box waiting, might get a 25 or 36 for it.
Thanks!
victapilot is offline Find More Posts by victapilot
Old Nov 12, 2009, 12:32 AM
FlattyFlier is offline
Find More Posts by FlattyFlier
Joined Dec 2003
A guy at our field has one with a .30(ish) sized 2 stroke on his, it flies very well and looks great, but he tore the LG out of it a couple weeks ago and bent/broke the wing struts when it tip stalled his.
I'd like to try one with a small saito .45!
FlattyFlier is offline Find More Posts by FlattyFlier
Old Nov 12, 2009, 08:44 AM
victapilot's Avatar
Joined Feb 2009
Been there and done that! Mine has tip stalled at altitude, follwed by death spiral - not pretty.
My choice of 46LA was based only on the fact that I had one sitting around. It's not too heavy and runs well. Other projects have kept me from flying it - need a perfect day without crosswind...
Old Nov 12, 2009, 12:54 PM
bebopgolf's Avatar
Columbus, Ohio
Joined Feb 2007
If I were to do it again I would have put a 40 la in it. My cg is a little forward of recommended... maybe about an 1/8 of an inch. It will fly pretty good on low rates but on high rates the motor is not strong enough. Also I beefed up my landing gear after it tore off.
Old Nov 12, 2009, 07:35 PM
Glue Gun is offline
Find More Posts by Glue Gun
registered user
Annapolis, MD
Joined Sep 2009
Here is my electric to glow conversion. I was inspired by that slow stick AP .061 video on youtube. I hoping to do some snow flying with it this winter. The wing is custsom.
Glue Gun is offline Find More Posts by Glue Gun
Old Nov 13, 2009, 07:37 AM
millerhill is offline
Find More Posts by millerhill
millerhill's Avatar
USA, VT, Brandon
Joined Aug 2004
Glow Stick....very nice. Looks like fun. Have you flown it yet? What's that engine and how's you get your CG to work out with that power pod hanging off the nose?
Steve
millerhill is offline Find More Posts by millerhill
Old Nov 13, 2009, 03:14 PM
Glue Gun is offline
registered user
Annapolis, MD
Joined Sep 2009
Yes I have flown it lots of times. I built it last december. The engine is as TT .07. Everything is stock accept for the wing and the engine. The servos, reciever, battery are all where you would have them if you were using the electric setup. The engine mount is made from a piece of plastic cutting board that is bolted to the carbon fiber stick. The bolts that I used were the same bolts I used to bolt the engine down (Dubro 4-40 with lock nuts). The 2 oz tank is rubber banded to the stick. The throttle servo is double sided foam taped and rubber banded to a piece of metal screwed to the cutting board. To compensate for this extra weight in the front (even though the engine itself does weigh less then that lame old speed 400 gear drive that comes with the kit) I simply slid the wing mounts forward on the stick. The battery I use to power the electronics is an old 700 mah 2 cell lipo with a 5v regulator. I ditched the original wing after the first few flights and built my own out of Lowes blue fanfold foam (which is what I use to make all of my airplanes nowadays, even spads) because it was hard to clean and it caused the plane to want to keep turning after I had made a turn. My custom wing is lighter (no metal struts), simpler (three pieces of foam glued together with hot glue), the plane is more responsive with it and it is easier to clean (no packing tape for the exhaust to get under). My custom wing is also the same size with the same amount of dihedral as the original. With the TT, performance and endurance are excellent. It does not have unlimited verticial, but I can cruise around the field at a little above quarter throttle. With two ounces of omega 10% I can get over 15 minute of flight time. I am very happy with how it tuned out! Way more fun than if it were electric! Flys much faster!
PS: Those brushed speed 400 jobs are lame because after one good crash, the shaft is bent.
GG
Old Nov 16, 2009, 05:21 PM
victapilot's Avatar
Joined Feb 2009
Hi!
Thanks for cg location. Mine is at the leading edge of the lower wing. Flew it today without the cowl. Need to put in a 3 line tank and then put on the cowl.
For now plenty of power with 46la and 12x6 prop. Actually easier to land than electric, just enough low rpm power at idle. Also I have put landing gear about 1" forward of original.
Will post pictures later, maybe on another thread since this is for smaller engines.
Torn Between Electric and Glow fly4fun Electric Plane Talk 47 Mar 20, 2008 10:54 AM
Electric power for a 25 pound model... Jason M Electric Plane Talk 7 May 22, 2002 12:38 PM
Ezoners at Old Warden/Traplet Vintage and Electric Event May 25/26? Thomas B Electric Flight Events 4 May 21, 2002 01:41 PM
GLOW/GAS .25 wing (80mph) DEATHspiral Aircraft - Fuel - Airplanes (FS/W) 1 Apr 02, 2002 10:24 AM
GLOW WING .25-.28 (80mph) DEATHspiral Aircraft - Fuel - Airplanes (FS/W) 0 Apr 01, 2002 10:14 PM
