Old Nov 26, 2002, 01:09 AM
splat man is offline
Find More Posts by splat man
Joined Dec 2001
what to do with a Graupner sp 700bb 12v?
I got one of these cheap from HL and have no idea what to do with it. HL claims it will spin a 12x8 350+ whatts 25 amps on 12 cells direct drive. The motor is about 12oz, if I used the 4/5 A 1950 nimhs, another 17 or 18 oz. Any ideas? HL says about 35 oz of thrust. I was thinking about a Sureflite Cub or maybe a Big T on the above setup.
splat man is offline Find More Posts by splat man
Old Nov 26, 2002, 03:49 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
With a gearbox, and that sort of cell count or a few more on big props it will lift a 40 sized plane quite well. DD its OK for a faster type 25 warbird or something.
If you narrow down the plane type and post sizes and weights, we can plug in motocalc for you...
Old Nov 26, 2002, 02:46 PM
Joined Dec 2001
How about the Easybuilt Hurricane I'm just finishing? 50" wingspan, fully sheeted about 410 sq inches, without drive and batteries 32 oz (w/radio gear). The motor I was considering was a MM/3:1-10cells.
Old Nov 26, 2002, 04:57 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
If you stick with 3/4 SC CP1700 cells, it will work on the Hurricane, but it will be fast!
I like the MM setup, but a 2.5 ratio is much better to keep the prop to 11 inches.
Fred Bronk is offline Find More Posts by Fred Bronk
Old Nov 26, 2002, 06:02 PM
Joined Dec 2001
I like the cp1700's, but twelve of them would would be close to 20 oz. On paper, the Gr 700 would put out more watts (350) on 12c than the MM geared 3.5 on 10cells and both should put out around 35 oz thrust with 12" prop. BTW, can someone explain to me which is more important? how can both motors put out about the same thrust but the sp700 have far more watts? what the difference when botha er spinning the same prop?
Old Nov 26, 2002, 07:10 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
I got one of these as well. Paid about $5 for it. I'm thinking of gearing it 3 to 1 or 3.5 to 1 and throw a big prop. Something like a large trainer weighing in around 60 to 70 oz. Big wingspan like
60 inches or so. Hehe, a flying Rhino!!!
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Nov 27, 2002, 11:54 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
splat man,
That 350W figure is Watts IN. Propeller size and RPM indicate Watts out. If both motor setups spin the same prop at the same RPM, then the Watts out is the same on both. This is where efficiency comes into play. The one that requires less Watts in is more efficient.
The big Speed 700 is not as efficient in direct drive as the geared MM. If you put a gearbox and a big prop on the 700 and let 'er wind up, you'll get a whole lot more Watts out.
mkirsch1 is offline Find More Posts by mkirsch1
Old Nov 27, 2002, 12:12 PM
rcjunkie is offline
Find More Posts by rcjunkie
SEFF Contest Director
rcjunkie's Avatar
USA, GA, Stone Mountain
Joined Oct 2000
The best use! Paper Weight like all my Speed 600 motors!
rcjunkie is offline Find More Posts by rcjunkie
Old Nov 27, 2002, 01:38 PM
Joined Dec 2001
Mkirsh1- Thanks for the explanation--I always wondered about the "watts at prop" ratings some motors used.
Rcjunkie-- I know how you feel. This motor is a step up from the 600 can as far as quality. I have a bunch of various 550/600 can motors that are a real challenge to do anything with. Something that wieghs 8 oz yet puts out as much as a sp400g is a tough. I do think that a WWI 45-50" fighter that is LIGHT might work with this sp 700 geared at 2:1 swinging a 16" prop on 16 cells.
What to do with all those Graupner motor stickers Vonbaron Electric Plane Talk 16 Jan 29, 2003 09:51 AM
What to do with my Christmas money? King Kong Electric Heli Talk 1 Dec 28, 2001 10:23 PM
What to do with Zagi Equipment? AirVenture Foamies (Kits) 4 Dec 11, 2001 08:05 PM
What to do with the dangle? alistairg Foamies (Kits) 3 Nov 25, 2001 04:32 PM
What should I do with a Graupner 480??? Regecide Electric Plane Talk 10 Apr 30, 2001 02:34 AM
